Hudy Air Vac
The HUDY Air Vac is a handy, ultra-compact electric-powered vacuum pump for 1/8 off-road shock absorbers.
HUDY Air Vac - Vacuum Pump - 1/8 Off-Road
The HUDY Air Vac is a handy, ultra-compact electric-powered vacuum pump for 1/8 off-road shock absorbers. It was developed to quickly and easily bleed unwanted air bubbles from oil-filled shock absorbers and differentials. It can also be used as a tire additive penetrator to help penetrate additive into the small pores of foam tires. The main platform is CNC-machined from aluminum and includes exchangeable shock/diff stands and a transparent plastic cover.
The Air Vac includes strong and effective vacuum pump that is powered by a 12V power supply or 7.2V battery (not included). It Includes holders for shock absorbers and differential and a 600mm connecting cable with gold-plated banana plugs. You also get a premium hard case for safe storage and transport.
  • Removes air from shock absorbers & diffs in seconds
  • Ultra compact & handy design
  • For 1/8 off-road shock absorbers
  • Machined from premium Swiss 7075 T6 aluminum
  • Includes holders for shock absorbers & differential
  • Included 600mm connecting cable with gold-plated banana plugs
  • Premium hard case for safe storage & transport
  • Individually assembled & tested
  • Works with 12V power supply or 7.2V battery (not included)
  • Available in 3 different sizes: on-road, 1/10 off-road, and 1/8 off-road
  • May be used also as a tire additive penetrator
Check out the Hudy Air Vac Here
May 01, 2019, 10:37 PM
Cabledawg1's Avatar
Who has $130 to blow on this nonsense?
May 08, 2019, 05:13 PM
Earth-bound misfit
Pontiac428's Avatar
People who don't know how to hook a hand pump to a mason jar? Battery warming is illegal, and some people gotta do something with their fidgety hands between races. It's a lot of fuss work for a (debatable) marginal gain
Discussion Fuselage mold vac bagging. Tim Harbour Composites Fabrication 9 Oct 21, 2016 02:43 AM
Discussion Molded / Vac Solid Core Bagged DLG wings Advice needed Chuchuf Composites Fabrication 40 Mar 04, 2016 09:06 AM
Build Log Vac-U-Cracker CashRC Racing Boats - Electric 17 Dec 21, 2015 05:54 PM
Discussion Vac u tow - Boating on the cheap jwill05 Scale Boats 2 Dec 06, 2015 11:32 AM
Hot to get vac bag to hold vac. joelontheroad The Builders Workshop 3 Oct 21, 2003 08:58 AM
