This thread is privately moderated by scousethief, who may elect to delete unwanted replies.
Apr 29, 2019, 05:32 AM
Quad Erat Demonstrandum
scousethief's Avatar
New Product
Volantex New Models
Nice to see more Volantex models hit the shelves. Their Phoenix and Ranger Gliders are excellent quality and perform beautifully. I have ordered the Kit version of the Saber for some summer bashing Both PNP and KIT version are available for each of the models.
https://www.banggood.com/custlink/KDv3reKezD
Volantex Saber 920 756-2 EPO 920mm Wingspan 3D Aerobatic Aircraft RC Airplane KIT/PNP
Description:
Brand name: Volantex RC
Item number: Saber 756-2
Wingspan: 920mm
Overall Length: 875mm
Flying Weight: 1100g
Prop Size: 1260 propeller
Motor Size: 2215/1400 Powerful brushless motor
Speed Control : Easy-Plug 30A Switch-Mode BEC brushless ESC
Servo 9-gram Servo * 4pcs
Recommended Battery 11.1V 1800mAh Li-Po
Flaps No
Retracts No
Minimum Age Recommendation: 14years
Experience Level: 8
Recommended Environment: Outdoor
Assembly Time: Less than Half Hour
Is Assembly Required: yes
Version: Kit, PNP (Optional)
Features:
* Great 3D flight performance: 4 channel remote control airplane, 3S power system and perfect size make 3D flight easy.
* Durable Material: Light weight and durable EPO construction, EPO is a special foam material which make the plane won’t get broke easily.
* Quick Assembly: High complete kit easy to assemble, assembly time less than Half Hour.
* Plug And Play: Include all electronic parts of the model, customer needs to purchase the transmitter, receiver, battery, and charger additionally.
Recommend Parts (Not included):
Motor: Brushless 2215 1400KV Click here
ESC: Brushless 30A Click here
Servos: 4 x 9 g Click here
Battery: 11.1V 1800mAh Li-Po Click here
Charger: LiPo charger Click here
Transmitter: 2.4Ghz 4-Channels Click here
Receiver: 2.4Ghz 4-Channels Click here
Package Contents:
1 x Airplane (Kit/PNP Optional )
https://www.banggood.com/custlink/mKGKc630QV
Description:
Brand Name: Volantexrc
Item Name: TrainStar Epoch
Item NO.: 747-6
Version: KIT, PNP (optional)
Material: EPO
Wingspan: 1100mm (43.3 in)
Overall Length: 864mm (34 in)
Flying Weight: 820g
Prop Size: 8" propeller
Motor Size: 2216/1400KV
Speed Control : Easy-Plug 20A Brushless ESC
Servo: 9g Servo *4pcs
Flaps: No
Retracts: No
Minimum Age: Recommendation: 14 years
Experience Level: Beginner
Assembly Time: Less than half hour
Is Assembly Required: Yes
Features:
- [Great For Beginner] 4 channel remote control airplane, built in 6 Axis gyro system super easy to fly even if you are a beginner.( 6 Axis gyro is combined with receiver,only included in RTF version)
- [Durable Material] Strong Blow Plastic Fuselage provides flexibility and durability to keep the plane from crashing damages.
- [Strong Power System] Powerful over-grade motor system allows easy controlling to do aerobatic flying.
- [Plug And Play] PNP version includes all electronic parts of the model, customer needs to purchase the transmitter, receiver, battery, and charger additionally.
- [Floats optional] Make the airplane can slide on the lake or pool if it mounted under the fuselage.(need to purchase floats additionally)
Recommended Parts For TrainStar Epoch (not included):
Battery: 11.1V 1500mAh 25C Li-Po, Click Here
Charger: 3S LiPo balancing charger, Click Here
Radio: 2.4Ghz 6 Channels, Click Here
Note:
KIT version doesn't include motor,esc,servo,transmitter,receiver,battery,charg er and gyro.
PNP version doesn't include transmitter,receiver,battery and charger and gyro.
Please select the version you prefer.
