Apr 21, 2019, 07:36 AM
biomecanoid's Avatar
Build Log
EPP Airplane Glider Dragon from Bangggood
Hello,
I have just bought this little hand thrown glider in the shape of a dragon:
https://www.banggood.com/EPP-Airplan...r_warehouse=CN
The plane feels tough and flies straight when you throw it, i would like to mod it to twin tractor RC on 2s with 4 channels so i can use differential thrust as well. This little thing will be virtually indestructible and will help me better my flying skills
I am open to suggestions for suitable hardware and where to mount it.
I will update when there is any progress.
Apr 26, 2019, 07:00 AM
Some more photos of the "airplane"
I think i would like to use the F959 motor for the dragon plane:
https://www.banggood.com/WLToys-F959...l?rmmds=search
https://www.banggood.com/WLtoys-F959...l?rmmds=search
and probably this servos:
https://www.banggood.com/3_7g-Micro-...l?rmmds=search
ESC:
https://www.banggood.com/Hobbywing-E...r_warehouse=CN
Regarding batteries i have lots of F959 2s batteries that i can use
The problem is that i would prefer to make the plane a twin tractor than a pusher and plus i need counter-rotating props and i wanna use differential thrust.
Any of you guys know of any counter-rotating props that would fit that motor ? How do i attach the motor on the wings any "clever" way of doing it instead of going crazy with the hotglue? Also what servo do you recommend ? the ones i found are a bit too big i think, some goes with the ESC a bit too big
May 03, 2019, 08:02 AM
Hello Guys,
I think i found a suitable motor:
https://www.ebay.co.uk/itm/DC-5V-6V-...8AAOSwOjBZZH83
What do you think ?
May 03, 2019, 11:59 AM
jimjim06's Avatar
How heavy is it? As a glider, and does that include any balancing weight (Which can be removed)?
That motor is not so good, heavy and old design.
I would go for 2 of theese https://www.banggood.com/85x20mm-Mot...r_warehouse=CN or similar.
If they counterrotate will depend on how you supply them with current.
The dragon looks cool, but The Eagle looks more promising for conversion, bigger wing area and smaller deadweight body.
I want the Pterodactyl, but that seems to be unobtainable...
Tommy
May 03, 2019, 02:28 PM
I wanted the Pterodactyl too but it seemed too difficult to convert to RC. I liked the eagle aswell but the dragon seemed to be the easiest to convert .
If the dragon is successful as an RC plane i will buy the eagle as well.
I haven't weight the plane but one guy on banggood said its about 40 grams. Also it doesn't seem to have any weights i tried to "scan" the dragon under a light but the black foam doesn't help.
As far as motors are concerned i would prefer a 2s capable ones since i have lots of batteries from the WLtoys SkyKing ( I like my planes over powered ).
Do you have any 2s motors in mind ? also i will need 2 small ESC and of course props, servos and FlySky receiver. I don't like all in one bricks because if something breaks you throw away the whole thing.
It flies very straight if you throw it, but now that i added the rudder and the elevator its a bit tail heavy. The control surfaces are oversized for now but i can always trim them.
Any suggestions ?
May 03, 2019, 02:36 PM
Can we find CW and CCW props for this motor ?
https://www.banggood.com/WLToys-F959...r_warehouse=CN
May 04, 2019, 11:11 AM
Laminated the wing and the control surfaces
May 04, 2019, 01:16 PM
I think these props will do fine with the WLToys F959 motor :
https://www.banggood.com/56mm-CW-CCW...r_warehouse=CN
I need ESC and receiver now
May 04, 2019, 02:11 PM
What about this ESC ?
https://www.ebay.co.uk/itm/Speed-Bru...kAAOSw2CFctnGj
May 04, 2019, 04:30 PM
OK if i go the 1s route with this kind of motors :
https://www.ebay.co.uk/itm/Pair-DC-1...UAAOSwQaFatjOm
where do i find a micro 1s ESC ?
May 04, 2019, 06:06 PM
This looks promising:
https://www.amazon.co.uk/Aeroplane-S...s&sr=1-1-fkmr1
May 04, 2019, 06:18 PM
Micro Servos:
https://www.banggood.com/1-Pair-Gote...r_warehouse=CN
https://www.ebay.co.uk/itm/1Pcs-Gote...MAAOSwzppZ5xk2
May 04, 2019, 07:35 PM
Mini Receiver:
https://www.banggood.com/Flysky-FS2A...r_warehouse=CN
New Product Z51 660mm Wingspan 2.4G 2CH EPP DIY Glider RC Airplane RTF Built-in Gyro scousethief Banggood.com 0 Sep 03, 2018 05:23 AM
Discussion Techboy Mini Fox 2.4G 2CH 345mm Wingspan EPP 360 Degree Rotation RC Airplane Glider R scousethief Banggood.com 0 Jul 10, 2018 05:23 AM
Discussion Techboy Mini Bull 2.4G 3CH 345mm Wingspan EPP 360 Degree Rotation RC Airplane Glider scousethief Banggood.com 0 Jul 10, 2018 05:20 AM
New Product HF-i3 Standard Tail EPP Hand Throwing Glider Airplane 480mm ONLY $8.99 FREE DELIVERY cooperationRC Multirotor Drone Talk 0 Feb 13, 2017 01:41 AM
