Apr 22, 2019, 09:44 PM
joseph1266's Avatar
Question
Truck cutting out
I just ran my new stenton for the first time. It ran for about 30 seconds and cut out. I turned it off and back on. It cut out again. I can't figure it out. Any thoughts out there?
Thanks, Joe
Apr 22, 2019, 09:53 PM
The Mad Titan
DC1138's Avatar
Battery isn't charged?
Apr 22, 2019, 10:53 PM
joseph1266's Avatar
Yes, battery is charged. However, my 50c battery died. I am using a 20c battery. Would this have any effect? I am asking because I also had the same problem with an Team Associated car last year, but was running a 50c battery. The batteries are both 5000mah and 7.4v.
Apr 23, 2019, 07:49 AM
Did I make the A Main?
bill_delong's Avatar
double check the LVC setting... for example if you are running a 2S LiPo and the ESC has the LVC is set to 3S then it will shut off on 2S
Apr 23, 2019, 11:47 AM
joseph1266's Avatar
What is an LVC? How do I check it?
Apr 23, 2019, 12:20 PM
Here's the manual for the Senton:
https://www.arrma-rc.com/pdf/manuals...387_6S_BLX.pdf
Page 27 explains the LVC = Low Voltage Cutoff limitations and how to program the ESC, apparently it auto selects the voltage with a minimum requirement of 3S, 4S or 6S
Also states a minimum of 35C - 5000mAh pack too
This tells me that if you are using either 2S or 5S, then you will hit LVC unless you set the ESC into NiMh mode which disables LVC.
Be sure to read the following article if you decide to disable LVC so you fully understand the risks:
https://rogershobbycenter.com/lipoguide
Apr 23, 2019, 09:06 PM
joseph1266's Avatar
I was told I could run this on 2s by the distributor. Is the LVC that you are talking about the small button next to the power switch? Also I ordered a new 5000 mah battery yesterday. I guess I will start again when I receive it. I am really lost on this.
Thanks Joe
Apr 28, 2019, 08:31 AM
User Registered
RustyUs's Avatar
There is three versions of the Senton. Depending on the model, the ESC's low voltage cutoff setting may vary.
Which Senton do you have?
May 14, 2019, 07:13 PM
joseph1266's Avatar
Problem solved. Thanks all.
Discussion OSD cutting out on punch-outs...FC supply noise? x91qLt7 Micro Multirotor Drones 7 Jun 20, 2018 08:46 PM
Discussion 808 #18 recording for a few seconds then cutting out. ell198679 Aerial Photography 0 Feb 12, 2016 12:49 AM
Discussion video cutting out, need advise or help? ncampos976 FPV Talk 8 Jan 10, 2016 09:03 PM
Help! FPV cutting out Phantom12 FPV Equipment 5 Oct 11, 2015 09:34 AM
