This thread is privately moderated by Blaze0021, who may elect to delete unwanted replies.
Apr 28, 2019, 03:21 AM
Blaze0021's Avatar
Video
Freewing F-22 Raptor High Performance 4S 64mm EDF Jet - Fun Flight
In 1080p 60fps - Here is the raw uncut footage of my 1-year old Freewing F-22 Raptor High Performance 4S 64mm EDF Jet.
Freewing F-22 Raptor High Performance 4S 64mm EDF Jet - Fun Flight (4 min 26 sec)
Purchased about a year ago through Motion RC, this was my first Freewing 64mm EDF Jet. Prior to this I had only been flying Eflite UMX EDF Jets, so this Freewing 4S 64mm EDF Raptor was my "stepping stone" into the 64mm EDF class. Since then I've been flying a variety of EDF Jets from the 50-70mm EDF class. However, I somehow let a year go by without getting at least one flight video of my Freewing F-22 Raptor HP 4S 64mm EDF Jet.. until now.
A year late, but here's a fun flight video from this past weekend. Hope you enjoy the show!
----FLIGHT SETUP & MODIFICATION DETAILS----
Powered by a Pulse 4S 2250mAh 45C lipo, weighing in at 243 grams. The CG was measured at 88mm from the leading edge of the wing at the root. Weight without lipo installed is 837 grams. Flight Timer was set to 3:40 minutes. Flown with a Spektrum DX8 G2 Transmitter and using a Lemon RX LM033 DSMX 7-Channel Stabilizer / Receiver.
Modifications from stock were minimal:
1) A double spray coating of Minwax Satin Polycrylic Finish over the entire airframe.
2) A foam brush-applied coating of JB-Weld 5-Minute Clear Epoxy over the leading edge trim of the air intakes (to create a hardened reinforced surface against frontal landing abrasion), followed with Polycrylic over the epoxy-coated air intakes to match the overall shine.
3) The canopy piece has also been modified to remove the 5-gram stock pilot figure, in favor of an interior-spray painted "golden" canopy.
The rates I used were as follows:
Aileron: 85% with 30% Expo
Elevator: 85% with 25% Expo
Flight video footage taken with my Mike's iPhone X on 1080p 60fps. Thanks Mike for recording my flight! Better late than never.
Thanks for watching!
Help! Freewing F-22 Raptor 64mm EDF Jet petenewton Electric Ducted Fan Jet Talk 0 Jan 14, 2017 10:17 PM
Discussion Freewing Stinger High Performance 4S 64mm EDF Jet - PNP xrichierichx Foamy EDFs 12 Sep 16, 2016 03:42 AM
Discussion Freewing F-22 Raptor High Performance 4S 64mm EDF Jet strykerf27q Electric Plane Talk 1 Jan 10, 2016 07:11 PM
