Apr 18, 2019, 06:49 PM
Banggood Lipo batteries
I ordered three batteries from Banggood. All three came charged. Two will not take a charge and one worked fine on recharge. Banggood is giving me grief on my order. GRRRRR
Apr 18, 2019, 07:05 PM
Could not figure out why the motor stopped in mid-flight. Swapped batteries and had the same issue. So came home and tried to figure out why. Went out again with battery number three. Worked fine. Just operator error in flying my plane
Came back to recharge them and found the problem two would not take a charge for two different reasons. The third that worked recharged fine.
Banggood is running me through the ringer to get replacements or a refund.
Apr 19, 2019, 12:46 AM
Bombs away! Err...landing
Ira NZ's Avatar
What do you mean "Would not take a charge?"
Apr 19, 2019, 04:15 AM
No Guts, No Glory
timmybeetle's Avatar
when you post it would be nice to ad more info
Hello
It would be nice if you ad more data in yours complained.
Brand, type etc.....
Charger you use
grts Hans
Apr 19, 2019, 09:22 AM
I use an IMAX b6 Charger. One said connection break. The other said battery cell connect voltage error
The batteries are from ZIP cell
Apr 19, 2019, 02:10 PM
No Guts, No Glory
3s 4s 2200-5000maH?
You said that one lipo works, you can charge it with this charger!
If yes, than one lipo should have a connection fault in main lead.
The other battery cell connect you should have a problem with balance connector, if you have a cell checker it should also faulted there too!
grts
ps some picture would be great also with your's claim at Banggoods
Apr 19, 2019, 02:36 PM
Ira NZ's Avatar
Yup, sounds worth doing some troubleshooting with a multimeter, check the actual voltage at the leads and the cell voltages via the balance connector.
Apr 23, 2019, 11:52 AM
It has been five days since I contacted Bang Good on my bad batteries. Still no response. I just sent my third follow up e-mail asking for new batteries or a refund.
Apr 24, 2019, 02:35 PM
No Guts, No Glory
no answers to our questions
Hi
would be nice if you could answer our questions, we are trying to help you with yours problem.
grts Hans
Apr 24, 2019, 05:36 PM
We are not men, we are DEVO 7e
xanuser's Avatar
Originally Posted by timmybeetle
Hi
grts Hans
no kidding. to be any help we need more information. (or is this thread just here to vent/rant?)
what voltage per cell where they charged to when you received them? what the lowest voltage per cell you've ever seen on them? what the maximum voltage difference between cells for each pack?
Apr 25, 2019, 10:27 AM
OkayThey are a three cell 11.1v 20c battery
I have no idea how they charged per cell they failed the first time I tried to charge them. The one good one that charged was three volts per cell for 12 total. The other two I can get zero reading on a tester or multi meter
Two failed right out of the box. The other worked I have not checked it to see how the voltalge dropped since I charged it
Apr 25, 2019, 03:27 PM
xanuser's Avatar
20c is very low for quads.
3.0 volts per cell is below safe lipo margins and caused damage to battery. also 3.0v on a 3-cell would be 9v, not 12.
Latest blog entry: MY notes/ Ascent 2"build notes
Apr 25, 2019, 07:02 PM
Okay starting to figure this out.
The battery I can charge. Cell 1 4.8 Cell 2 4.11 Cell 3 4.6
The batteries that will not charge (connection error) Cell 1 3.75 Cel 2 .35 cell 3 3.94
Battery 3 cell error Cell 1 4.8 Cel2 .48 Cell 3 3.77
Apr 25, 2019, 07:53 PM
Ira NZ's Avatar
There's something else going on there. What are the total voltages? The battery you can charge would probably have exploded and burned your house down that badly overcharged.
Apr 25, 2019, 09:03 PM
The battery I can charge is 12.4 total
The second total voltage is 4.7
And the third seems to be taking a charge this time. That one was 8.05 total voltage. I am charging at 1.3A and so far it has gone from 7.6 to 8.41 in about 15 min
The numbers on the batteries are 11.1v 20C and 1300mAh
New Product BangGood Free sample test—ISDT Battery Charger and Lipo Battery BGjim Batteries and Chargers 39 Mar 15, 2019 07:28 AM
Discussion Lipo Batteries From Banggood!!! Helio Marques Batteries and Chargers 1 Nov 01, 2017 05:41 AM
Discussion SY60 Connectors on Banggood Infinity 1300mah 14.8V 90C 4S1P Race Spec Lipo Battery hulksdaddy Multirotor Drone Power Systems 6 Jul 07, 2017 10:19 AM
Discussion No more Lipo batteries from Banggood ewoodcox Banggood.com 60 Mar 04, 2017 03:25 AM
