This thread is privately moderated by rhmoore0, who may elect to delete unwanted replies.
Apr 12, 2019, 01:02 PM
Question
First Drone Build--Help With Betaflight
Hi everybody,
This is my first quadcopter build, and I have been watching tutorials/reading posts everywhere to try and figure out some problems and do some trouble shooting.
Before I start, here's all my gear:
Omnibus F4V5 Flight controller
BlHeli 20A ESC's x 4
Tachyon t2207 2450KV motors
FlySky X6B receiver
FlySky FS-i6 transmitter
So, my problems are that when I'm on betaflight, motor 4 does not spin up. I've troubleshooted by getting a new ESC, detaching the motor from the ESC and putting it on a different ESC (it worked), and getting a new motor. Betaflight is just not picking up this fourth motor.
Also, betaflight is not picking up that the transmitter and receiver are talking to each other. The receiver is bound, connected to UART 6 (SBUS port for the F4V5), and fully powered up. I'm seeing on my transmitter also that the receiver is hooked up (I see the battery life), but no response on betaflight. I have another transmitter coming in the mail soon, so that's my last step of troubleshooting.
Any suggestions? Much obliged!!
Apr 13, 2019, 02:01 AM
Just some thoughts:
  • Any free UART can be used with a flysky receiver, there's no inversion problem for F4 boards like you have on a Frsky receiver. UART 6 will work fine (I think?), however. To emphasize, IBUS is "good"; it's the Frsky receivers that need to use particular UARTs or software inversion to work properly.
  • Flysky receivers use IBUS. (You'll find this on the Configuration tab, labeled "Serial receiver provider").
  • Make sure you're not hooked up to the PPM port on the X6B. (PPM is an older protocol. The X6B is basically a copy of a pretty old flysky receiver)
  • On the Ports tab, do you have "Serial Rx" turned on for UART 6?
  • As for the ESC's, not sure. You could try loading up the blheli configurator (rather than betaflight configurator) to see if it sees the ESC. Are you using DSHOT (configuration tab)? DSHOT does not need calibration. If these are older ESC's that don't support DSHOT, you'll typically have to do an ESC "calibration" in the betaflight configurator (youtube videos on this)
Apr 15, 2019, 09:19 PM
Antequam sciat ego nescibam
Watageek's Avatar
For the motor hook it to outpout 5 or 6 and remap resource.
In the cli type resource
Make sure you have the right target flashed.
Discussion First Quadcopter Build - Need Help - Betaflight - XM+ J Bat New Member Section 0 Nov 08, 2018 06:56 AM
Help! First Drone Build (Need Help With Parts) carter7868 Scratchbuilt Multirotor Drones 16 Sep 08, 2017 09:37 AM
Question Building first drone - Need inexpensive, easy to fly-help! not2worried Beginner Multirotor Drones 8 Oct 18, 2016 08:25 AM
Discussion My first racer a 250 FPV, $99us 2205 all clone build, need some help with betaflight zippiz Mini Multirotor Drones 42 Oct 02, 2016 08:05 PM
Discussion Want to build your first racing drone? We can help! gogodrone Vendor Talk 2 Aug 27, 2016 01:21 PM