Package Included:
1x Volantexrc TrainStar Epoch 747-6 V2 1100mm Wingspan EPO Trainer
https://www.banggood.com/custlink/mKDKJgD4n6
Description:
Item Name: TrainStar Ascent
Item NO.: 747-8
Wingspan: 1400mm
Overall Length: 1010mm
Flying Weight(without battery): 820g
Material: EPO & Plastic
Motor: BL 4023/1050KV
Speed Control: BL ESC 40A
Servo: 9-gram Servo * 4pcs
Flaps: No
Retracts: No
Experience Level: Beginner~Expert
Assembly Time: Less than 20min
Is Assembly Required: Yes(PNP) No(RTF)
Package Size (L x W x H): 96.00 x 24.50 x 19.00 cm / 37.80 x 9.65 x 7.48 inches
Features:
- [ Integrated Gyro Easy To Control ] 6-axis gyro ultra stable self stabilization of gyro system. Powerful over-grade motor system and 4 channel allow easy controlling to do aerobatic flying.(gyro is combined with receiver, RTF version included)
- [ Beginners' Frst RC Airplane Trainer ] 3-level flight control assists(Beginner level with full assist/ Intermediate with partial assist/ Expert for manual control) help beginners learn to fly step by step.
- [ Easy To Get It Back ] After setting up one key return function, you are able to return it to the opposite direction that the airplane take off, it makes this airplane more friendly to beginners.(this function has been set up on receiver, RTF version included)
- [ Durable Material Brings Long Life Tome ] Strong Plastic Fuselage provides flexibility and durability to keep the plane from crashing damages.
- [ Two Versions Optional ] PNP:Include all electronic parts of the model, customer needs to purchase the transmitter, receiver, battery, charger additionally; KIT: All electronic parts of the model are not included,customer needs to purchase the motor,ESC,servo,transmitter, receiver, battery, charger additionally. Portable package to go with you everywhere.
Recommended Parts For TrainStar Ascent (not included):
Battery: 3S 11.1V 2200mAh Li-po, Click Here
Charger: Li-po Charger, Click Here
Radio: 2.4Ghz 4-Channels, Click Here
Note:
Package Included:
Volantex TrainStar Ascent 747-8 1400mm Wingspan EPO Trainer
https://www.banggood.com/custlink/vGmKJ6vgAq
Volantex RC 768-1 Mustang P51D 750mm Wingspan EPO Warbird RC Airplane PNP/RTF
Mustang P51D airplane is the most intelligent RC airplane ever offered by VolantexRC. It’s a good size for beginners to start in RC airplane. Mustang P51D is capable of performing a basic complement of aerobatic Maneuvers dry as loops, rolls, and even inverted flight.
It is a high performance plane, stable and easy to be under control. EPO is not easy to be broken, so it is a good choice for the beginners. The whole plane is high completeness and easy for beginners to assemble.
Description:
Model: 768-1 Mustang P51D
Wingspan: 750mm (29.5 in)
Overall Length: 650mm (25.6 in)
Flying Weight: 270g
Flaps: No
Retracts: No
Minimum Age Recommendation: 14 years
Assembly Time: Less than 10 minutes
Color: Blue, Red (Optional)
Version: PNP, RTF (Optional)
Features:
* The ideal beginner’s choice when learning to fly.
* Quick, easy assembly.
* Light weight and durable EPO construction.
* Powerful brushless outrunner motor.
* Easy-Plug 10A brushless ESC.
* High complete kit easy to assemble.
* High performance in low speed pass.
Recommend Parts:
Prop Size: 7040 propeller
Motor Size: 2808 brushless outrunner (included in PNP and RTF)
Speed Control : Easy-Plug 10A brushless ESC (included in PNP and RTF)
Servo 9-g Servo *3pcs (included in PNP and RTF)
Recommended Battery: 11.1V 500mAh ~ 800mAh 20C Li-Po (included in RTF)
Charger: 2S LiPo balancing USB charger cable ( included in RTF)
Radio: 2.4Ghz 6-Channels (included in RTF)
Package Included:
1x Volantex RC 768-1 Mustang P51D Warbird PNP/RTF
https://www.banggood.com/custlink/mD3Gc4GnJI
The Super Cub 750mm Sport Park Flyer is the ideal beginner's choice when learning to fly with an instructor. It's small size makes it easy to transport , but it's power makes it a joy to fly. The top wing design of the Super Cub provides gentle handling characteristics with a flowing glide. Increasing the throw on the control surfaces really opens the this docile plane up allowing for tight angle turns, loops, and other aerobatic tricks!
