Apr 24, 2019, 01:40 PM
Retired CAD guy
birdofplay's Avatar
~20 oz for a bipe sound spretty good to me !
Apr 24, 2019, 04:55 PM
Out the Window
High Flyin''s Avatar
looks great so far.....following
Ray
Apr 24, 2019, 10:13 PM
Tony Audsley Retired Locksmith
Lockey's Avatar
Ray
Hey Ray, I have already started working on a foam fuselage, and would imagine it would save around 200 grams or so
Lockey
Apr 25, 2019, 06:19 AM
Lockey's Avatar
Bit more on the wings today
Lockey
Apr 25, 2019, 10:17 AM
Out the Window
Lockey
Great, thanks Lockey! I was even looking at a couple of internet sites that will generate truncated cones. Your plans for the Taube were so well done, everything went together so well and most importantly the Taube flew so well. So if I have a choice I will go with the Lockey plans if available!!
Ray
Apr 25, 2019, 08:48 PM
Lockey's Avatar
Ray
No probs mate, I will do a detailed build of the fuselage as soon as I have it finished, I have designed it to use 6mm Depron for the formers and 5mm Hobby King foam for the skin .. what will you be using for your build ?
I am making progress .. I have tried to keep the shape so the fuselage will be in 8 sections plus the hatch and will have a skeleton fuselage frame to slide the sections on to .. with only minimal sanding it should be a nice shape
Don't worry mate, rolling foam is REALLY easy so long as you tape the outer surface first with el-cheapo clear packaging tape AND get the grain running the correct way to roll .. I just put the tape on temporarily and remove it as soon as I have finished rolling
I didn't quite tape the wing far enough and forgot .. this was the result (it cracked) .. see last 2 pics .. I have had to repair it
Lockey
Apr 26, 2019, 09:07 AM
Out the Window
Lockey
I will probably use some Dow Protection Board III that I have on hand. I have had better luck with it than my other choice Dollar Tree Foam. It is the foam that I used for the Taube.
I just measured the Dow FFF with my caliper and it measures about 5.24 mm. It should work and with a some colored tape and MonoKote it makes a strong build. I sure wish I could get a couple of bundles more of it, but it is hard to find in the US.
Ray
Apr 26, 2019, 09:38 AM
Lockey's Avatar
Ray
That'll work Ray, you might just have make the slots a little narrower on the formers throughout the skeleton as they will be for 6mm Depron ... other than that, everything else will be the same
Lockey
Apr 26, 2019, 08:12 PM
Retired CAD guy
birdofplay's Avatar
Hey Tony, you're out of order here !
You did the Hybrid 1st, then you did the all foam version !
Well, maybe you can use the 3dP parts as a Forming Buck for the Bent foam parts !
Apr 27, 2019, 09:56 PM
Lockey's Avatar
I am going to finish the hybrid first Bob .. as you know, the fuselage is all finished and I have the wings and tail parts ready in a day or so (when I can get back into the workshop )
I will then cut out and make a foam fuselage and maybe it will be there if and when I crash the hybrid .. cos you know what happens to the plastic fuselage if you have a crash .. or even a very heavy landing ..
Lockey
Apr 29, 2019, 05:26 PM
Retired CAD guy
birdofplay's Avatar
That looks nice, as usual.
Good choice on equipment too.
Nice LG mod. That ought to do ya some good service.
Good on ya !
Apr 29, 2019, 07:13 PM
Lockey's Avatar
Thanks Bob, I dint have any bigger wheels .. well ... not that would have looked right so I sat down last night and drew some up and printed them overnight and here they are ready this morning
Not sure how they will stand up to the job, I printed in PETG as I didn't have any soft filament for the tires ( I have ordered some black from HK )
Lockey
Apr 29, 2019, 08:36 PM
When cows fly!
Looking good Lockey!
Build Log Peter Rake 44" Albatross DIII Prototype Build Brian Allen Scale Kit/Scratch Built 241 Apr 26, 2010 05:49 PM
Discussion Another Peter Rake Albatross DIII Pete Thomas Scale Kit/Scratch Built 61 Jun 19, 2009 06:28 PM
Build Log 24" Albatross Diii... New Photos Added Toolbag Foamies (Scratchbuilt) 17 May 06, 2009 08:25 PM
Discussion Albatross DIII or DVa kostuk Scale Kit/Scratch Built 7 May 19, 2008 09:53 PM
E conversion of SE5 or Albatross DIII? mario alvarez Scale Kit/Scratch Built 2 Mar 18, 2005 02:39 PM
