Apr 15, 2019, 08:58 AM
Boat thrust problem
I recently made a boat, bought part for it from AliExpress, cheap, and lucky as I was, all of them work. I got a 50cm plastic boat shell, and probably overpowering the thing with a 3650 3300kV motor running 2 or 3s. But the thing won't run on water, at low throttle it goes, but giving it any more than some 10-15% throttle and it starts bursting air instead of pushing that water, and it moves practically nowhere.
What did I do wrong? Is my prop too close, is it placed too shallow? Sitting in water it's wholly submerged, and half under the boat floor, the shaft angle is low as I can do, 15 cm long shaft, motor mounted 0,5cm off the floor, exiting at the back, level with bottom.
Apr 15, 2019, 02:38 PM
Just Plane Nutts
AirDOGGe's Avatar
Originally Posted by D_man97
...What did I do wrong? Is my prop too close, is it placed too shallow? Sitting in water it's wholly submerged, and half under the boat floor, the shaft angle is low as I can do, 15 cm long shaft, motor mounted 0,5cm off the floor, exiting at the back, level with bottom.
Photos of your build and phone-video of the boat in the water in (attempted) operation would go a long way towards finding out what is wrong and getting the useful help you need.
Also, this is the forum room for marine electronics and computer hobbyists. You'll find more help with this particular topic in "Fast Boats- Electric" or "Dock Talk".
Discussion Alligator tour boat crazy thrust doug14 Dock Talk 10 Jan 17, 2019 06:52 AM
Help! Mini throttle, max thrust problem Zgredd Multirotor Drone Power Systems 13 Jun 27, 2016 04:03 PM
Discussion WLToys WL911 boat problem, thrust cutting out randomly, please help. David Heggood Micro and Sub-Micro Boats 10 Dec 14, 2015 11:38 AM
Discussion problem with boats performance AK electric Racing Boats - Electric 5 Nov 13, 2015 07:09 PM
Discussion joysway silverline 26cc boat starting problem Freddyboy Racing Boats - Internal Combustion 11 Oct 30, 2015 09:07 AM
