This thread is privately moderated by reverse, who may elect to delete unwanted replies.
Apr 22, 2019, 12:14 PM
Data
Spektrum protocol
The Spektrum protocol puts out a packet of data every 11ms. The packet holds 7 channels.
In 22ms mode, that means there are 7 x 2 slots available, 14 channels total. The first 6 of each packet are channels 1-12, and the last slot is used for the X-Plus channels (which makes it very obvious why they are up to 88ms latency).
In 11ms mode, there are 4 channels that are sent every time, and the remaining 6 channels come in 3's. It sends out 4 channels + 3 channels, then the next packet has the same 4 channels + 3 different channels. 4 + 3 + 3 = 10 channels max in 11ms mode.
The DX18 generates its data as 12 channels + 8 channels, where channels 11 & 12 are the same as X+1/2.
The DX20 generates its data as 12 + 8 also, but channels 11 & 12 are configured independently.
This is what the "DX18 Compatibility Mode" option is for. It lets you pick 10+8 or 12+8 mode.
Because the iX12 can import files from either one, or from a lower end DX, it can generate either mode as well. It's important to understand what you are getting the configuration from to know how it will behave. If you import from a DX18 or lower, it will most likely be in DX18 Compatibility Mode, generating channels 1-10 normally and using X-Plus data for 11 & 12. If you import from a DX20, if it's in 20-channel mode then channels 1-12 will be as you expected. It is done this way because the purpose of importing a file from another type of radio is to make it so that the new radio controls the old model exactly the same way. You want your new radio to fly the plane the same way as the old radio, not change channel assignments on you.
Opalix didn't understand that part and assumed that the DX8 file he imported would automatically go into the 20-channel mode. It doesn't do that because a DX8 works in DX18-compatibility mode for channel generation (but you can't get there on the menu). He's got it all straight now (we've been working with him for several weeks through Product Support and PMs).
https://www.rcgroups.com/forums/show...ostcount=60541
Discussion Spektrum Remote Receiver Protocol Documentation AndyKunz DIY Electronics 14 Sep 11, 2017 06:25 PM
Discussion Spektrum Remote Receiver Protocol Documentation AndyKunz Radios 2 Nov 11, 2016 10:06 AM
Discussion Spektrum Protocol Implementation on Naze32 and Raspberry Pi frezik Multirotor Drone Electronics 2 Oct 18, 2015 10:48 AM
Discussion Spektrum Flight Log Protocol Fluffy Monster DIY Electronics 34 Apr 16, 2013 08:28 AM
