Apr 26, 2019, 09:53 PM
geekbuying.com
GeekBuying's Avatar
New Product
JJRC X11 2K 5G WIFI FPV GPS Brushless Foldable RC Drone Quadcopter
JJRC X11 2K 5G WIFI FPV GPS Brushless Foldable RC Drone Quadcopter With Single-axis Gimbal Follow Me Mode RTF
Highlights
Ultrasonic
Ultrasonic sensor assists barometer to keep super stable altitude hold.
Follow Me Mode
The aircraft's camera will lock on your mobile phone when using this function, the aircraft will track you automatically and capture your movement with a particular aerial view. The camera lens will keep pointing at the mobile phone and remain constant distance to the mobile phone.
Point of Interest
Set a specific building, object or position as your point of interest. With the point of interest, your aircraft will continuously circle clockwise around the prest point. The point of interest is set at 10 meters to forward the aircraft by default. To change the point, please click "setting"-"Flight Radius" to reset.
Optical Flow Positioning
The built-in optical flow sensor that gets the real-time optical flow information and makes integrating computations.
Tap Fly
In the Waypoint Flight Mode, you can just focus on composing, B4W wll fly ot the target or fly in the direction your tapped on the screen, and change the flight paths smoothly if you're planed the track on the screen again.
4-in-1 Responsive Esc
The innovative 4-in-1 electronic speed controller makes racing aircraft more agile and more adept at sudden maneuvers including sharp turns and hard braking.
Powerful Brushless Motor
MT2204 1350KV brushless motor, the most cost brushless motor among the brushless motor lines. Maximum upward lift 230g.
LED Lights
The bright LED lights made night flying as easy as flying in the day. Your bugs 4W looks cool and attractive.
Specification
Aircraft
Wheelbase: 330mm
Quadcopter Size: 19.5 x 11.5 x 7cm (the arms folded)
45.2 x 41.5 x 7cm (the arms not folded)
Quadcopter Weight: 640g
Max. Ascent Speed: 3m/s
Max. Descent Speed: 2m/s
Max. Flight Speed: 40km/h
Max. Limit Height: 150m
Hovering Accuracy Range: Vertical 0.3m,Horizontal 0.3m(Indoor routine environment, within 3 meters height)
Vertical 0.5m,Horizontal 0.5m(Outdoor 3 meters above normal environment)
Remote Controller
Operating Frequency: 2.4G
R/C Distance: About 1.6km (Free interference and no occlusion)
Transmitter Battery: 1.5V 2 X AA(Not Included)
Using Time: About 12h
Camera
Camera: 2K 20fps
Photo Resolution: 2048 X 1152
Video Resolution: 2048 X 1152
Lens Angle: 110
Sensor: 1/3 CMOS
Aperture: F/2.4
Shooting Range: 1m to ∞
Shutter Speed: 1/30s - 1/10000s
Camera Adjustable Angle: -90- 0(Adjusted By Transmitter)
APP
Video Transmission System: 5G WiFi(802.11.ac)
Live View Quality: [email protected]
Mobile Device Holder: Max.5.5Inch Smartphones
Required Operating Systems: IOS 8.0 or later/Android 4.4.4 or later
FPV Distance: About 500m (Free interference and no occlusion)
Battery
Capacity: 3400mAh
Voltage: 7.6V
Battery Type: 2S Lipo
Battery Weight: 165g
Flying Time: About 20mins
Charging Time: About 4h
Ambient Temperature: 5 ~ 40
Charger
Input: 5V/2A
Output: 3.8V/2A
Operating Temperature Range: 5 ~ 40
Power System
Motor Type: Brushless
Motor Model: 2204 1400KV
ESC: 4in1 10A Brushless
Supported SD Cards
Supported SD Cards: Micro SD Card Class 10 And Above (Not included)
Max. Expansion: 32GB
Latest blog entry: Geekbuying Offers Free samples
Jul 02, 2019, 12:31 AM
Pro Bro # 2398
GassPasser's Avatar
Follow
Dec 27, 2019, 03:41 PM
JJRC X11 review - 2K 5G WIFI FPV GPS Brushless Foldable Quadcopter Drone.
Hi fellow rc pilots & rc enthusiasts
JJRC X11 review. This JJRC X11 review includes unboxing, features, functions, wifi & app requirements, photo & video samples, features & flight duration tests. It is best to watch this in 2048x1152 resolution.
You can get this JJRC X11 2K 5G WIFI FPV GPS Brushless Foldable RC Quadcopter Drone here: http://bit.ly/2QkDMsM with DISCOUNT CODE: 48M23HKI
Get this JJRC X11 2K 5G WIFI FPV GPS Brushless Foldable RC Quadcopter Drone with TWO BATTERIES using this DISCOUNT CODE: 48M2ACOR here: http://bit.ly/2QkDMsM
JJRC X11 review - 2K 5G WIFI FPV GPS Brushless Foldable Quadcopter Drone. (32 min 57 sec)
New Product JJRC H78G 5G WiFi FPV 1080P HD Camera GPS Foldable RC Quadcopter BGKevin Multirotor Drone Talk 7 Dec 27, 2018 05:38 AM
New Product JJRC X8 GPS 5G WiFi FPV with 1080P HD Camera RTF Brushless RC Quadcopter Drone review Bill M - RC Mini Multirotor Drones 0 Dec 15, 2018 08:56 AM
New Product NEW Visuo XS811 MOBLA GPS 5G WiFi FPV Foldable RC Quadcopter Drone Bill M - RC Mini Multirotor Drones 3 Nov 27, 2018 07:58 PM
