This thread is privately moderated by smoothvirus, who may elect to delete unwanted replies.
Apr 15, 2019, 11:11 AM
smoothvirus's Avatar
Build Log
X-UAV Talon
Parts List:
X-UAV Talon EPO 1718mm Wingspan V-tail FPV Plane Aircraft Kit V3 $129.90
https://www.banggood.com/X-UAV-Talon...r_warehouse=CN
HobbyWing Flyfun 80A V5 ESC (3S-6S)$59.99
https://www.helidirect.com/index.php...6s-v5-esc.html
Cobra C-3520/14 Brushless Motor, Kv=700
http://innov8tivedesigns.com/cobra-c...s-motor-kv-700
Aeronaut CAM 13x10 folding prop
http://www.espritmodel.com/aeronaut-...denthaler.aspx
OSD AND AUTOPILOT FPV KIT
https://www.pitlab.com/pitlabshop/fp...it-detail.html
AIRSPEED SENSOR
https://www.pitlab.com/pitlabshop/fp...or-detail.html
Dragon Link Micro Receiver
http://fpvpro.com/micro-receiver
DragonLink 1.2 / 1.3 GHZ Video Transmitter Antenna - 1.5 Inch ( 4 CM ) Semi Rigid Coax Extension
http://fpvpro.com/12-13-ghz-video-tr...coax-extension
RMRC - LC Power Filter - 1.7A
https://www.readymaderc.com/store/in...oducts_id=4081
Heavy Duty Pan and Tilt
https://www.thingiverse.com/thing:1821872
Actobotics Flat Bearing Mount (3/8")
https://www.robotshop.com/en/actobot...-mount-38.html
25 TOOTH 0.375" X 1.00" SERVO SHAFT
https://www.servocity.com/375-x-1-servo-shaft
GWS 360 Degree Sail Winch Servo
https://www.readymaderc.com/products...il-winch-servo
Runcam Swift II - IR Block - NTSC Orange - 2.1MM
https://www.readymaderc.com/products...c-orange-2-1mm
Matek UBEC DUO, 4A/5~12V & 4A/5V
https://www.readymaderc.com/products...-esc-4a-12v-5v
EMAX ES08MA II 12g Mini Metal Gear Analog Servo [x2]
https://www.getfpv.com/emax-es08ma-i...-rc-model.html
Hitec HS-85MG Metal Gear Servo [x2]
https://www.readymaderc.com/products.../hitec-hs-85mg
Reference:
RCGroups thread:
https://www.rcgroups.com/forums/show...from-FPV-Model
X-UAV 2m Talon from FPV Model
https://www.itsqv.com/QVM/index.php?...from_FPV_Model
X-UAV Talon Build
https://www.rcgroups.com/forums/show...5#post30626027
FPV X-UAV Talon Build
https://www.rcgroups.com/forums/show...5#post26381880
Talon parts on Thingiverse
https://www.thingiverse.com/search?q...95cb9f7a5b3353
New more streamlined nose mount
https://www.rcgroups.com/forums/show...postcount=3896
http://www.itsqv.com/QVM/index.php?t...y_Pan_and_Tilt
Cobra C3520/14 Motor Propeller Data
http://www.innov8tivedesigns.com/ima...0-14_Specs.htm
XUAV Talon build overview (10 min 15 sec)
X-UAV Talon (FPV Platform) build (28 min 0 sec)
Pitlab setup video for a friend (57 min 25 sec)
Compare to:
My Fly Dream - My Twin Dream (MTD) - KIT
https://www.readymaderc.com/products...-dream-mtd-kit
May 15, 2019, 12:21 PM
People were asking me why I went out and bought a budget 3D printer.. check the image below, this is what you'll pay to have 3D parts printed now that 3DHubs changed their business model. I would have easily spent more than $100 just to get all the parts printed for this plane. That's more than halfway to the cost of a decent 3D printer where you can print them yourself for pennies. It probably cost me a couple of dollars worth of PLA plastic to print the nose module out.
Jun 16, 2019, 09:12 AM
The Build
Hoping to get this in the air this summer...
Mini-Review X-UAV Mini Talon from Banggood USA kross1 Foamies (Kits) 2 Aug 24, 2016 03:58 PM
