Apr 18, 2019, 04:28 AM
BG-Wilson's Avatar
Eachine Wizard X140HV— no roll of death issues
Regarding our newly released Eachine Wizard X140HV, there will be no more roll of death issues
Due to the previous situation of X220HV, many people have the same concerns about this x140hv. However, after our factory testers' debugging, this problem will not happen again And the X200 HV roll of death problem was caused by many players updating its firmware
The X140 HV is only three inches long, but supports 6S output,It would be a real little beast
Found it herehttps://www.eachine.com/Eachine-Wiza...TX-p-1458.html
X140 HV Specification
X140HV Frame Kit
Wheelbase: 140mm
Floor thickness: 3mm
Upper plate thickness: 1.5mm
Side panel thickness: 1.0mm
CNC Aviation Grade 6065 Custom Aluminum Column
1507/2500KV Brushless Motor
KV: 2500kv
Voltage: 2-6s
Weight: 17.7g (including line)
Output shaft length: 14mm
Maximum pulling force: single 740g (6S/3056 three-leaf paddle)
Maximum power: 480w
Number of slots: 9n12p
Mounting hole spacing: 12*12mm
Mounting hole specification: m2
Bearing: nsk
N52 NdFeB magnet
Recommended paddle: 3 inches
20A Brushless ESC
Continuous current: 20A
Peak current: 25A (10s)
Bec output: NO
Input voltage: 2 ~ 6 s
Main control chip: 48mhz efm8bb2
Firmware upgrade: support dshot600 /blheli _ S/Oneshot125
MOS: 3*3
MOS model: pe632ba 30v53a
Betaflight F4 Flight Controller
Main control chip: stm32f411
IMU: mpu6000 6-axis sensor
BEC: 5v/1a
Integrated OSD
PPM/DSM/IBUS/UAR sharing: UART1-RX
Installation size: 20*20
Weight: 3.0g
Support firmware: betaflight/cleanflight/inav
Support for programmable LED Sprit
Reserve buzzer interface
FOXEER Arrow MICRO PRO Camera
Image sensor: 1/3" Sony Super Had II CCD + NextChip 2040 DSP
Pixel: PAL: 976 (H) x 494 (V); NTSC: 768 (H) × 494 (V)
TV system: PAL
Resolution: 600TVL (color) 650TVL (black and white)
Synchronization: internal
Minimum illumination: 0.01lux
WDR: Support
OSD programming board: support
White point repair: support
DNR: 2D DNR
Camera title: support
Image adjustment: support
OSD: Edit Name, Power, Flight Time
Input power: 5-40V
Storage temperature: -40 C~60 C
Working temperature: -10C~50C
Power consumption: 70ma
Low pressure alarm: support
Default mode: def, vivative, sunny, cloudy, led tr, usr1
Size: 18.5*19mm (without bracket)
Weight: 5.3g (without bracket)
XF5805 /5.8G 40CH 25/100/200/300mw Switchable VTX
Support TBS SmartAudio
Transmitting power: 25/100/200/300mw adjustable in three steps
Frequency points: 40ch
Video format: full NTSC / PAL format
Input voltage: 7V ~ 26V
Power consumption: +12V/600MW, 260ma @
Size: 25 × 20 × 4mm
Weight: ≤ 3.2g (except antenna)
With copper tube mini antenna (ipex interface)
Tips: Before powering up, you must first install the antenna to avoid the possibility of burning the tuner.
Multi functional taillight module
Working voltage: 5v
Integrated programmable taillight / bb ring / light strip drive
RGB full color highlight WS2812b lamp beads *2
Integrated 80dBi buzzer
Integrated photon emission line driver
Weight: 3.5g
T3056c Propeller
Material: Imported pc
Installation aperture: 5MM
Center thickness: 6mm
Weight: 2.5g / only
Quantity: 4 pairs (8 pieces)
Color: transparent purple * 2 / transparent * 2
Recommended power supply
Recommended voltage: 3-6S
Recommended capacity: 450-750mah
Weight
Drone weight: 150g
Package Included:
1 x X140HV Frame Kit
1 x Atmosphere light strip
4 x 1507/2500KV Brushless Motor
1 x 4 In 1 20A Brushless ESC
1 x Betaflight F4 Flight Controller
1 x FOXEER Arrow MICRO PRO Camera
1 x XF5805 /5.8G 40CH 25/100/200/300mw Switchable VTX
1 x Multi functional taillight module
4 x T3056c Propeller (2xcw 2xccw)
Latest blog entry: Ways to contact me
Apr 18, 2019, 04:32 AM
BG-Wilson's Avatar
Reserve for X140 HV review
Apr 18, 2019, 04:48 AM
Fan of just about anything RC
SoloProFan's Avatar
Sounds good. Hope some reviews start appearing soon, to confirm this news.
Latest blog entry: For the love of the hobby!
Apr 18, 2019, 05:11 AM
Sumfear's Avatar
Apr 18, 2019, 06:40 AM
Quad Erat Demonstrandum
scousethief's Avatar
Needs reviewing
Apr 18, 2019, 10:05 AM
alex_nikiforov's Avatar
really supports batteries 6s 450mAh?
Interesting to try it.
Apr 18, 2019, 02:53 PM
Sumfear's Avatar
The problem is where to get them...
Apr 18, 2019, 09:49 PM
I would like to review it, you can see my other reviews here in my blog. Thanks
Apr 18, 2019, 09:50 PM
BG-Wilson's Avatar
Yes, we also hope to confirm it as soon as possible
Apr 18, 2019, 10:42 PM
R/C Superfan
aben71's Avatar
Interested
Apr 19, 2019, 03:29 AM
I make myself out of 2s or 3s batteries.
Apr 24, 2019, 12:11 AM
SoloProFan's Avatar
So samples are already on their way to reviewers, or are you still looking for "guinea pigs" to try it?
Apr 29, 2019, 09:46 PM
BG-Wilson's Avatar
Pre-sale arrival, looking for reviewer
Apr 30, 2019, 06:44 AM
I reviewed the Wizard TS215 a while ago (LINK), I can review this one as well if you want.
Regards
Mariano
Apr 30, 2019, 09:02 AM
SoloProFan's Avatar
Would be happy to review. Really into 3 inch FPV quads, and it's been ages since I got selected for testing any Eachine FPV stuff.
Discussion 3inch + 6S drone: Eachine Wizard X140HV Sumfear Micro Multirotor Drones 4 Apr 16, 2019 01:31 AM
Help! Death roll issues evilworm Multirotor Drone Electronics 25 Oct 12, 2017 01:08 PM
