Tiny Whoop Nano
The creator of the Tiny Whoop has joined forces with Team BlackSheep to create the Tiny Whoop Nano.
New 55mm Micro Drone from Tiny Whoop
The creator of the Tiny Whoop has joined forces with Team BlackSheep to create the Tiny Whoop Nano. The TWN is a 55mm micro drone that is turtle-able with brushed motors. Being even smaller than the original Tiny Whoop, it will feel like the world is huge and allow you to fly through gaps and spaces you never thought possible. Here's more from from the Tiny Whoop webpage.
55MM LIGHT-WEIGHT AIRFRAME
The airframe has been redesigned to be smaller, lighter (3.00g) and utilize no hardware whatsoever. Each duct has only three struts that are heavily reinforced where they attach to the duct or the motor mount. The motor mounts themselves are designed to be compatible with 0615 size motors, but a small plastic peg can be clipped out to make room for 0617 motors. Because the ducts of this airframe are closer together, the battery mount holds the battery on it’s side, which allows free flow of the air. Finally, just under the battery mount are two tiny loops. Jesse wanted these loops to encourage the community to innovate even more Tiny Whoop games.
TURTLE-ABLE BRUSHED FLIGHT CONTROLLER/RECEIVER COMBO
The new F3 flight controller is equipped with hardware that is capable of reversing brushed motors, allowing the aircraft to flip itself over if it lands upside down, making this the first brushed Whoop-style aircraft capable of turtle-ing in any direction. The Tiny Whoop Nano FC is running the newly released “TBS Harold” flight controller software, and is tuned for snappy execution of control commands.
TBS FPV SYSTEM WITH SMART AUDIO
The FPV system uses the TBS Tiny Camera, with 700TVL resolution and a redesigned camera form-factor to fit as low as possible to the airframe under the canopy. The VTX is the infamous TBS Unify Pro Nano, the world’s smallest FPV video transmitter with 25mW/50mW power levels and integrated Smart Audio, allowing the pilot to change video channels instantly using only their transmitter. The video transmitter’s stock antenna is a linear dipole on FPC substrate, which looks like a sticker on one of the rear ducts. It’s incredibly durable, and transmits beautiful, clear video.
THE SWEET SPOT BETWEEN SPEED AND CONTROL!
The stock motors are 0615 size brushed motors with a speed of 17,000kv, allowing for a high level of throttle resolution and altitude control for technical and tight Tiny Whooping, but can easily be upgraded to any higher-kv 0615 or 0617 brushed motors, making it an extremely light and powerful Tiny Whoop.
From the moment you first fly the Tiny Whoop Nano you’ll notice it feels a little different to be even smaller. You’ll appreciate all of the innovation that went into downsizing and redesigning the current standard in Whoop flight.
TECHNICAL SPECIFICATIONS
  • Size: 55mm Motor to Motor
  • Weight: 18g dry
  • VTX: TBS Unify Pro Nano 25mW 5.8GHz
  • FPV camera: 700TVL
  • Motors: 0615 17,000kV stock
  • Motor compatibility: 0615 - 0617
  • Receiver: FrSky D16 (XM-style)
  • Flight time: Up to 4 minutes per charge
  • Battery: 1S 260mAh TBS Graphene
  • Battery compatibility: up to 1S 300mAh
KIT CONTENTS
  • Tiny Whoop Nano BNF drone
  • 1S 260mAh TBS Graphene Battery
  • Spare Canopy
  • USB Charger with PowerWhoop Connector
  • Spare propellers TBS Whoop Propeller (random color!)
  • TINY WHOOP STICKERS!
Apr 11, 2019, 07:34 AM
If it's R/C, I LIKE IT!
Nikolei Zinsli's Avatar
Schweet!!
Latest blog entry: 93" AJ Laser 230z
Apr 18, 2019, 09:40 AM
FPV Ground Pounder
Gramps50's Avatar
Might have to add one of these to the collection
Discussion Tiny Nano Whoop Euwan Micro Multirotor Drones 29 Feb 02, 2020 09:24 PM
Video My first flight with the TINY WHOOP MOD !!! DaxFX Mini Multirotor Drones 3 Dec 12, 2017 06:06 PM
Discussion Blade Nano 3D FPV is Better than tiny whoop IMO tntburnett FPV Talk 3 Aug 03, 2016 12:53 PM
Discussion Blade Inductrix/tiny whoop or nano qx w/diy fpv?? King Theodin88 Micro Multirotor Drones 8 Jul 29, 2016 04:54 AM
