Apr 25, 2019, 05:03 AM
Quad Erat Demonstrandum
scousethief's Avatar
New Product
MinimumRC New Generation S.E.5A /Sopwith Camel 360mm Wingspan And other Micro's
This is were I started and it is were I will always return. This thread will just give a small glimpse into what is commonly available ( no hunting for one man shops in the Alpines for that ultra rare kit ) and were possible I will include links to the builds completed by members of the RCGroups community. Feel free to post your own links, builds or suggestions and I will happily update the main posts to reference your work.
To remove a little extra stress from the build process Microaces have all bases covered with the choice of available, reliable receivers and receiver-servo combo's that are perfect for not only their own line of highly detailed micro kits but are suitable for the majority of kits from Guillows, MinimumRC, Dumas etc etc.
Receivers : Spektrum , Futaba, Frsky D8
Servo's 1.5g Super Micro Servo: Click HERE
Receiver and Servo combo : Spektrum, Futaba, FrSky D8
Motor and Gearbox : Standard shaft, Extended Shaft.
It is only "fitting" to start with La Crème de la crème The MicroAces Airco DH.2
1915.
https://microaces.myshopify.com/coll...alan-wilkinson
The main Thread for the Microaces DH.2 is HERE and i will add links to other builds as i find them.
Specification:
Brand Name: Microaces
Item Name: DH.2
Type: KIT, KIT with motor(optional)
Wingspan: 340mm
Length: 320mm
Material: Laser cut 1mm Depron, Laser cut polypropylene sheet, Polyester decal sheet , 0.8mm Plywood parts.
Flying Weight: 34-36grams
Recommended Parts (Not Included):
Motor: 8.5x20mm brushed motor and gearbox Click Here
Servo: 1.5g *2 Click Here
Receiver: Micro 1s 3CH receiver, Spektrum, Futaba , FrSky D8
Battery: 1S 3.7V 130mAH
https://www.banggood.com/MinimumRC-Fokker-E3-420mm-Wingspan-Balsa-Wood-Laser-Cut-RC-Airplane-KIT-p-1150382.html
Specification:
Brand Name: MinimumRC
Item Name: Fokker E3
Wingspan: 420mm
Length: 380mm
Material: 1mm Balsa wood + 1mm laminate
Flying Weight: 25-30g
Package Weight: About 160g
Motor: 716 coreless, Click Here
Servo: 1.7g *2, Click Here
Receiver: Micro 1s 3CH receiver, Click Here
Transmitter: 2.4G 4CH, Click Here
Battery: 1S 3.7V 150mAH 1.25 JST
Build Instructions
1916.
https://www.banggood.com/Sopwith-Pup-Balsa-Wood-378mm-Wingspan-Biplane-Warbird-Aircraft-Kit-p-1102091.html
Description:
Brand Name: Sopwith Pup
Product Name: Balsa wood Aircraft Kit
Body length: 280MM
Material: balsa wood
Wingspan: 378MM
Flight weight: 42-50 grams
Center of gravity: 10-15mm below the leading edge of the lower wing
Use of the environment: indoor or outdoor windless weather
Equipment recommended: (Not included)
Battery: 150-200 mAh 1S Click Here
Servo: 2*1.7g servo Click Here
Radio: DSM2 transmitter/receiver Click Here
Motor: 7mm Coreless Motor Click Here
Build Instructions
https://www.banggood.com/custlink/m3v3JEJ0Ae
Description:
Item Name: Mini Camel Fighter
Material: Balsa wood
Wingspan: 380mm
Length: 250mm
Take-off Weight: 45g
Version: KIT, KIT with motor (optional)
Motor: 8502 coreless motor or 1104 brushless motor Click here
Propeller: GWS4540 propeller
Battery: 1S 3.7V 300mAh Click here
Receiver: Micro DSM2 Receiver, Click Here
Transmitter: DSM2 Transmitter, Click Here
Covering Film: Click Here
Note:
The KIT with motor version comes with a 8520 coreless motor and a 4530 propeller, other electronic devices are not included.
The KIT version does not included any electronic device.
