This thread is privately moderated by xinte, who may elect to delete unwanted replies.
Apr 24, 2019, 02:47 AM
iFlight SucceX F4 TwinG Flight Controller + SucceX 50A ESC 2-6s BLHeli_32 Dshot1200 4
iFlight SucceX F4 TwinG Flight Controller + SucceX 50A ESC 2-6s BLHeli_32 Dshot1200 4-in-1 Flytower Flight Tower for FPV Racing Drone Quadcopter DIY Models
https://www.xt-xinte.com/iFlight-Suc...s-p583302.html
Specifications :
FC Specifications
MCU:STM32F405R6T6
IMU:Twins IC2689,Twins Gyros built-in(SPI)
Baro:BMP280
OSD:AT7456E
Blackbox:Blackbox logging device
5X Uarts(1 2 3 4 5)with build-in inversion
8X Dshot/Proshot/Oneshot output
8X individual ESC power/ signal pads
1X Group of Gnd/Vbat/M1/M2/M3/M4/Cur/TX
Smart audio & Tramp VTX protocol:YES(IRC Tramp)
WS2812 led Strip:YES
Beeper:YES
PDB Specifications
Input:2-6S(5-36V)
BEC:5V/3A cont
FC Firmware
Betaflight/INAV
Target:STM32F405
FC:IFRC/IFF4_TWIN_G(STM32F405)
Physical
Mounting:30.5*30.5mm,φ4mm with Grommets φ3mm
Dimensions:36*36mm
Weight:6.3g
SucceX 50A 2-6S BLHeli_32 Dshot1200 4-in-1 ESC
Features:
8 layers double-sided PCB board;
4oz 1.6mm thick power board(0.9mm copper ratio),better operating load capacity;
32bit FO51K86 MCU, 48mHz maximum clock speed;
TDK MLCC Low ESR ceramic capacitors;
Top grade NTMFS5C430NL MOSFET;
Rational layout, countersunk holes on extended solder pads to ensure PCB layer connection
Specification:
Dimension: 43*39mm
Mounting Holes: 30.5*30.5mm/Φ3mm
Weight:14.4g
Supports 2-6S lipo input
STM32F051 MCU, 48Mhz Runs BLHELI 32.X Firmware
Current sensor: Yes
BEC: No
Supports: DShot DShot150/300/600/1200/MultiShot/ OneShot etc.
Target: iFlight-BL32-4IN1
RECOMMENDATION:
No additional capacitor needed up to 5S!
To encounter back EMF and ensure the longevity of your electronics, min. 220uF Cap 35V for 4-5S, 50V for 6S on your main lead!
Package included:
SucceX F4 TwinG FC+ SucceX 50A 2-6s BLHeli_32 Flytower
New Product iFlight SucceX F4 Mini Flight Controller 35A Blheli_32 2-6S ESC 5.8G 25/100/200mW Sma smg24 Banggood.com 7 May 15, 2019 07:07 PM
New Product iFlight SucceX F7 TwinG Plus F7 OSD Flight Controller & 50A BL_32 4in1 ESC Stack alex_nikiforov Banggood.com 0 Apr 07, 2019 08:55 AM
New Product iFlight SucceX 50A Plus BLheli_32 2-6S 4 in 1 Brushless ESC Support Telemetry for RC Merch Banggood.com 0 Apr 04, 2019 03:09 AM
New Product iFlight SucceX 50A Slick 2-6S BLHeli_32 Dshot1200 Single ESC with RGB LED Merch Banggood.com 0 Jan 22, 2019 03:48 PM
New Product iFlight SucceX 60A Plus 2-6S BLHeli_32 4 in 1 ESC Support Current Sensor Dshot1200 Merch Banggood.com 0 Dec 06, 2018 08:14 AM
