Apr 22, 2019, 08:57 AM
San Diego California
Build Log
DIY Submarine 2019 project
Submarine, it's a magic word make boys excited by the secret scent almost like a hideaway base in bushes. There are kinds of design concept from scale model of real war ship to autonomous submarine drone etc. and all of them are still excite grown up boy like me too.
Here are my DIY submarine design outline and priority.
1. A vessel controlled by RC transmitter ------ 27MHz frequency band
2. Insure recovery ------ positive buoyancy
3. Static diving ------- diving thruster
4. No compromise WTC ------ no through hole shaft or link
Waterproof components such as ESC, servo and motor need to be checked their reliabilities because those are seldom designed to be submerged.
And most important concept is "cheap as much as possible" so that you still can have good Sunday brunch with your sweetie.
Apr 22, 2019, 11:47 AM
Steps? What steps?
zozer's Avatar
The motor is no problem, a brushless outrunner can run fully submerged. Do not put the ESC outside the WTC! Three brass bolts through the WTC will conduct the electrons, bolt the motor and ESC wires to either end of the bolts. Servos may be more of a problem, few are sealed well enough to function fully submerged for extended periods. Make sure the servo wires are sealed where they pass through the WTC.
Apr 22, 2019, 12:02 PM
Thanks for inputs. These are the points I definitely have to consider beside the BL motor. I tried to make an easy maintenance motor (no ball bearings) so that it could be rinsed and dried after every run. No need to be greased or oiled. I also expect "viscous lubrication effect" by the water too.
Submersible motor trial No 1 (1 min 55 sec)
Apr 22, 2019, 12:44 PM
Child resistant ? WTC
1-7/8" x 8-7/8" WTC is fabricated.
Apr 22, 2019, 01:09 PM
Latitudes vs Attitudes
Bob Gaito's Avatar
Why reinvent the wheel-I use oregano and parmesan cheese containers...
Latest blog entry: Mark V Navy Seal SOC
Apr 22, 2019, 01:30 PM
Well, this is clear rational why I chosen these medicine containers especially these two are not same size.
Yes, the size did matter. I wanted have a just right size WTC I needed.
Apr 23, 2019, 06:44 AM
The thruster
Sure, I could use oregano and parmesan cheese containers but I still use these yellow transparent containers.
Ooooops.
I think I made a big mis-judgement. The outrunner motor is designed for in air usage and it has ribs for centrifugal air flow.
This causes cavitation at high rpm in water. I should notice it before hand. OK, I learned.
Submersible BL motor trial 2 (1 min 36 sec)
Apr 23, 2019, 10:17 PM
Sneak preview
I know some hate this junk but all look good to me so far.
Apr 24, 2019, 10:42 PM
Building of monocoque fuselage
Or I should call it hull ? The upper and lower are bolted by brass screws.
The Italian biscotti container has good transparency although I will paint it to be visible.
If you have a couple of prescription drug, cost nothing up to here.
Apr 25, 2019, 07:32 PM
Buoyancy test
Without all necessary wires, needs a little more float in nose but wires will make some difference.
Now, I'm waiting for the propellers I order by $4.17 a pair from Shenzhen, China.
Apr 26, 2019, 04:57 AM
Diving steampunk?
Her see through look is not bad at all.
BTW, every quarter of the body panels are detachable for maintenance.
Discussion DIY RC Submarine yellowsubmarine Submarines 6 Apr 04, 2019 03:10 PM
Build Log DIY diving plane submarine Old NEET Dock Talk 89 Mar 19, 2019 09:35 AM
Yippee! rc submarine project. bluefork Submarines 2 Dec 26, 2016 02:53 PM
Discussion Anthology's XL width Buggy Wheels (DIY Project) Anthology5251 Off-road Cars 2 Oct 18, 2015 11:43 PM
