May 14, 2019, 11:47 PM
davereap's Avatar
A cable tie... drilled and cut to suitable lengths.. 1mm rod and 2mm holes..
May 15, 2019, 09:25 AM
Great tip thanks
Jun 06, 2019, 01:49 AM
davereap's Avatar
another tip for making vertical cuts.. used on fuz for butt joins..
I always get a slight angle when using a scalpel hand held cutting by eye
Jun 06, 2019, 02:55 AM
davereap's Avatar
My second model is a 3D Cub .. again inspired by multiplex's funny cub.. but made for crash and bash..
This one should be fully aerobatic and having a high wing it should be more stable than the Extra..
AUW on this is 235gms with a 450 2s lipo setup.
Jun 06, 2019, 03:02 AM
davereap's Avatar
The construction of all my models is easy..
Assemble the horizontal surfaces...
Hinge the elevator..
Butt join the vertical surfaces..NOTE.... align the rear rudder hinge line with the elevator hinge line..
I use UHU por for the joints , reinforcing them with a fillet of cool melt
Add strips to the top of the fuz on both sides for strengthening at the wing joint
Hinge/add the rudder..
Add triangular motor mount blocks with reinforcing..
Make the wing, adding the full length CF flat spar... hinge the ailerons
The wing is glued on top of the fuz.. and bracing struts are added below..
The paints are ready mixed water based from hobbycraft... these are not too bad on EPP... but not so good on depron..
Jun 06, 2019, 03:21 AM
davereap's Avatar
Specs...
Gartt 2204-1800... 8x4.3 prop..2s 450 nanotech.. 2x 1440 tgy servos and 2x 1601 tgy.. all 1440s would be fine.. its just what I had..
12A ESC and a 6ch REC....
All throws are maxed out ..but I have lower rates available on my switches..
servos on each aileron allow for flaperons ...
235gms AUWwith the bigger wheels
horus radio..
Jun 06, 2019, 03:41 AM
davereap's Avatar
I replaced the small wheels with some bigger ones to increase the angle of attack when on the ground
Jun 06, 2019, 03:59 AM
davereap's Avatar
more with the extra..last week.
extra 1 31may (2 min 49 sec)
slow and flat
extra 2 slow and flat 31may (4 min 21 sec)
Jun 09, 2019, 03:46 AM
davereap's Avatar
videos of the funky Cub maiden flights...
The model is not correct at the moment, I was trying to get flaps setup as well as the basic COG and trim...
However the flaps are giving problems , when they are "on" the model goes well out of trim, so I have obviously setup the programming on my Horus wrong...
Nothing exciting here, its gentle flying and slow flying.. more a record of the flights for later analysis
Funky Cub 1 june 2019 (4 min 52 sec)
Funky Cub 2 june 2019 (3 min 37 sec)
Jun 21, 2019, 01:31 AM
davereap's Avatar
After more longer evaluation flights...
The Extra is the preferred model.. smoother and neutral. nice and fully capable...
The Cub is a bit of a disappointment as an aerobat .... Its aerobatic performance is more troubled...
After any severe movements there is a wallow.. And its easy to give over corrections and loose a lot of control...
It flies best , in fact, very nice and smooth, when its just flown gently, which was not what I wanted..
The Cub would do better with reduced ailerons and elevator, and used as a trainer..
The flap trim problem was due to one of the aileron horns being fitted behind the hinge line, it should have been lined up correctly..
Jul 05, 2019, 12:56 AM
davereap's Avatar
getting better using the Extra... inverted and knife edge are so easy..
Jul 05, 2019, 04:07 AM
Danish? Don't U eat that??
DKChris's Avatar
Brilliant idea for utilizing what's essentially usually a waste product. Please do post this idea in the "homemade ideas for cheap and/or free" Thread
Discussion VA-Models Full Fuse EPP 41" Extra 330sc- Now Available at TwistedHobbys! Ethan Ater 3D Foamies 20 Apr 25, 2019 04:30 PM
News Multiplex Extra 330SC - Indoor Edition Jason Cole 3D Foamies 8 Jan 31, 2018 01:35 PM
Article Hacker Models Extra 330SC Full-Fuselage EPP Plane Review Spackles94 Sport Planes 86 Mar 29, 2013 09:13 AM
