Aug 23, 2019, 08:25 AM
Recreational Engineer
Tom Harper's Avatar
Name Plate
Made up a simple name plate to test the trophy shop idea. I chose a photographic process over engraving because it allows more design flexibility.
I gave then a plate of brass that I generally use and It kind of worked, but the image was a faint orange color. Normally they use thinner brass with a special coating. So that's what they did. The result is not bad - good resolution so I can layout a much smaller one. Since it's photographic it can be any shape and I can invert the image so the letters show as brass against a black background. I got 4 images on their plate for $8. I sheared them out and filed the edges.
I don't know how durable the image will be in the oily steam environment, Probably have to coat it with epoxy. For two bucks each they are not bad.
Aug 23, 2019, 09:32 AM
tghsmith's Avatar
looks great!!! shouldn't get to hot or oily on that side,, I would try a poly..
Aug 23, 2019, 09:40 AM
Tom Harper's Avatar
Good suggestion, probably something I can get in a spray can.
Nov 09, 2019, 09:36 AM
Tom Harper's Avatar
Second Engine
Completed a second engine using a cylinder and flywheel from the box I bought on Ebay. Made a stainless steel piston that is a bit longer than the original. The engine initially balked at running. I found the problem was with the tension spring touching the pivot screw. A little lathe work cleared it up and I changed the drawings for the future.
Running no load, on air, these engines are both slower than a stock heritage engine. I assume they have more friction due to closer tolerances and larger bearing surfaces. It will be interesting to see if there is any difference under load on steam.
Still working on the burner.
Video [CD] Why can't we remake the Saturn V Rocketdyne F1 engine? Ron van Sommeren Life, The Universe, and Politics 44 Jul 25, 2018 09:07 PM
Question I want to remake a lipo battery pack Chatenever Batteries and Chargers 13 Jun 23, 2017 09:56 AM
Discussion Fast-food fan Trump could remake healthy school lunches Boogie_ Life, The Universe, and Politics 6 Nov 16, 2016 09:41 AM
Careful! Movie Remakes Buran Life, The Universe, and Politics 9 Oct 31, 2016 04:24 PM
Discussion QAV250 remake Z303 FPV Racing 2 Feb 04, 2016 06:38 AM
