1/10 SCX10 II 4WD Rock Crawler Kit (AXI90075)
Axial introduces a 1/10 scale truck kit for experienced drivers that features the unrelenting SCX10 II chassis with an aggressive forward cab body. Trick out the kit to your personal specs and prevail on any trail!
Prevail on any trail!
Axial recreates the forward cab look in a body with many military-inspired scale features. It has a full-scale truck's aggressive approach and departure angles. Axial also includes military-style 1.9 MW19 bead lock wheels and 1.9 MT45 tires, as well as a functional spare tire.
The kit's off-road performance more than does justice to the vehicles that provide its all-terrain inspiration. Its tried-and-true SCX10™ transmission combines scale looks with the durability of all-metal internal gears. A full set of ball bearings is included. A 2-Speed Gear Set is available separately (Option Part AX31440), for builders who'd like to install a functional low/high-speed transmission — an additional servo for the shifting fork is also required.
Axial AXI90075 SCX10™ II UMG10™ 4WD Kit (2 min 34 sec)
Along with adding scale realism, the AR44™ single-piece axles feature a high-pinion design with a much lower gear ratio than most cars on the market, plus increased strength. It also avoids the torque twist often associated with smaller gear sets. And like the transmission and axle designs, the kit's chassis-mounted steering servo boosts its scale looks — while at the same time, supplying the correct steering geometry with virtually no bump steer.
Enjoy class-leading performance and forward cab realism with this latest Axial vehicle to take advantage of the proven SCX10 II chassis. Produced in kit form, it gives you the freedom to customize and add your preferred radio and electronics for a trailblazing machine that's all your own.
Features
  • Kit completion level gives experienced drivers the ability to customize the vehicle with their favorite equipment
  • New, realistic body design scaled after forward cab military style trucks
  • Plenty of locations for mounting LED lighting
  • Included options for customizing interior details
  • New rear cage hinged design allows easy access to interior components
  • Optional 2-speed gear set provides a functional low/high transmission when paired with optional servo
  • SCX10™ transmission mimics a real transmission and includes full ball bearings and metal gears
  • Chassis mounted servo for scale looks and close to zero bump steering
  • AR44™ single piece axle with high pinion gear set for a much lower gear ratio
  • New military-style MW19 bead lock wheels and MT45 tires, including a functional, mounted spare
  • All aluminum suspension links
  • Adjustable battery tray
  • WB8 HD Wildboar™ 3-piece driveshafts with an updated design and larger diameter
  • Waterproof receiver box
  • High strength, C-channel frame rail chassis
Learn More
For pricing and more info head to Horizon Hobby!
Apr 12, 2019, 11:51 AM
For 3hundred bucks that thing better be good out of the box
Apr 12, 2019, 07:49 PM
USA: LakeGeorge, New York
Traxxas TRX-4 Sport chassis with this body.
These scale crawlers are getting very nice!!!!
Latest blog entry: My FAVORITE FPV CockPits'!!!!
Apr 13, 2019, 02:05 PM
Panhead5496's Avatar
I can’t decide if I like the way it looks or not haha!
Apr 26, 2019, 11:04 PM
Then you either like Unimogs or you don’t
Rare to see real ones in the USA
Discussion HG P407 1/10 2.4G 4WD Rally Rc Car TOYATO Metal 4X 4 Pickup Truck Rock Crawler RTR To scousethief Banggood.com 0 Jun 08, 2018 06:58 AM
Discussion 1/10 Baseltek NXC 4WD Rock Crawler RTR...any good? Panhead5496 Rock Crawlers 9 May 21, 2018 04:05 AM
News 1/10 Night Crawler SE 4WD Rock Crawler Brushed RTR, Jim T. Graham Rock Crawlers 2 Feb 15, 2018 12:56 PM
Cool Original HSP 94180T2 1/10 4WD Electronic Powered Rock Crawler cooperationRC Rock Crawlers 0 Nov 05, 2016 01:57 AM
Discussion Tenshock Rock Crawler RC906 6 pole 1250kv Motor for 1/10 1/14 Crawler tf boy Rock Crawlers 0 Feb 14, 2016 04:44 AM
