Feb 05, 2020, 09:49 AM
Size Matters!
RocketRob's Avatar
Originally Posted by dan berry
I would be interested in knowing what the aileron modification was supposed to accomplish.
That and the tail wheel.
Feb 05, 2020, 10:00 AM
Size Matters!
RocketRob's Avatar
Don, Sorry to hear about the accident - get well! The problem with being out of action is the grey matter doesn't stop and you brainstorm new projects!
I have an affection for this model. I am building a .020 size now for one of the small diesels. I have a large kit I thought would be a perfect home for a Taplin Twin, but alas It sits.......
Feb 05, 2020, 10:46 AM
Bayou_City_Boy
RocketRob,
I do not know why the previous owner did those. I am removing them. I might include a light tail wheel.
You should see all the drawings I did sitting in my recliner for 3 months!!!
Don
Feb 05, 2020, 10:48 AM
Size Matters!
RocketRob's Avatar
Two roughed out wing panels. Will keep design dihedral. Added a small carbon rod directly under the top wing spar for peace of mind!
Feb 05, 2020, 12:39 PM
Bayou_City_Boy
The diesel will look great on it.
Don
Latest blog entry: Recovery Update
Feb 06, 2020, 08:46 AM
Cox International now sells a 3D printed tankless backplate for the reedie Pee Wee engines that allows use of an external tank without the need for the stock tank to mount the engine. The future is brighter for Pee Wee flyers who need more runtime!
Feb 06, 2020, 10:23 AM
Bayou_City_Boy
I saw that.
A bit on the high side dollar wise.
But I bet'cha they sell a bunch of them!
Feb 20, 2020, 09:06 AM
Size Matters!
RocketRob's Avatar
Hey Don, Making any progress? I have my wing and tail feathers framed up and have to carve/sand them into an airplane shape. And two fuselage sides! Woo Hoo. Decided to put a .5cc - .030" Redfin Kompish diesel in it spinning a 6x4. The engine sits at quite an extended moment from the CG but hoping i can stuff the rx batts and or servos well aft.
Feb 20, 2020, 06:41 PM
Bayou_City_Boy
Working on getting all the mods removed. I was thinking a out buying one of the new 3D printed back played for my PeeWee .020. But since I have a Skycopter back plate I think I will save the $30 bucks for another project.
Feb 20, 2020, 07:05 PM
Hey rocket,
I hope you have a throttle on that Kompish. It will be a missile at full bore!
Or, running it decompressed can be fun, burping around the field.
Paul
Feb 20, 2020, 10:19 PM
Size Matters!
RocketRob's Avatar
Hey paul,
The kompish has a nice little carb but it runs so much better with the venturi.
Feb 20, 2020, 10:34 PM
They are cute little engines! I have a .15cc Russian Mills, and thought it might fly the 34"Quaker, if built light. I know an overpropped Pee Wee is ample power.
Feb 21, 2020, 09:27 AM
Size Matters!
RocketRob's Avatar
I have a .25cc russian mills but it won't pull the skin off the bread pudding as they say. Was not aware of a .15cc version.
Feb 21, 2020, 10:22 AM
My mistake. I should have written .015 cu in. Many guys have had problems with the little buggers, some even refusing to run. Guess I got lucky, mine runs very well. I flew a 20" all sheet model with 2 channels with it, but performance was marginal. It was a little heavy, though. I think a 34" Quaker could be built at about the same weight, and with the lighter wing loading, should fly very scale like.
Apologies for hijacking the thread somewhat.
Paul
Build Log Herb Clukey Quaker Flash-- 50in span dgliderguy Vintage & Old-Timer Designs 43 Nov 27, 2019 05:38 PM
Discussion Advise on correct angles on Quaker Flash. Super six Electric Plane Talk 1 Dec 17, 2016 04:45 PM
Discussion Quaker Flash - Spark Ignition apilgrim Vintage & Old-Timer Designs 8 Oct 08, 2016 04:35 PM
Build Log 50+ Build-off - Ben Buckle Quaker Flash SAslinky Vintage & Old-Timer Designs 84 Aug 28, 2016 07:53 PM
Discussion Quaker Flash Reginald Vintage & Old-Timer Designs 84 Apr 22, 2016 01:29 PM
