Apr 13, 2019, 04:32 PM
asr
asr
Build Log
EMB-120 Build
Hello group, I'm starting this build thread since there is none out there. The model is an Embraer 120 Brasilia. Got this laser cut short kit from eBay, seller is Ama Models.
I'm fairly new to electrics, so I welcome all suggestions and recommendations pertaining motors, ecs, batteries, and so on.
SPECS
98.5 in. wing span
99 in fuselage length
30 - 35 lbs. weight range
.60 - 1.20 nitro engine
I doubt/hope it will be less than 30-35lbs.
Will be using 2 .80 size brushless motors and JP hobby cnc retracts with brakes.
Apr 13, 2019, 07:54 PM
Nice subject, and at a nice size.
Electrics are the way to go for multi engines.
I’ll be following your build
Paul
Apr 14, 2019, 02:15 AM
Up-Out-&-Gone
demondriver's Avatar
Sweet EMB-120 Build ASR! Sub me up!
Latest blog entry: RC 737 Max 7 Maiden flight!
Apr 14, 2019, 03:43 PM
was geht , müssen unten kommen
Keenan smith's Avatar
Nice! i was Considering a turboprop build since i have the parts Laying around... Subbed
K
Apr 15, 2019, 10:38 AM
asr
asr
Not much going on today, I just ordered some carbon fiber hollow tubes that slide thru some of the fuselage bulkheads (expensive!!!)
Apr 23, 2019, 09:35 AM
asr
asr
These is the landing gear set I'm planning on using.
Still waiting on some missing laser cut parts from the seller.
Apr 23, 2019, 06:14 PM
Those look nice, where did you source them?
Paul
Apr 23, 2019, 08:41 PM
CatManDu's Avatar
Nice, neat size. Brings back memories! Thanks.
Randy
Apr 24, 2019, 06:52 AM
asr
asr
Paul
They're from JP Hobby
Apr 24, 2019, 04:36 PM
May 16, 2019, 08:32 PM
asr
asr
One month into the build, yes the table is a mess .
Now to start routing servo and light wires.
Jun 18, 2019, 06:00 PM
Howdy. Any updates? What's the sheeting material/process? Was considering using this as a base for an E145 model. Also asked the seller if he'd be willing/able to commission one based on this but I was sadly told that his "supplier" said no.
Also I see the plans are in spanish. I'm trying to track down which company actually designs and cuts these kits. If you have that info that would be great.
Jun 19, 2019, 04:10 PM
Also following
Jun 24, 2019, 09:19 PM
asr
asr
The company who sells the plans is casadabalsa.com, I got the kit from an eBay seller but it came with missing parts, so it was somewhat of an inconvenience trying to get the correct pieces. An E145 wouldn't be a problem but a new wing, tail feathers and a stretched fuselage will have to be made.
I will be using 1/8" balsa sheeting all over the structure and .75oz fiber cloth.
The plans show inacurate dimensions for the windshields and engine nacelles, so I will be correcting those, everything else seems fine scale wise.
Jun 26, 2019, 10:25 PM
Noted, appreciate the update.
Build Log Xavante EMB 326 JET - Build xandezendron Fuel Jet Talk 8 Mar 30, 2017 10:39 AM
Discussion test embed Azrak Test Forum 0 Nov 06, 2015 08:17 PM
Discussion EMB-120 Brasilia jdlilfan RC Airliners (Commercial, Cargo, Troop Carrier) 104 Oct 20, 2015 03:53 PM
Build Log Demon-Mini-Liners EMB-120 Brasilia! demondriver RC Airliners (Commercial, Cargo, Troop Carrier) 321 Feb 02, 2013 02:11 AM
