This thread is privately moderated by Gary Chen, who may elect to delete unwanted replies.
Apr 15, 2019, 03:30 AM
Gary Chen's Avatar
FW-250 Fixed Wing VTOL Plane With 2 Hours Endurance
YANGDA FW250 Fixed-wing VTOL Plane (4 min 56 sec)
YANGDA FW-250 is a reliable and affordable VTOL fixed-wing plane designed for long-range inspection, survey, aerial photography, agriculture, search and rescue and public safety applications. As a fixed-wing UAV with VTOL and hover capabilities, the FW-250 features a modular airframe that can be set up in less than 10 minutes, does not require runway or catapult to get airborne. Once in the air, the aircraft transitions to horizontal flight as a push-prop fixed-wing.
Tool-free assembly
Due to its modular airframe design, FW-250 can be set up in less than 10 minutes by a single man.
Long flight time
FW-250 airframe is using light-weight and high strength composite material, which will enable the fixed-wing plane to fly up to 2 hours with 2KG payload, at an average cruising speed of 75KM/H.
Multiple camera options
These cameras are compatible with FW-250 VTOL aircraft: Sky Eye-U30 30X zoom camera, Eagle Eye-30IE-U 2-axis 30X EO/IR camera.
Specification
Wingspan: 2.5m
Fuselage: Composites
Frame Weight: 2.68kg
Total Weight: 5.5kg(without battery)
Max Take-off Weight: 12kg
Max Payload: 2kg
Flight Time: 2 hours with 2KG payload
Max Speed: 100km/h
Stall Speed: 15m/s-16m/s
Altitude: 3000m
RTF Combo
1 x YANGDA FW-250 VTOL fixed-wing airframe
4 x T-motor MN505 KV260
4 x T-motor FLAME 60A ESC
2 x T-motor 1654 CF Propeller CW&CCW
1 x T-motor 4120 KV250
1 x T-motor 12S 60A ESC
1 x 15x8 Wooden Propeller CW
4 x DS135MG Servo
1 x Px4 Air Speedometer
1 x ASSAN UBEC-8A
1 x Power Monitor Module
1 x Pixhawk 2.1 Standard Set with Here 2 GNSS
1 x YR16S Radio Controller
1 x Assembly and Flight Test Service
Options
Battery
1 x 18650 6S 35000mAh Li-ion Battery for cruising motor
2 x 6S 5000mAh Lipo Battery for lift motors
New Product Fixed wing VTOL plane FW250 charlesfang Yangda Security 0 Apr 11, 2019 11:23 PM
Discussion New long endurance VTOL more than 5 hours RaptorUAS UAV - Unmanned Aerial Vehicles 2 Jul 10, 2017 01:29 AM
Discussion RC AP plane with 96 hour endurance, can cary SLR(s) Arthur P. Aerial Photography 7 Jul 16, 2010 07:25 PM
