This thread is privately moderated by CGordon, who may elect to delete unwanted replies.
Apr 10, 2019, 10:56 PM
Micro spar - balsa/basswood
I wanted to see if a small balsa square stick could be strengthened by a tiny amount of basswood on the outsides - much like a spar.
I glued thin (think veneer-like) strips to a balsa stick, and then I reduced the thickness of the finished glue-up the next day using my surface sander. I only left about .010" of basswood per side, which you can see along with the dark glue bands in the second photo. (Not the large balsa grain in the middle)
Results - this is much stiffer than plain balsa, but adds little weight. I went ahead and failed it, and predictably it failed in compression. The failure was much more friendly than the twig-like snap! you get from a balsa stick. If forces were coming from one direction, the optimum structure would have one side of basswood twice as thick as the other.
You could make a really strong truss with this material. It would also be good for tail construction, being both stiff and light.
Question Balsa Spars vs Hardwood Spars? dhable Vintage & Old-Timer Designs 10 Nov 15, 2017 04:09 PM
Discussion Basswood, balsa supplier Davey01 Slope 5 Oct 11, 2013 03:29 PM
Discussion Balsa vs Basswood - Planking Strips Tug Hercules Scale Boats 12 Sep 02, 2013 03:09 AM
Discussion Where to Order Balsa and Basswood? RC Man Balsa Builders 7 Dec 19, 2012 07:15 PM
Discussion Basswood for spars? drola The Builders Workshop 16 Sep 11, 2009 10:12 AM
