This thread is privately moderated by helisfreak, who may elect to delete unwanted replies.
Apr 24, 2019, 10:52 AM
Trader Rating: 56
Im flying... don't talk!
helisfreak's Avatar
$120.00 USD
Seller Pays Shipping
For Sale
FlySight View Optix HD FPV Goggles built-in AV,HDMI, DVR HD
Brand new in box never been open. 120.00 shipped within the USA.
Features -
Low Latency 1024x600 Display, with ‘No Blackout / Blue Screen’ if Video Signal gets low
Adjustable Lens Focus – Focal distance can be adjusted with simple dial on bottom of unit
Dual diversity receivers – Automatic switching to Antenna / Receiver with best reception for outstanding range. Also features auto scanning function for fast and easy channel searching!
Support AV and HDMI In – Use with an external receiver for long range, or simply enjoy a movie or playing a video game on your own private giant screen!
Supports AV and HDMI source DVR (HDMI DVR maximum input resolution supported is 1920*1080P @ 60HZ)
NTSC/PAL mode Auto Switching – No need to worry about what mode camera you are using, the ViewOptixHD auto-recognizes the format and displays the image properly!
Includes Standard 5.5mm Barrel Type connector, and Extensions for use with XT60 and Barrel type Power connectors
Specifications of the ViewOptix HD VOHD720 Head Mounted Display:
LCD –
Resolution 1024x600 – 7” Diagonal
Contrast 700:1
Brightness 350-380 cd/m2
Lens Focus Distance 50mm – 80mm (Adjustable)
Power –
Input: 7.4 VDC – 25.2 VDC (2S/3S/4S/5S/6S Li-Ion/Li-Po Compatible)
Current Draw – 15 Watts Max
Wireless RF System –
Frequency: 5.685ghz-5.945ghz (ISM Band)
40 Channel/Bands: A,B (Boscam),E,F (Fatshark),R (Raceband)
Sensitivity: -90dBm (±1dBm)
Antenna Port: 2 X RP-SMA, 50ohm
Diversity Type: Receiver / Antenna diversity Switching
TV System: NTSC/PAL (Auto)
Video output level: 1.0Vp-p Typical,75ohm
Audio output level: 1.0Vp-p Typical,10Kohm
DVR – Supports up to 128GB USB / SD Card Drive (FAT32 File System), 10 MB/s Recording Rate MPEG Compression 60FPS, .AVI Format (Auto Save when Power Off)
HDMI Input – Supports up to 1920x1080P 60HZ (HDMI 1.4a)
May 02, 2019, 01:36 PM
Trader Rating: 4
interested, would you take 100
Off Site 10% off store wide + chance to win FREE FlySight Optix HD Goggles GotHeliRC Aircraft - Electric - Multirotor (FS/W) 0 Dec 18, 2018 11:43 AM
Review Empire Hobby - Flysight ViewOptix HD Goggle - HDMI/DVR Jim T. Graham FPV Equipment 24 Nov 15, 2018 11:20 AM
Sold Skyzone SJ-V01 Glasses Goggles 7 Inch FPV Video 5.8G HD Headset HDMI Input Built-in Manchild FPV Equipment (FS/W) 1 Feb 06, 2017 03:35 PM