Upgraded: New batch comes with Integrated flight control with self-stabilization function (11.08)
Description:
Iten number: V765-2
Overall Length: 520mm (20.5 in)
Flying Weight: 200g
Servo: 9-gram Servo * 3pcs
Flaps: No
Retracts: No
Radio: 2.4Ghz 4-Channels ( included in RTF )
Features:
* The ideal beginner’s choice when learning to fly with an instructor
* Quick, easy assembly, no glow required
* Lightweight and durable EPO construction
* Powerful brushless outrunner motor and good value 180A Power system two choice
* ABS cowling make it super durable
* A lot of potential to be upgraded become a good performance sport plan
Volantex V765-2 Super Cub Spare part, Click here
Package Included:
1X Volantex RC V765-2 765-2 Super Cub 750mm Sport Park Flyer RTF
Apr 29, 2019, 06:18 AM
Volantex also produce some pretty sweet gliders that are so popular they have been created in multiple sizes to suit every flying field
https://www.banggood.com/custlink/3vDGW0mAFF 2.4m/2400mm Phoenix Glider
https://www.banggood.com/custlink/mm3vr4vsIy 2.0m/2000mm Phoenix Glider
https://www.banggood.com/custlink/3m3DJ0mNil 1.6m/1600mm Phoenix Glider
Description:
Item number: 759-3 Phoenix 2400/2000/1600
Wingspan: 2400mm/2000mm/1600mm
Overall Length:varies
Flying Weight: varies
Minimum Age Recommendation:14 years
Experience Level:Beginner
Recommended Environment:Outdoor
Assembly Time:Less than 1 Hour
Is Assembly Required:Yes
Features:
* Click & plug Easy Wing Mounting.
* Durable Plastic Fuselage.
* Professional Level Glider.
* Sporty flying performance.
Recommended parts are listed on Banggood's Website and on https://www.volantexrc.eu/
Some Awesome examples available here on RCGroups
https://www.rcgroups.com/forums/show...3-Phoenix-2400
https://www.rcgroups.com/forums/show...in-1-RC-Glider
https://www.rcgroups.com/forums/show...2400-update%29
Volantex Ranger
https://www.banggood.com/custlink/vvv3W4GNL7 Ranger 2.0m/2000mm
https://www.banggood.com/custlink/vvv3W4GNL7 Ranger 1.6m/1600mm
https://www.banggood.com/custlink/KmD3WeDne2 Ranger 1.38m/1380mm
https://www.banggood.com/custlink/vvDvCembsD Ranger 1.2m/1200mm
Description:
Brand: Volantex
Item Name: Ranger 1600
Item NO.: V757-7
Wingspan: 1600mm
Fuselage Length: 1100mm
Fuselage Material: EPO material
Propeller Size: 8040
Color: White
Brushless Motor: 2212 1400KV
Brushless ESC: 30A ESC
Servo: 9g servo x 4
Features:
Light weight and durable EPO wing construction.
Plug-in and click structure,easy to assemble.
Big cabin to install more equipments.
Volantex ASW28
https://www.banggood.com/custlink/mGvvC03bsS 2.54m/2540mm
The full-scale ASW 28 is a Standard Class glider with a fifteen metre span built of modern fibre reinforced composites. The manufacturer of the ASW-28 is Alexander Schleicher GmbH & Co. The 'W' indicates this is a design of the influential and prolific German designer Gerhard Waibel. Serial production started in 2000.
As all Standard Class sailplanes, the ASW-28 does not have flaps or other lift-enhancing devices. It has tall winglets, a retractable undercarriage and a water ballast system. The structure is a complex composite of carbon, aramid and polyethylene fibre reinforced plastic. This permits a light structure with the strength to carry large amounts of water ballast, thus permitting the widest possible range of wing loadings for weak and strong soaring weather.
Volantex ASW 28 is a sport scale model that does incorporate flaps unlike its full scale counterpart. It comes plug and fly so you just need to complete some final assembly, install your battery, receiver and fly. The airframe is a mix of EPO foam for the wings and tail, with a blow molded plastic fuselage. This gives a slick finish that is also extremely durable. Great for those less than perfect slope sites. A powerful 4018 850kv brushless outrunner motor rockets the ASW 28 to altitude, then when you throttle down, the propeller folds back for extended soaring. Accessing the battery is easy through the canopy with four small snap locks that keeps the canopy secure.
This Version 2 comes with lots of extra features. The wings come with two spars in each wing to give extra strength during those tight turns and power dives. Installing the wings is now easier with a plastic latch for securing the wings. Inside there is now a bigger plywood tray to make it easier to carry FPV camera's, VTx's or other electronics. Landings are now a lot easier with the inclusion of landing gear. No more scraping the fuselage.
