Jun 04, 2019, 08:24 PM
all wood
Jun 07, 2019, 02:52 PM
attached horizontal stab and vertical stab -----
rudder and elevator temporary --
I plan on painting my model with Stits polyfiber paint system,
light sanding of all surfaces
paint all surfaces with Stits poly fiber FC900 sanding sealer , filler , hardener , primer , covering adheres better try it
sand all surfaces probably use mask , no fan , vacuum to pick up white powder
fiberglass on fuse next --- I will use 3/4 oz. fiberglass cloth and Minwax polycrylic ( 2 maybe 3 coats )
Solartex covering on wings and fuse (turtle deck and bottom of fuse ), rear fuse sides , etc
Heck just cover the whole plane
Jul 12, 2019, 02:51 PM
continue
Aug 23, 2019, 12:15 PM
1st assembled photo
Aug 23, 2019, 02:46 PM
Originally Posted by Williams RC
I’ve been looking at some of Hostetler’s planes. This gives a good insight on what the build is like.
Yes, indeed. I bought a set of plans for the Aeronca Champ when at the Toledo Show from Wendell and to date I haven't considered buying the kit because I had no idea how the builds went. It does look pretty much straight forward but there are always a few twists and turns.
As of now I'm not sure I'm going to go with it as I have realized the amount of building space required is beyond what I have available. I bought a Sig 1/4 Cub and considering selling it as it's an impractical size for my build /work shop. I just finished a Kadet Senior and I had trouble with the size of it.
Yes, by work shop is that small.
Discussion Hostetler's 30% PA-28 "Cherokee" Clint Dethrow Giant Scale Airplanes 73 May 09, 2018 03:29 PM
Discussion 33% Hostetler Decathlon. Powerplants. epoxyearl Giant Scale Airplanes 0 Jul 12, 2017 01:33 PM
Discussion Looking for somebody that built either of Hostetler Decathlons... ferincr Balsa Builders 4 Apr 19, 2017 01:08 PM
Discussion Super Cub vs Super Decathlon vs Giant Citabria cappaj1 Fuel Plane Talk 19 Nov 13, 2015 01:34 PM
Discussion 33 % Hostetler Decathlon. epoxyearl Giant Scale Airplanes 16 Aug 08, 2013 07:46 PM