English Manual, Click Here
https://www.banggood.com/custlink/vGvvpadfyf
MinimumRC New Generation S.E.5A 360mm Wingspan Foam Scale Biplane Zoom Mini RC Airplane KIT
Specification
Brand : MinimumRC
Model : New Generation S.E.5A Airplane
Wingspan : 360mm
Material : Foam
Motor : Coreless motor 8520
Recommanded Parts (not included)
Servo : 1.7g *2 click here
Battery : 3.7v 150mAh click here
Control Channel : 3ch click here
Package Included(KIT version doesn't include motor)
1 x MinimumRC New Generation S.E.5A 360mm Wingspan Foam Scale Biplane Zoom Mini RC Airplane KIT
1 x Coreless motor 8520
https://www.banggood.com/custlink/DmmvCohwrh
Specification
Model : Sopwith Camel RC Airplane
Wingspan : 380mm
Material : Foam
Motor : coreless motor 8520
Channel : 3CH
Recommanded Part(not included)
Servo : 1.7g servo *2 click here
Remote Conrol System : 3CH click here
Package Included (Kit version doesn't include motor)
1 x MinimumRC New Generation 380mm Sopwith Camel Kit
1 x coreless motor 8520
1918
https://www.banggood.com/MinimumRC-Fokker-Dr_I-350mm-Wingspan-Balsa-Wood-Triplane-Warbird-RC-Airplane-p-1184868.html
Desription:
Item Name: Fokker Dr.I
Material: 1mm Balsa Wood + 1mm Laminates
Wingspan: 350mm
Length: 380mm
Flying Weight: About 50g
Optional Model: Kit, Kit + Motor (Optional)
Recommended Parts Sold On Our Site (Not Included):
Motor: 8520 coreless motor, Click Here
ESC: 20A, Click Here
Servo: 1.7g *2 Click Here
Battery: 1s 150mah 25c LiPo
Charger: SkyRC balance charger, Click Here
Radio System: 2.4G 4CH, Click Here
Build instructions
Apr 25, 2019, 05:05 AM
1931
https://www.banggood.com/MinimumRC-Tiger-Moth-Biplane-400mm-Wingspan-Balsa-Wood-Laser-Cut-RC-Airplane-KIT-p-1142300.html
Specification:
Item Name: Tiger Moth
Wingspan: 400mm
Length: 360mm
Servo: 1.7g *2
Note:
The KIT verison doesn't include any electronic device.
The KIT with motor version comes with a 716 coreless motor and a 138mm propeller.
Please select the version you prefer.
Build Instructions
Apr 25, 2019, 05:28 AM
https://www.banggood.com/Mini-Zero-Fighter-435mm-Wingspan-Balsa-Wood-Laser-Cut-RC-Airplane-KIT-p-1209642.html
Specification:
Item Name: Mini Zero Fighter
Wingspan: 400mm
Take-off Weight: 48g
Recommended Parts For This KIT (Not Included):
Motor: 8.5mm coreless motor or 1104 brushless motor
Battery: 1S 3.7V 300mAh (Max)
Build Instructions
https://www.banggood.com/P51D-Mustang-400mm-Wingspan-Balsa-Wood-Laser-Cut-RC-Warbird-Airplane-KIT-p-1326095.html
P51D Mustang 400mm Wingspan Balsa Wood Laser Cut RC Warbird Airplane KIT
Description:
Item Name: P51D Mustang
Material: Balsa Wood
Wingspan: 400mm
Length: 365mm
Recommended Parts For P51D Mustang (Not Included):
Power System: 8520 coreless motor, Click Here
Servo: 1.7g Micro Servo *2, Click Here
Battery: 1S 3.7V 250mAh LiPo (Max), Click Here
Receiver: 4CH Micro Receiver, Click Here
Transmitter: 2.4G 4CH Transmitter, Click Here
Build Instructions
Apr 25, 2019, 05:29 AM
under construction
Apr 25, 2019, 05:32 AM
under construction
Apr 25, 2019, 05:33 AM
under construction
Apr 25, 2019, 05:34 AM
under construction
Apr 25, 2019, 05:35 AM
under construction
Apr 25, 2019, 05:36 AM
Under Construction
Under construction
Apr 25, 2019, 05:38 AM
Generic Balsa models
https://www.banggood.com/Mini-Cessna-182-435mm-Wingspan-Balsa-Wood-Laser-Cut-RC-Airplane-KIT-p-1209646.html
Specification:
Item Name: Mini Cessna 182
Wingspan: 435mm
Take-off Weight: 40g
Build Instructions
https://www.banggood.com/Keplar-K1-316mm-Wingspan-Mini-Balsa-Wood-Micro-Indoor-RC-Airplane-Model-p-1238486.html
Description:
Item name: Keplar K1 Mini Balsa Wood Model
Wingspan: 316mm
Fuselage Length: 282mm
Flying Weight: 25g
Model: Kit, Kit+ EPS7 brushless motor+5inch propeller (Optional)
https://www.banggood.com/MinimumRC-T34-460mm-Wingspan-Balsa-Wood-Laser-Cut-Mini-RC-Airplane-p-1280559.html
Specification:
Item Name: T34
Type: KIT, KIT with 8520 motor(optional)
Wingspan: 460mm
Length: 400mm
Flying Weight: 45g
Build Instructions
https://www.banggood.com/MinimumRC-CJ-6-450mm-Wingspan-Balsa-Wood-Laser-Cut-RC-Airplane-KIT-p-1177374.html
Description:
Item number: CJ-6
Wingspan: 450mm
Length: 400mm
Material: 1mm Baltar wood + 1mm laminates
Flight weight: 40 to 45 grams
Type: KIT, KIT with Power System (optional)
