Apr 17, 2019, 12:20 PM
Pushboat Tug build
After renovating the NAVIGATOR tug model and cleaning out the shop, I got my previous start on a pushboat tug off the shelf and decided to try finish it. It started out as a project two years ago with making a buck of the hull, laying up a mold and then molding the hull out of fiberglass. I added a little depth to the hull as the original tugs were shallow on draft and I figured I needed the additional displacement. Here are the beginnings of the build. jerryj98501
Apr 17, 2019, 01:29 PM
CaptCB's Avatar
That is a NICE looking hull!
Apr 17, 2019, 06:19 PM
pops52's Avatar
Very nice build you have going. Please continue to share your progress.
Apr 17, 2019, 09:48 PM
r/c ships and workboats
Going to be another nice project and a stunner for sure.
Apr 17, 2019, 11:18 PM
boat butcher
the goon's Avatar
Mark
Apr 18, 2019, 08:16 PM
Today I built the modifications to the house for the recess for pump room vent areas. Filled, sanded and primed basic assemblies. jerryj
Apr 23, 2019, 12:36 AM
I dug out the fiberglass deck and decided it did not represent the deck for this model so decided to go with a plywood deck with side rails installed on the upper edge of the hull. These rails were sawed from solid stock using a table saw. The rails were then installed with Gorilla Glue. The rub rails were then cut from wood dowel stock using a setup on the bandsaw. A spacer block and brass stock were clamped to the rear of the blade after setting the offset to get the half round stock. The rip fence was used as a reference surface. The brass stock kept the dowel from twisting. The ends of the rub rails were tapered using the K.I.S.S. principle (Keep it simple stupid.) on the belt sander with a reference plate. jerryj98501
Apr 23, 2019, 08:51 AM
Rmay's Avatar
Looking very nice. If you need other towboat pictures for detail shots or just inspiration I always enjoy Dick's Towboat Gallery:
https://www.towboatgallery.com/The_T...llery.php?mnu=
Apr 23, 2019, 11:32 AM
Thanks Rmay and all the others who have made comments. It is great working on my own boat again. jerryj98501
Apr 23, 2019, 11:52 PM
Built a basic stand for the model. Fit the deck to the hull and started working on raised deck on stern. Built the push knees with steps. Arranged parts to see what modifications I might have to do. jerryj98501
Apr 24, 2019, 06:54 AM
Lot of water; some gets thin
chum444's Avatar
Looks good Jerry
Apr 24, 2019, 10:34 AM
Mopar Musclecar fanatic
xx29l9's Avatar
I'm really liking the looks of this boat....well done!
Bob
Apr 25, 2019, 12:19 AM
Thanks for the comments, makes it easier to continue working on the model. Finished the rear raised deck by making a sliding plate so I could have access to the drives later. Laid out the push knee layout and cut it to final shape. Laid out for the cutouts for the superstructure and reinforcing braces. jerryj98501
Discussion Build thread for 3 mtr 99cc tug plane. Jim.Thompson Fuel Plane Talk 856 Dec 17, 2016 02:27 PM
Discussion Anine tug-model Building dlljmx Scale Boats 15 Nov 30, 2015 08:19 AM
Build Log Building a 1/72 canadian "Glen-class" tug from the 1/82 Lindberg Diesel Tug Lichtbote Scale Boats 85 Apr 14, 2015 04:52 PM
Discussion 1/96 SDM tug build - DMS tug "SEAHORSE TAIPAN" Deckie Scale Boats 7 Feb 01, 2013 10:54 PM
Build Log Springer Tug / Pushboat. tugboatjack Scale Boats 89 Jun 17, 2012 12:01 PM
