This thread is privately moderated by DutchRC, who may elect to delete unwanted replies.
Apr 09, 2019, 09:10 AM
my RC. Your info
DutchRC's Avatar
Esky Eagle 1100mm - Bush STOL Pusher Beginner FPV airplane :)
Halloa peoples!
sooooo! Another plane then.. I had personally been looking for a medium-size airplane with tricycle (so not a taildragger) landing-gear.. Preferable with a pusher-prop setup (no propellor in the FPV view)..
And! Along came this Esky Eagle It even has pretty big wheels so it can take off from gras
Link to the plane: Esky Eagle 1100mm beginner airplane
First video time then! In this video I'll do a quick unboxing but mostly a build (which won't be flawless :@)
Esky Eagle 1100mm - A different kind of Bush plane? UNBOXING + BUILD (36 min 3 sec)
Specifications:
wingspan: 1100mm
length: 871mm
weight: 755 grams all up
material: EPO foam
kit type: PNP
motor: 2306 2250kv brushless
propellor: 6x4 (my guess)
ESC: 30A
servo's: 4x 9 grams
receiver: 4 channel minimum (not supplied)
lipo: 2200mah 3S 20-35C (not supplied)
ailerons: yes
rudder: yes
flaps: nope
retracts: nope
lights: nope
Apr 12, 2019, 09:13 AM
my RC. Your info
DutchRC's Avatar
And.. time to see if this bird actually flies!
I have to add it was not only a Windy, but allso COLD day :|
Esky Eagle 1100mm - Trainer / FPV / Bush / STOL Airplane - MAIDEN FLIGHTS! :) (15 min 52 sec)
Apr 21, 2019, 09:06 AM
my RC. Your info
DutchRC's Avatar
Halloa people
soooo.. I set out to shoot a second flight-video with the plane to better show it's flight envelope.. There was however even More wind then previously :@ :P
Ohwww well! Some more flight testing with the Esky Eagle 1100mm
Esky Eagle 1100mm - Trainer / FPV / Bush Airplane - Flight Envelope Testing :) (19 min 4 sec)
May 15, 2019, 10:32 AM
my RC. Your info
DutchRC's Avatar
Et voila.. I used a Runcam micro Eagle + TX200U FPV set to FPV this airplane..
Here is how That worked out
Runcam micro EAGLE on the Esky EAGLE :D :D - Install - Test - Review (30 min 29 sec)
New Product ESKY Eagles 1100mm Wingspan EPO Trainer Beginner RC Airplane BGKevin FPV Aircraft 22 Jul 10, 2019 01:43 PM
Discussion ESKY Eagles 1100mm Wingspan EPO Trainer Beginner RC Airplane PNP Merch Banggood.com 9 Jun 07, 2019 06:43 PM
Discussion What is the fascination with bush/STOL planes ? BobHope Electric Plane Talk 142 Mar 08, 2019 04:08 PM
