This thread is privately moderated by scousethief, who may elect to delete unwanted replies.
Apr 17, 2019, 06:53 AM
Quad Erat Demonstrandum
scousethief's Avatar
Mini-Review
SHRC H2 Locke 2K WIFI FPV RC Quadcopter Smart Follow Optical Flow Positioning Mode RT
http://tiny.cc/ksyu6y LINK
Rewriting the review as something happened in the original upload
Highlights
WiFi FPV
The WIFI enabled FPV camera is mounted on the drone, to broadcast the live video to the pilot on the ground.
2K Wide-angle Camera
This 2K HD wide-angle camera helps make more attractive and better recordings and clearer pictures,also with Gesture Taking Photo function.
The drone will automatically recognize objects of various sizes, and can dynmaically adjust the tracking parameters according tot eh type and speed of the object, making it easier to follow.
Smart Follow
H2 will automatically recognize objects of various sizes, and can dynamically adjust the tracking parameters according to the type and speed of the object, making it easier to follow.
Set-circle Fly
Press the one key set-circle button, the drone will fly 360°around the controller.
One Key Fly Away
H2 can make the drone fly backwards at the same time with one key fly away function, and shoot perfect visual video,so that you can easily experience the popular shooting mode, everything is as simple as this.
Flight Path
With the flight path multi-point route control technology, as long as a path is drawn on the real-time camera screen, the drone will fly at the current altitude along the designated route.
Battery Monitoring Fuction
Our intelligent algorithm can accurately calculate the battery capacity of H2,allowing users to view the remaining fly time in real time.
I will start with a picture showing a credit card for size reference. The H2 is nice and small, its about the same size as a 130mm racing quadcopter although it is aimed at a different corner of the market so the H2 has features that you wouldnt use on a Racer.
The H2 Locke arrives packaged in a convenient little zippered carry case. Everything you need can be carried with you.
A dual language instruction manual and a separate sheet with QR code for the app are in the case.
The included accessories are stored withing a netted pouch inside the case, included are a set of 4 prop guards a spare set of propellers and the USB charger. The USB charger means that this can be charged nearly anywhere that has a usb port, if you buy a cheap connector for your phone ( USB-C/Micro/Mini to Female USB on ebay usually $1/£1 ) you could use your phone to recharge the battery if your phone allows it.
The Mobile holder is a simple grip type holder.
A funky little Transmitter can be used to control the H2 Locke or you can choose to use your phones touch screen. In order to make the Transmitter more portable the H2 uses a thumb slide rather than a gimbal. The thumb slides feel like you are using a laptop track pad but one that has a button that you move around. A quick batteries worth of testing and i am more than happy that these thumb gimbals can control the quad easily. The rest of the H2's functions are operated via either a simple button press or via the app and your phones touch screen.
The rear of the transmitter has a clip for the Mobile Phone Mount, it is a simply slot-in clip but it holds your phone quite steadily. On the top of the transmitter are the two shoulder buttons for Tri-rates and a simply 180 degree turn.
The H2 is powered via a single cell 1000mah Lithium Ion proprietary battery. The charger is a small USB charger that fits into the carry case so a proprietary charger isnt too much of an issue. It is great news that they have chosen to use a LIon battery rather than a LiPo as LIon are generally safer and hold their charge better than LiPo batteries.
The H2 Locke itself, the frame size is approx 130mm and the motors are simple brushed motors and either 0716 or 0720 so spares and hot-Wind Upgrades are available from the usual sources. The stock props are nice and wide, much wider than i would typically use on a brushed 07** quadcopter.
On the top of the H2 is the on/off button and an indicator panel that lets you know the status of the Quadcopters battery and bind status.
The camera of the H2 is static meaning that the H2 must be facing whatever you want to film, it would be nice if the angle was adjustable.
A quick look at the insides, i cant get a better image without disassembly.
Underneath, a simple vent to allow airflow around the battery .
Again the credit card image for size reference.
LockeH2 (2 min 6 sec)
Discussion SHRC H2 Locke 2K WIFI FPV RC Quadcopter Smart Follow Optical Flow Positioning Mode GeekBuying Geekbuying.com 0 Mar 29, 2019 04:03 AM
New Product SG106 WiFi FPV With 1080P Wide Angle Camera Optical Flow Positioning RC Quadcopter alex_nikiforov Banggood.com 0 Jan 02, 2019 11:52 PM
New Product JYU Hornet 2 WIFI FPV with 4K HD Camera 3-Axis Gimbal Follow Me Mode RC Quadcopter RT GeekBuying Geekbuying.com 0 Mar 17, 2018 02:37 AM
Discussion Cheerson CX-OF Wifi FPV Optical Flow Dance Mode Mini Slefie RC Quadcopter BNF/RTF siriusflier Micro Multirotor Drones 22 Jan 25, 2018 12:49 AM
New Product Cheerson CX-OF Wifi FPV Optical Flow Dance Mode Mini Slefie RC Quadcopter BNF/RTF BGKevin Micro Multirotor Drones 17 Oct 05, 2017 10:30 AM