Build Instructions
https://www.banggood.com/MinimumRC-J3-Cub-460mm-Wingspan-Balsa-Wood-Laser-Cut-RC-Airplane-KIT-p-1290005.html
MinimumRC J3 Cub 460mm Wingspan Balsa Wood Laser Cut RC Airplane KIT
Build Instructions
https://www.banggood.com/MinimumRC-Cessna-L-19-460mm-Wingspan-Balsa-Wood-Laser-Cut-RC-Airplane-KIT-p-1210610.html
Specification:
Item Name: Cessna L-19
Wingspan: 460mm
Length: 400mm
Flying Weight: 35g
Build Instructions
https://www.banggood.com/MinimumRC-Beech-V35-460mm-Wingspan-Balsa-Wood-Laser-Cut-RC-Airplane-KIT-p-1333761.html
Description:
Item Name: Beech V35
Version: KIT, KIT + Motor (optional)
Material: 1mm Balsa Wood + 1mm layer board
Wingspan: 460mm
Length: 340mm
Flying Weight: 40g
Build Instructions
https://www.banggood.com/ZYO-6-Balsawood-Hand-Launch-Free-Flight-Glider-RC-Airplane-KIT-p-1122553.html
Build Instructions
https://www.banggood.com/TY-Model-3-3-370mm-Wingspan-Balsa-Wood-Laser-Cut-RC-Airplane-KIT-p-1143668.html
Build Instructions
https://www.banggood.com/TY-model-LX17-375mm-Wingspan-Balsa-Wood-Laser-Cut-RC-Airplane-KIT-p-1142726.html
Build Instructions
https://www.banggood.com/TY-Model-NO_7-292mm-Wingspan-Wood-Park-Flyer-RC-Airplane-KIT-p-1004972.html
Build Instructions
https://www.banggood.com/MinimumRC-Spacewalker-460mm-Wingspan-Balsa-Wood-Laser-Cut-RC-Airplane-KIT-p-1151157.html
Build Instructions
https://www.banggood.com/Flea-Balsawood-358MM-Wingspan-Micro-RC-Airplane-Newton-Kit-p-1120707.html
Build Instructions
https://www.banggood.com/TY-Model-NO_5-296mm-Wingspan-Wood-Park-Flyer-RC-Airplane-KIT-p-988832.html
Build Instructions
https://www.banggood.com/GEEBEE-Balsa-Wood-Laser-Cut-600mm-Wingspan-RC-Airplane-Building-Kit-p-1105390.html
https://www.banggood.com/custlink/vv3GC4Pm0f
TY Model Indoor Airplane Hummingbird Ultra Light Thin Film Carbon Rod Mini RC Aircraft 5.6g Only With Power System BNF
Description
Material : thin film,ABS
Wingspan : 224mm
Fuselage : 224mm
Weight : 5.6g (with 28mA LiPo)
Specification
Battery : 28mA LiPo(28-50mAh recommanded)
Playing Time : 5-8min
4CH electromagnetic rudder receiver(3CH for airplane)
Receiver protocol : DSM2 (remandand the Walkera D7e controler, not included)
Experience Level: Beginner to advanced
The gravity position is 40-45% backward of the leading edge of the wing
Pull-down angle of reduction gear is 6 degree.
Package Included
1 x MINI Indoor Airplane Kit
1 x 28mA LiPo Battery
1 x DSM2 Receiver
2 x Servo
Apr 25, 2019, 05:40 AM
Under construction
Apr 28, 2019, 12:20 PM
RNAF's Avatar
Why the heck are you posting the entire catalogue here at little added value? Are you trying to make money here?
Apr 28, 2019, 03:37 PM
I appreciate it because it's a link to the product page and the builders manual.
Apr 28, 2019, 04:50 PM
Because I buy these as do others and not everybody wants to spend time wading through the website which isn't exactly streamlined nor logical. A lot of these models are Much cheaper than buying locally or simply aren't available so I don't see what the problem is.
I could start a thread for every product or everytime I think of something or just because it's Sunday but I think there are enough manufacturers who do that as is.
These items are directly in line with the forum section and they are all kept to one thread. I will add the build manuals one I get back onto my PC and I will update the posts when more models become available keeping everything nice and tidy.
You would think that members were forced to read every thread under threat of decapitation rather than it being a choice.
New Product Eachine S.E.5a SE5a 378mm Wingspan Balsa Plane With Power System--------FREE REVIEW BGjim Micro Ready-to-Fly 231 Apr 25, 2020 10:25 AM
New Product J3-Cub MinimumRC Bankyard Flyer 360mm Wingspan RC Airplane KIT/PNP - KIT+Motor+Servos scousethief Banggood.com 1 Apr 23, 2019 12:59 PM
New Product MinimumRC F8F Rare Bear 360mm Wingspan KT Board Mini RC Airplane KIT With 720 Coreles scousethief Banggood.com 0 Sep 03, 2018 05:16 AM
Discussion balsa usa 1/4 scale sopwith f1 camel bsovermars Fuel Warbirds 0 Oct 14, 2015 03:37 PM
Discussion Cartoon Scale Sopwith Camel. New 8.5 inch wingspan version with machine gun lights. Joe Malinchak Scratchbuilt Indoor and Micro Models 21 Oct 22, 2012 05:49 PM
