This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Apr 18, 2019, 12:18 AM
old4570's Avatar
Mini-Review
Mini Surfer 800 ( Part 2 ) Motor / ESC install
Sent for review by Banggood.com
Motor ESC install
I had some alternative ESC's to chose from in the 10A to 12A range ..
Chosen was the MR RC 12A ESC , since it already had a connector on it .
Yes , the plan is to run a 2s battery with the 5x3x3 prop ..
With the ESC soldered up , I did a quick current check and the combo pulled some 5.5 amp ..
A) Motor pod .. I was very easily able to open it up .. This allowed me to tighten the motor mount screws .
I then proceeded to hotglue the motor mount into the pod and hot glue the pod shut .
B) Since I was playing with the hot glue , I hot glued the pod onto the wing ..
No issues here , and the wing fits to the fuse just fine .
C) The 12A ESC was zip tied to the wing and the cables routed through the hole to the inside of the wing .
The ESC should get plenty of air where it is . Seems to be a very neat install .
D) At this time I do not plan to run 3s , just in case anyone was wondering .
E) Next I need to watch some TV , give my back a rest .. Then I will solder up the Rx ...
This one from BG , simply my Fav 4ch Rx right now ...
Part 3 - Install the Rx
New Product Mini Surfer 800 800mm Wingspan EPP Aircraft Glider RC Airplane BGKevin FPV Aircraft 30 Jul 08, 2019 09:12 PM
New Product Mini Surfer 800 800mm Wingspan EPP Aircraft Glider RC Airplane Kit Merch Banggood.com 3 Mar 04, 2019 06:54 AM
New Product Mini Surfer 800 800mm Wingspan EPP Aircraft Glider RC Airplane PNP alex_nikiforov Banggood.com 0 Feb 23, 2019 04:33 AM
Alert Forsale: HET F20 with Wemotec Mini Fan Neu Motor 1110/1.5Y/3.2 and ESC installed Mike Parsons Atlanta Area RC 7 May 14, 2009 07:40 AM
