Apr 11, 2019, 05:38 AM
alex_nikiforov's Avatar
New Product
ZLRC Beast SG906 GPS 5G WIFI FPV With 4K Ultra clear Camera Brushless Selfie Foldable
ZLRC Beast SG906 GPS 5G WIFI FPV With 4K Ultra clear Camera Brushless Selfie Foldable RC Drone Quadcopter RTF
Description:
Item name: ZLRC SG906 Beast RC Brushless drone
Pressure sensor: Height setting
Frequency: 2.4Ghz
Camera: 120 wide angle camera (Adjustable camera by transmitter, 60)
Capacity of smart lithium battery: 7.4V 2800mAh
Remote battery: 4x15V "AA" battery
Motor: 1806 brushless motor
Drone battery: 11.1V 2500mAh
Flight time: About 23-25 mins
Charging time: About 5 hours
USB Charging: 5V
Control distance: 800m (Free interference and no occlusion)
5G Wifi image transmission distance: 350m (Free interference and no occlusion)
GPS follow me: About 30m
Image follow me: About 5m
Hand gesture shooting:1-3m
Color: Black/White (option)
Quadcopter size: 28.3x25.3x7cm (unfolded) 17.4x8.4x7cm(folded)
Flight weight: 527g
Takeoff weight: 527g
Aerial image configuration parameters 1080P 4K
Video resolution on Mobile Phone
(Front camera)
1920x1080p 2K: 2048x1080P
Video resolution on Memory Card
(Front camera)
Photo resolution
(Front camera)
1920x1080p 4K:4096P*3072P
(Down-looking camera) 1280*720p 1280*720p
Photo resolution
1280*720p 1280*720p
Frame rate
(Front camera)
20 fps 20 fps
Frame rate
50 fps 50 fps
Features:
-GPS returns to take-off point with low power and no signal.
-GPS Intelligent Following: 1.After the aircraft links the GPS, it opens the APP Following function, and the aircraft follows the mobile phone. 2.Image Following: Recognize the shooting object and follow the flight automatically.
-Gesture photography and recognition: within 1-3 m from the aircraft, make photographic gesture/photographic gesture in front of the camera.
-Route multi-point planning flight: the aircraft autonomously flies according to the pre-set route, the player concentrates on shooting.
-Fixed-point surround: Find the center of the surround, and then move the desired surround radius through the rocker.
-Track and recall the drone: Click on the GPS signal icon three times, open the map interface, the map shows the final distance of the aircraft, longitude and latitude position.
-Photo and Video Sharing: Photos can be shared singly or selectively, and videos can only be shared individually at a time.
Function: Foldable, One key start, One key landing, Altitude hold, Optical flow constant, Double camera, Wifi connect, APP control, Gesture photo, Gesture recording, Inteiiigent IPP Following, Following me mode, Palm Control(up down left right), Way Point Flight, Points of Interest, Speed Control, Real-time transmission, MV Image and Video Sharing, GPS return home.
Package Included:
1 x RC Quadcopter
1 x Remote Controller
1 x Remote joystick(pair)
1 x Screwdriver
1 x Body Batetry (option)
1 x USB Charger Cable
2 x Spare propeller (pair)
8 x Spare Screw(grain)
1 x Instruction Manual
Apr 29, 2019, 09:28 AM
No cable to phone? I worry not stable
May 16, 2019, 07:13 PM
Quad Erat Demonstrandum
scousethief's Avatar
It is fine. I have just begun my review, quite a good quadcopter for the price.
May 17, 2019, 02:53 AM
Hello, I would like to ask you what video latency do you have? For me it's up to 30 seconds and it's too much.
VID 20190517 072817 (5 min 48 sec)
May 19, 2019, 06:19 AM
Im working on finding the cause of the latency. Try turning the stabilisation off and record in SD which is 1080p ( HD settting is 4K ) It may reduce your latency a little, but from what i can tell after testing 6 phones the latency is a mix of poorly coded App, 5G WiFi limitations the camera and the phone ( which are struggling because of high bandwidth and recording 4K/1080p video at once )
May 30, 2019, 10:21 PM
Check out my response here: https://www.rcgroups.com/forums/show...5&postcount=90
New Product SJRC F11 GPS 5G Wifi FPV With 1080P Camera Brushless Selfie RC Drone - Free Reviewing BGKevin Multirotor Drone Talk 72 Jun 06, 2019 11:12 AM
New Product SIMTOO XT-175 Fairy Selfie Drone GPS 1080P HD Camera Foldable Wifi FPV Brushless RC Q scousethief Banggood.com 4 Nov 17, 2018 11:42 AM
New Product VISUO XS811 GPS 5G WiFi FPV with 720P Camera 14mins Flight Time Foldable RC Drone RTF Merch Banggood.com 1 Oct 28, 2018 08:37 PM
Discussion SJRC F11 GPS 5G Wifi FPV With 1080P Camera 25mins Flight Time Brushless Selfie RC Dro scousethief Banggood.com 0 Sep 22, 2018 06:38 AM
New Product SJRC F11 GPS 5G Wifi FPV 1080P Camera 25mins Flight Time Brushless Selfie RC Drone Rishi Banggood.com 0 Sep 22, 2018 01:39 AM
