This thread is privately moderated by Carmen Chen, who may elect to delete unwanted replies.
Apr 25, 2019, 05:02 AM
New Product
Flytec V500 Upgrade Version of 2011-5 Bait Fishing RC Boat with Full Scale Controller
Flytec V500 500M Control Distance Upgrade Version of 2011-5 Bait Fishing RC Boat with Full Scale Controller
The upgraded version of the 2011-5 bait fishing baot is equipped with a full-scale gun remote controller, full-scale throttle and full-scale steering functions, the bait fishing boat is more flexible and convenient to control. 2.4GHz remote control frequency, remote control distance as high as 500 meters, less interference in water, remote control is more stable. This product is equipped with backpack, making it easier to carry around.
Specifications:
Remote controller: 2.4Ghz
Color: Black
Material: ABS & Electronic Part
Charge Time: 10-12 hours
Control Time: 2-24 hour
Control Distance: 500m
Speed: 5.4KM/H
Controller Battery: 4*1.5V AA Battery (Not Included)
Battery: 7.4V 52000MAH
Product Weight: 2060g
Product Size: 50*27*20cm
Product Selling Point:
1. ABS engineering material is molded from the main body of the hull
The boat body of the hull is made of ABS engineering material at one time.It has superior impact resistance and wear resistance, is not easy to wear, has strong scratch resistance, beautiful atmosphere, strong and stable, strong wind and wave resistance.
2. Large capacity rechargeable battery
The lithium battery is faster to charge and has a larger capacity. The battery is placed in the middle of the hull, which can achieve a good balance and stability, and has better performance (Note: 3S battery can be used)
3. Double motor hull Large load design
The hull adopts double motor design, two independent nests, which can be operated independently, with a load capacity of about 1.5 kg.
4. Realize the control without battery in the 500m range. The remote control signal is more stable.
Remote control can be realized without obstructing the environment of 500 meters, no longer bound by the line, free to enjoy the convenience of unlimited technology, and the signal is widely stable.
5. Waterproof grass double motor design
Powerful dual-motor design with waterproof cover design to prevent interference from propellers.
6. Double bait box design
It is especially important to control the fixed-point nesting in the vast fishing environment of the waters! With the open-position design, each bait box can be opened separately and baiting, with a large load!
7. Night light adopts strong blue light design
It can locate and discern the direction in the night flight and play a certain role in attracting fish.
8. Dedicated digital automatic frequency modulation device
The special circuit and the special digital automatic frequency modulation remote control device completely solve the problems of mutual interference when multiple ships are sailing, the remote control distance is near, and the ship is out of control. Simple operation, strong stability, infinitely variable speed, forward and backward push, flexible left and right turn!
9. Strong wind resistance
The design of the single streamline hull, the whole ship has been waterproofed, can effectively prevent all kinds of water leakage phenomenon, 3-4 winds often travel!
10. Strong endurance, low noise, low energy consumption, continuous sailing for 2 hours
11. Easy to carry. Handbag packaging configuration, easy to carry, easy to travel
Controller Selling Point:
1. Gun remote controller design
One-handed control, easy to control without difficulty
2.2.4 GHZ transmission
Anti-interference, remote control distance up to 500 meters
3. Three power supply methods
1.5V AA*4 dry battery / USB power port / Lithium battery socket (any lithium battery any interface form, as long as the battery size and interface size apply)
4. Controller low power warning
It is foreseen that the remote control will be safely driven back in advance when it is disconnected from the boat, effectively avoiding the loss of products or the need for salvage.
5. Throttle direction / steering direction can be switched
The throttle and steering control directions can be switched according to the user's usage habits, and the applicable crowd is wider.
6. Throttle sensitivity slight adjustment / steering slight adjustment
In the process of using, the ship's navigation will be affected by the on-site environment (water surface wave level, wind speed, etc.), and the fine-tuning key can be used to quickly and accurately adjust the navigation direction for the motor differential speed adjustment.
7. Forward and reverse and steering proportional shift
Different demand experience for achieving sailing speed.
Controller Function:
4-channel remote controller / proportional throttle / proportional steering / low battery warning / LED light / throttle direction switching / steering direction switching / throttle sensitivity slightly adjustment / steering slightly adjustment / steering speed adjustment / forward and backward speed adjustment / three battery charging methods
Product Function:
Forward/backward/left turn/right turn/throw bait/LED night fishing light/low power warning
Controller Charging:
1.Dry battery (1.5V AA*4 continuous use for about 1 hour)
2.Lithium battery (any plug and model can be used)
3.Emergency Android charging port (connected power bank / computer)
Package List:
Boat *1, Remote Controller *1, Charger *1, Boat battery *1 (installed in the cabin can not be removed),
Manual *1, Remote control Rod*2, Spare Accessory Kit*1 (screw*3, nut*2, hopper blade*2, propeller*2), HANDBAG*1 (Optional)
Get this awesome Fishing Boat: https://www.alibaba.com/product-deta...anage.0.0.333c 71d2Fkib6C
More RC Products: Please check: www.iRctoy.com
Get related video:
Flytec V500 RC fishing bait boat with latest full-scale controller,2011-5 bait boat upgrade version. (3 min 39 sec)
Last edited by Carmen Chen; May 16, 2019 at 10:44 PM. Reason: forget to shown in boldface
Apr 26, 2019, 07:31 PM
biomecanoid's Avatar
Will you be offering samples for review ? i am interested
Apr 29, 2019, 04:19 AM
Thanks for your interest, yes, we can offer the sample for review. Would you can kindly offer more information for you or your company? The first batch sample of this new arrival will be finished in the middle of the May.
New Product Flytec V500 50cm Fishing Bait RC Boat 500M Remote Fish Finder 5.4km/h Double Motor Merch Banggood.com 0 Apr 16, 2019 02:37 AM
Cool Flytec 2011-5 Intelligent Fishing Bait RC Boat with Double Motors GeekBuying Geekbuying.com 0 Apr 05, 2019 03:21 AM
Article Radio Controlled Fishing Bait Boat Jason Cole Dock Talk 45 Jan 07, 2019 01:48 AM
