Apr 12, 2019, 03:00 PM
HSKRC Freestyle 250 - My dream build
This is gonna be my dream build log.
Iím gonna update the first post as it advances.
Right now, the frame and few other components have arrived and frame is assembled.
This is going to be very light freestyle build with lot of battery life.
Iíll be adding build video as soon as I get all the parts together. Still waiting for motors and VTX.
Current part list:
HSKRC Freestyle frame 118g
Foxeer Predator v3 8,7g
Immercionrc Tramp HV v2 4g
Bardwell F4 AIO FC v2 7g
Racerstar Metal 50A 4in1 ESC 16g (modified)
CLRACING Frame Arm LED board (racewire) x8 = 8g
iFlight Xing 2306 2450kv motors 28g each
Runcam Split Mini V2 12g
FrSky R9MM receiver 1g
Foxeer Lollipop Stubby Antenna 5g
Dalprop Cyclone T5046C props
Apr 18, 2019, 02:29 PM
Got the build started. This is gonna be pretty tight build 👌
Apr 20, 2019, 08:52 AM
Looking forward to this build.
Have fun
Poslano sa mog SM-N950F koristeći Tapatalk
Apr 20, 2019, 12:12 PM
First powering up.
Motors and receiver missing.
Everything good so far and video is working.
Apr 20, 2019, 12:27 PM
For some reason I cant see any pics?
Apr 20, 2019, 01:52 PM
Almost complete.
Missing one motor (backorder) and need to figure out how to attach the Runcam Split Mini 2... I guess I will make my own mount for it. I will be installing a switch to change between main FPV cam (Predator 3) and Runcam Split to be able to change runcam settings through onscreen menu. Also I will be connecting Runcam Split to one UART on flight controller to be able to start and stop recording via switch on FrSky X-Lite.
Weight is currently 306 grams without the Split Mini and 322 grams with. To add to that one motor 28g the
Total weight will be 350g with HD cam on board already without battery 👌
Apr 20, 2019, 01:56 PM
I have no clue about the issue?
Showing up fine here.
Apr 21, 2019, 09:18 AM
Runcam Split installed and all electronics coated with plastic spray (waterproof). Runcam Split connected to fc so I can control it with transmitter.
Iím going to install micro switch to change between Runcam and main Predator 3 fpv video feed to be able to see the runcam settings trough goggles aswell.
One motor still in backorder.
Apr 23, 2019, 01:54 PM
bootbox's Avatar
Looking good, really nice work on the build!
Apr 24, 2019, 03:00 PM
Thanks!
Apr 26, 2019, 07:21 AM
Finished.
Here are some photos of the quad before I go smashing it to trees ��
Microswitch is used to change between Predator v3 and Runcam split mini 2 fpv feed.
Total weight at ready to fly with battery S4 1550mAh = 569g
First hower:
New build - First hover (0 min 56 sec)
May 12, 2019, 09:18 AM
Maiden flight. Also first time testing 3D flying.
3D freestyle quad maiden flight (4 min 17 sec)
New Product Realacc Real3 250mm Frame / HSKRC Freestyle 250 - Very familiar frames... sevet Mini Multirotor Drones 2 Mar 25, 2018 03:30 AM
Discussion Diatone blade 250 CF build (my first build) Drtysx Multirotor Drone Talk 11 May 03, 2016 06:05 PM
