Apr 19, 2019, 09:29 PM
toad007's Avatar
P-Zero fun
Here are two versions of my cranks for the P-0
These are for the .050 displacement making it a true 1/2a
One has a brg shield, benefit is it keeps blown brg parts from trashing the sleeve. Stuffs the case a bit more also
One has the web cleared. Better balance is the benefit Smoother run I think, not sure I dont have a way to determine vibration rates. ..yet
Just wondering what the folks that have these engines would prefer. These are just blanks, I havent cut the window yet or heat treated them. sorry about the blurry pic's
Apr 19, 2019, 09:59 PM
Nitro User
1/2A Nut's Avatar
Bearing shield would be my vote with the extra case fill.
Apr 20, 2019, 02:19 PM
toad007's Avatar
I'm getting "cranky" in my old age.
These are actually kind of fun to make this way.
You can get kind of the" jist" of how I am making these, Maybe these pic's can help some one that may want to try it some day
Please feel free to comment on how you might do it or have to do it. I like all the Ideas.
Apr 20, 2019, 02:46 PM
ffkiwi
Look good Toad-what steel are you using? I wonder-given what happened with the original OEM ones whether heat treating is actually an advantage in these sizes...?
ChrisM
'ffkiwi'
Apr 20, 2019, 02:47 PM
ffkiwi
ChrisM
'ffkiwi'
Apr 20, 2019, 02:50 PM
toad007's Avatar
I tried to anneal, then retreat the stock crank to a lower hardness, I still broke them on the test stand.
I have made these with 4140, and a few others, Heat treated them and had them ground. D2 is nice. Basically anything I can heat treat to 60+RC worked. I'll grind the brg surface hopefully in house this time . I hope I dont scrap a few in the process. I'm just goofin around here, Please suggest steels and such, Oh, the 5200 series of steels carbarized I think are the best, but damn they are hard to do, Too much scrap for me.
Apr 20, 2019, 03:07 PM
toad007's Avatar
Here are the bearings I am going to use for these. I hope they work. I have to remove the Shields still
Apr 20, 2019, 03:11 PM
Nitro User
1/2A Nut's Avatar
5-40 studs? I am down for two setup's Mel
I have two still in a shipping box never opened.
Another two with broke cranks two with your
other cranks both on outrigger hydro's and one
with Galbreath's sleeve fix with nelson plug head.
How easy do the bearings pop out little heat gun
action and wood dowl or such? Looks like only the
rear bearing needs replacing and bore out the case
a bit for the larger dia. crank.
Apr 20, 2019, 03:12 PM
toad007's Avatar
I don't dare say what steel I am trying here...Just in case so I dont recommend something that sucks (bad info) if these break, The first ones I did of this steel are all still un broken. I hate being embarrassed LOL
Apr 20, 2019, 03:13 PM
toad007's Avatar
I still have several tools to make to do the rest of the operations
I just wanna see how it goes for now and break a few on my own first...
I cant promise any yet.
Apr 20, 2019, 03:14 PM
toad007's Avatar
I'll post pictures as I go. It is kinda fun.
Apr 20, 2019, 03:47 PM
toad007's Avatar
I have a controlled hot plate, I set the temp for 240 F* sit the case on it, Then pick up the case and slap it gently on wood. the rear brg falls.
Just remember, every aluminum alloy loses temper above 312F* I dont dare take a case higher than 240. Just how I do it, It heats up from the back plate side, rarely getting even close to "too hot"
Apr 20, 2019, 03:51 PM
toad007's Avatar
I'm too lazy to make Nelson head buttons
Apr 20, 2019, 03:53 PM
toad007's Avatar
The Stock head button, re cut to set the deck height works great with the Turbo type plugs, I'm not going with Nelson head buttons. One less part to make from scratch
Apr 20, 2019, 04:20 PM
Nitro User
1/2A Nut's Avatar
I don't see any need for it the turbo heads work great.
Thank you for the bearing removal tip. I will certainly
will follow those recommendations.
What about a radial mount those short lugs suck for mounting to beams.
Discussion The Mirage 2000 is equipped with 'zero-zero' (zero speed,zero altitude) ejection seat rockyboy2 Life, The Universe, and Politics 14 Feb 01, 2019 09:11 PM
Build Log Picco P-Zero .85cc Rigger with Profi 1/2A Tuned Pipe 1/2A Nut Racing Boats - Internal Combustion 887 Sep 10, 2018 01:35 AM
Question Royal 1/2A P-51 & Zero Toysareforkids 1/2A Planes 8 Feb 13, 2016 05:50 PM
Texan Take Off Massacre & Zero Fun Wingbreaker Parkflyers 5 Dec 23, 2003 07:03 PM
Seriously Fun Models Zero PanzyPoof Foamies (Kits) 0 Sep 16, 2001 12:01 AM
