This thread is privately moderated by scousethief, who may elect to delete unwanted replies.
Apr 16, 2019, 09:38 AM
Quad Erat Demonstrandum
scousethief's Avatar
New Product
Eachine Wizard X140HV 140mm 3 Inch 3-6S RC FPV Racing Drone PNP Betaflight F4 OSD FOX
https://www.banggood.com/custlink/3mDmrFg8Ej
Not sure on this one, looks like theyre using a Foxeer low resolution camera (PAL: 976 (H) x 494) which is a bit, well , meh, whatever. These low resolution cameras were passable in 2015 but its 2019 now and we still seem to be stuck with the same crappy low resolution cameras.
Eachine Wizard X140HV 140mm 3 Inch 3-6S RC FPV Racing Drone PNP Betaflight F4 OSD FOXEER Cam 25~300mW VTX
Item Specification
X140HV Frame Kit
Wheelbase: 140mm
Floor thickness: 3mm
Upper plate thickness: 1.5mm
Side panel thickness: 1.0mm
CNC Aviation Grade 6065 Custom Aluminum Column
1507/2500KV Brushless Motor
KV: 2500kv
Voltage: 2-6s
Weight: 17.7g (including line)
Output shaft length: 14mm
Maximum pulling force: single 740g (6S/3056 three-leaf paddle)
Maximum power: 480w
Number of slots: 9n12p
Mounting hole spacing: 12*12mm
Mounting hole specification: m2
Bearing: nsk
N52 NdFeB magnet
Recommended paddle: 3 inches
20A Brushless ESC
Continuous current: 20A
Peak current: 25A (10s)
Bec output: NO
Input voltage: 2 ~ 6 s
Main control chip: 48mhz efm8bb2
Firmware upgrade: support dshot600 /blheli _ S/Oneshot125
MOS: 3*3
MOS model: pe632ba 30v53a
Betaflight F4 Flight Controller
Main control chip: stm32f411
IMU: mpu6000 6-axis sensor
BEC: 5v/1a
Integrated OSD
PPM/DSM/IBUS/UAR sharing: UART1-RX
Installation size: 20*20
Weight: 3.0g
Support firmware: betaflight/cleanflight/inav
Support for programmable LED Sprit
Reserve buzzer interface
FOXEER Arrow MICRO PRO Camera
Image sensor: 1/3" Sony Super Had II CCD + NextChip 2040 DSP
Pixel: PAL: 976 (H) x 494 (V); NTSC: 768 (H) 494 (V)
TV system: PAL
Resolution: 600TVL (color) 650TVL (black and white)
Synchronization: internal
Minimum illumination: 0.01lux
WDR: Support
OSD programming board: support
White point repair: support
DNR: 2D DNR
Camera title: support
Image adjustment: support
OSD: Edit Name, Power, Flight Time
Input power: 5-40V
Storage temperature: -40 C~60 C
Working temperature: -10C~50C
Power consumption: 70ma
Low pressure alarm: support
Default mode: def, vivative, sunny, cloudy, led tr, usr1
Size: 18.5*19mm (without bracket)
Weight: 5.3g (without bracket)
XF5805 /5.8G 40CH 25/100/200/300mw Switchable VTX
Support TBS SmartAudio
Transmitting power: 25/100/200/300mw adjustable in three steps
Frequency points: 40ch
Video format: full NTSC / PAL format
Input voltage: 7V ~ 26V
Power consumption: +12V/600MW, 260ma @
Size: 25 20 4mm
Weight: ≤ 3.2g (except antenna)
With copper tube mini antenna (ipex interface)
Tips: Before powering up, you must first install the antenna to avoid the possibility of burning the tuner.
Multi functional taillight module
Working voltage: 5v
Integrated programmable taillight / bb ring / light strip drive
RGB full color highlight WS2812b lamp beads *2
Integrated 80dBi buzzer
Integrated photon emission line driver
Weight: 3.5g
T3056c Propeller
Material: Imported pc
Installation aperture: 5MM
Center thickness: 6mm
Weight: 2.5g / only
Quantity: 4 pairs (8 pieces)
Color: transparent purple * 2 / transparent * 2
Recommended power supply
Recommended voltage: 3-6S
Recommended capacity: 450-750mah
Weight Drone weight: 150g
Package Included:
1 x X140HV Frame Kit
1 x Atmosphere light strip
4 x 1507/2500KV Brushless Motor
1 x 4 In 1 20A Brushless ESC
1 x Betaflight F4 Flight Controller
1 x FOXEER Arrow MICRO PRO Camera
1 x XF5805 /5.8G 40CH 25/100/200/300mw Switchable VTX
1 x Multi functional taillight module
4 x T3056c Propeller (2xcw 2xccw)
New Product sample test:Eachine Tyro79 140mm 3 Inch DIY Version FPV Racing RC Drone F4 OSD BG-Wilson Multirotor Drone Talk 26 Mar 02, 2019 11:44 AM
