This thread is privately moderated by CGordon, who may elect to delete unwanted replies.
Apr 17, 2019, 07:07 PM
Teak/Balsa Experiment
I wanted to try a darker hardwood and much thinner balsa than the last experiment. This time it is 1/16" balsa with teak veneer. The strips were glued with yellow glue and pressed overnight to dry. The teak was surfaced down to just a few thousandths on each side.
Next, a strength/weight test. I cut a very narrow strip and a wider strip of balsa of about the same weight. The balsa was slightly heavier and slightly stiffer, but I'd say these were fairly matched. No question that the teak was doing the work of carrying the tension and compression loads nicely.
There's probably a geometry of teak/balsa which exceeds plain balsa, but hard to optimize at this tiny scale.
I love the look of teak and I could create a slab fuselage with this technique that would look really cool. Tail pieces too. And I've proven I can do this without a weight penalty (especially if factoring in a lack of covering material).
As always, fun experiments with little need to have a practical application.
Apr 20, 2019, 10:51 PM
Entropy is happening!
Jim.Thompson's Avatar
Pauwlonia.
I have been using Pauwlonia as a balsa substitute succesfully in recent builds.
I have sometimes used it with .6 mm Basswood ply facing.............also very good for facings etc.
I don't know if this relates to your Teak trials, but thought I should mention it.
Jim.
May 28, 2019, 07:39 PM
Jim, I missed your reply. I have some paulownia and have struggled a bit more than I thought to find an application for it. It came at a time when I was really realizing the advantages of dissimilar materials in a sandwich. It seemed it was too dense for the center but too weak for a skin. Paulownia as the middle with basswood must be very strong!
Sure is fun experimenting with various materials.
May 28, 2019, 08:00 PM
Spacewalker..........mostly Pauwlonia.
https://www.rcgroups.com/forums/show...e-build-thread
Discussion 3D Sick Full Fuse XA Balsa Experience Foamie Free Plan Dean Marshall Foamies (Scratchbuilt) 6 Jul 27, 2019 07:59 AM
Build Log Scratch build 1.2m balsa build-up Polyhedral Experiment hog2soar Hand Launch 3 Dec 12, 2017 04:52 PM
Build Log Starmax 90mm Kit Sheeting Airframe in Balsa Experiment PWJClub78 Foamy EDFs 104 Sep 19, 2017 01:56 PM
Experience with flat plate balsa wings ? ChrisP Modeling Science 4 Jun 24, 2002 07:43 AM
