This thread is privately moderated by Merch, who may elect to delete unwanted replies.
Apr 15, 2019, 11:06 AM
Merch's Avatar
New Product
Happymodel Sailfly-X 105mm Crazybee F4 PRO 2-3S Micro FPV Racing Drone PNP BNF
https://www.banggood.com/Happymodel-Sailfly-X-105mm-Crazybee-F4-PRO-2-3S-Micro-FPV-Racing-Drone-PNP-BNF-w-25mW-VTX-700TVL-Camera-p-1453471.html
Processing time:Expected on May 14,I will pick one up soon as Pre-orders start for a full review
Happymodel Sailfly-X 105mm Crazybee F4 PRO 2-3S Micro FPV Racing Drone PNP BNF w/ 700TVL Camera
Specificaiton:
Brand Name: Happymodel
Model: Sailfly-X
Item Name: 105mm Crazybee F4 PRO 2-3S Micro FPV Racing Drone
Version: PNP ( Without Receiver) / Compatible Frsky RX /
Compatible Flysky RX / Compatible DSM2/DSMX RX ( Optional)
- Frsky version support both NON-EU and EU-LBT Frsky transmitter
(EU-LBT need to update firmware to Betaflight 4.0( release date :2019-4-11)
- Flysky version support both AFHDS and AFHDS-2A protocol transmitter
- DSM2/DSMX version support DSM2 and DSMX compatible Spektrum transmitter
- No RX version support external serial-bus receiver like xm+, crossfire, S-FHSS etc.
Wheelbase: 105mm
Size: 95mm*95mm*50mm(without propellers)
Weight: 35g(without battery)
Weight:60g(with Original 3s 300mah Lipo battery )
Crazybee F4 PRO Flight Controller
(Frsky version) CRAZYBEE F4FR PRO V2.1 Firmware target: CrazybeeF4FR
(Flysky version) CRAZYBEE F4FS PRO V2.1 Firmware target: CrazybeeF4FS
(DSM2/DSMX version) CRAZYBEE F4DX PRO V2.1 Firmware target: CrazybeeF4DX
(No RX version) CRAZYBEE F4 PRO V2.1 Firmware target: CrazybeeF4DX
MCU:STM32F411CEU6 (100MHZ, 512K FLASH)
Sensor: MPU-6000(SPI connection)
Board size: 28.5 * 28.5MM
Power supply: 2-3S battery input (DC 7.4-13V)
Built-in 5A(each) Blheli_S 4in1 ESC Dshot600 ready
Frsky version Built-in SPI Frsky receiver with telemetry(D8/D16 switchable)
Flysky version Built-in SPI Flysky receiver with telemetry(AFHDS/AFHDS2A switchable)
DSM2/X Version built-in Serial-based DSM2/DSMX compatible satellite receiver
No RX version need to add external Receiver
Built-in Betaflight OSD(SPI Control)
Built-in Current meter Max 28A
Current meter scale set to 1175
Built-in 5V 1A BEC with LC filter
Built-in voltage detection
EX1102 9000KV Motor
Mode: EX1102 KV9000
Configu-ration:9N12P
Stator Diamter:11mm
Stator Length:2mm
Shaft Diameter:Φ1mm
Motor Dimension(Dia.*Len):Φ13.5mm*16mm
Weight(g):2.8g
No.of Cells(Lipo):2S-3S
Onboard 5A 4in1 ESC
MCU upgraded to EFM8BB21
Power supply: 2-3S LiPo/LiPo HV (7.4v/13v)
Current: 5A continuous peak 6A (5 seconds)
Support BLHeliSuite programmable
Factory firmware: S_H_50_REV16_7.Hex
Default protocol: DSHOT600
Onboard Frsky Receiver Version
SPI BUS receiver
Frsky D8/D16 switchable
Compatible both Non EU and EU-LBT transmitter Channels: 8ch or 16ch
EU-LBT support(need to update betaflght v4.0 date 2019-04-11)
Failsafe support
No ground interference ( Transmitter and receiver 1 m from the ground): 300m
Onboard Flysky receiver Version
SPI BUS receiver
Protocol: AFHDS and AFHDS-2A Switchable
Channels: 8ch(AFHDS) or 14ch(AFHDS-2A)
Failsafe support
Onboard DSM2/DSMX receiver version
Serial bus receiver
Protocol: DSM2/DSMX compatible
Channels:6-9 (Depend on your radio)
PNP Version ( Without Receiver)
40CH 25mW VTX AIO 700TVL Camera
Output power: 25mw
Frequency: 40CH
Input voltage: 3.3V 5.5V
Current consumption: 300mA(type)
Camera resolution: 700TVL
Video Format: NTSC
Antenna: RG178 antenna
Frequency: 5.8GHz 5bands 40 channels
With Raceband
Smartaudio ready(Frsky EU-LBT and DSMX version not compatible)
Size: 13.9"12.0mm ( L*W )
Weight: 3.2g
Lipo Battery ( All Version have)
Capacity:300mAh
Voltage:11.4v
Continuous Discharge Rate: 30C
Instantaneous discharge rate: 60C
Weight: 25g
Connector: XT30
Features:
- Crazybee F4 PRO V2.1 AIO Flight controller 2-3s Lipo Compatible
- The lightest 1102 brushless motor only 2.7g with double ball bearings
- Light ,Powerful and smoothly
- AIO 5.8G 40CH 25mW VTX / 700tvl camera with smartaudio
- 2mm carbon fiber frame with TPU 3d-printed canopy
- Betaflight OSD support ,easy to get RSSI, Voltage ,current from your goggles(DSMX version no RSSI output)
- Full telemetry function ready (Frsky and Flysky version support)
- Compatible both for 2s-3s Lipo/LIHV
Package Included:
1x Sailfly-X FPV Racing Drone
1x 3D Printed 30 Degree Angle Canopy ( Red)
1x 3D Printed 40 Degree Angle Canopy ( Purple)
1x 3S 11.4v 300mah 30C/60C battery
1x Propeller disassemble tool
1x Screwdriver
Apr 16, 2019, 11:39 PM
Merch's Avatar
Happymodel New micro Beast FPV racer Drone ---Sailfly-X test footage (2 min 29 sec)
Discussion Happymodel Sailfly-X 105mm Crazybee F4 PRO 2-3S Micro FPV Racing Drone PNP BNF w/ 25m Merch Banggood.com 4 Apr 16, 2019 05:34 PM
New Product Supra7 Pro 75mm F4 OSD 2-3S Cinewhoop FPV Racing Drone PNP BNF w/ 200mW VTX CADDX Tur Frimen Micro Multirotor Drones 4 Apr 13, 2019 08:58 AM
New Product Supra7 Pro 75mm F4 OSD 2-3S Cinewhoop FPV Racing Drone PNP BNF w/ 200mW VTX CADDX Tur alex_nikiforov Banggood.com 0 Apr 12, 2019 06:16 AM
New Product Happymodel Mobula7 HD 2-3S 75mm Crazybee F4 Pro Whoop FPV Racing Drone PNP BNF BG-Wilson Banggood.com 0 Feb 22, 2019 01:38 AM
New Product Happymodel Mobula7 HD 2-3S 75mm Crazybee F4 Pro Whoop FPV Racing Drone PNP BNF w/ CAD alex_nikiforov Banggood.com 1 Feb 12, 2019 01:27 PM