Description:
Item Name: ASW28
Wingspan: 2540mm
Length: 1132mm
Flying Weight: 1050g
Motor: 850kv Brushless Outrunner Motor
ESC: 30A w/BEC
Servo: 9g x 6 Click Here
Requires:
6 Channel Transmitter and Receiver Click Here
3S 11.1V 1500mAh Lipoly Battery Click Here
Foam-safe glue
Features:
• Plug and Fly - Just install your own battery, transmitter and receiver
• Ultra durable blow molded plastic fuselage
• EPO foam molded wings and tail
• All servos, including flaps come pre-installed
• Easy removal canopy/battery hatch with pilot figure
• Powerful 4018 850kv brushless motor with folding propeller
Package Included:
1x Volantex ASW28 ASW-28 V2 Electric Sailplane EPO/Plastic 2540mm Wingspan PNP
Jun 15, 2019, 11:47 PM
shen13's Avatar
Anyone bought this plane?z
Jul 01, 2019, 09:19 AM
Which one ? i have the Saber on its way to me now.
Aug 11, 2019, 07:01 AM
Edit: Just did the maiden on my epoch, it does fly great especially on 4s, but I had some issues with shipping and stuff, package came pretty beat up with “received damaged” stickers on it, the wing was a little bent but it bent back. Also the prop was really out of balance and the adapter was slightly bent, so I removed the whole prop spinner and adapter and put my own on. The screws provided didn’t exactly match the instructions, so that was a little frustrating, but not a big deal they all worked once I figured out what was what. Also the wheels bind pretty bad, if you watch reviews you’ll notice almost everyone tips forward when trying to takeoff on even the lowest of grass, well that’s the wheels binding, I sprayed Teflon on them, got my drill out and just held it up to em to spin em for a couple minutes or so, loosened em up and they seem ok now. All stuff I can live with but just a little disappointing.
As far as flying, it’s really the best you can expect for a high wing plane, it flies inverted, on 4s it will do a barrel roll with just rudder, which is impressive, and even on 3s the aileron rolls are tight and it handles much like a low to mid wing plane would. In my experience is not easy to accomplish all this with a high wing, usually they like to stall and twist and dip and do all kinds of weird stuff when you try and roll but the characteristics of this plane are pretty ideal, especially since a dead stick will bring the plane level. Now I’m not a novice by any means, I just wanted a high wing plane that was predictable and easy to fly which I’m eventually going to use for fpv, and this plane really fit the bill, especially the price for the size. Oh and the plastic is awesome, the fuselage is the one thing you really don’t want breaking, and this feels nice and solid but flexible as well, some people call it milk jug plastic but it’s a little thicker and more rigid than a milk jug. It’s actually quite impressive power for only pulling 16a or so, so I’m assuming this is a very efficient little motor, so that’s a plus. If you’re a beginner 3s is a great start and gives this a little over a 1:1 thrust (meaning you can climb vertically) if you’re intermediate to advanced I’d definitely go with 4s, it’s much more fun and 3s is a little slow for how this plane can handle. I will probably be putting a bigger motor in this eventually, as well as a bigger esc, just cause it’s clear it’s capable of handling more power. And actually now that I think about it a 2216 should be capable of pulling much more than the 16a it does with this prop on 3s, so perhaps all I need to do is put a little bigger prop on with a larger esc, I have another 2216 same kv that will turn an 8060 prop on 3s, so that might be what I do with this.
Anyways just wanted to share my experience, probably not the best place to do it but I already had commented on here and just started rambling, if you’re thinking of buying this plane I would definitely recommend it as a trainer, especially because if it does happen to survive your learning (my first plane years ago didn’t) it will still be fun and useful even as an intermediate to advanced flyer.
Great plane, little rough around the edges but in the end it flies great and I’m happy.
Sep 13, 2019, 07:34 PM
Out Standing In The Field
RexGalore's Avatar
Hope you're plane showed up!
A friend of mine & I are thinking about ordering Sabers, but we're wondering if the wing has an airfoil, or is it flat?
The side views aren't enough for me to tell.
Thanx!
Discussion New Product: Volantex 759-3 Phoenix 2400 the_bunker Electric Sailplanes 259 Oct 15, 2019 07:59 AM
Discussion New Volantex V756-2 ??? jimjim06 3D Foamies 10 Jan 14, 2019 06:33 PM
Help! Need some help new prop on volantex Blade GravityZ Racing Boats - Electric 2 Mar 30, 2017 01:41 AM
Discussion New to FPV, Volantex Ranger EX, am I missing anything? mrienstra FPV Equipment 9 Jan 28, 2016 11:27 PM
