Toledo News - Buddy RC iCharger X6 & X8 Chargers
The Junsi iCharger X6 & X8 are compact portable DC chargers that can output some serious power for your charging needs.
Compact High Output Chargers
Check out the X6 and X8 chargers at BuddyRC
X6
iCharger X6 is a new product Junsi launched in the summer of 2018. This palm size charger is packed with an unbelievable 800W power in such a compact dimensions, together with tons of features only seen in advanced chargers. The user interface inherits from those popular Duo iChargers, and is easy to navigate and understand. Buddy RC is a major iCharger distributor since 2009, our unparalleled service to iCharger users is well known in the community.
  • X6 supports up to 6s LiPo, Lilo, LiFe, LiHV, LTO, NiZn batteries, with maximum 2A balance current, and adopts a unique balance calculation of internal resistance correction. Supports 1 - 20s NiMH/NiCd batteries and 1 - 12s Pb batteries.
  • Intelligent fan control. Sensing internal temperature via the internal temperature sensor, to control the fan speed
  • Internal temperature protection. When the internal temperature exceeds the power reduce temperature, the output power is automatically reduced, and the charger will shut down when temperature exceeds the shut-down temperature
  • This charger can save 32 parameter settings and support the data import/export to SD Card.
  • A 2.4" IPS LCD Screen provides rich information including current, voltage, power, capacity, internal resistance, control status, time consuming and temperature, etc.
  • Multi discharge features: self discharge, regenerative to input discharge, and lithium battery extra expanding discharge
  • Supports measurement for internal resistance of battery offline and online. Can measure not only the internal resistance of the entire pack, but also measure the internal resistance of each cell within the lithium battery. .
  • The X6 has protection for reverse polarity, input or output,
  • Supports upgrading the hardware program by USB port or SD card. The X6 also supports the "junsi Console" Software and can display, plot and analyze the charge and discharge data by it.
  • Display: 2.4 " IPS LCD (320×240) Net weight: 168g Dimension: 83×64.5×37 ±0.5mm
  • Input voltage range: 7—32VDC Maximum input current limit: 2.0A
  • Price: $109
X8
The Junsi iCharger X8 Lilo/LiPo/Life/NiMH/NiCD DC Battery Charger features 8S capabilities and up to 1100W of power and up to 30 Amps of charge current.
  • X8 uses advanced Synchronous buck-boost DC/DC converter technology with high power, high current and high-performance power conversion circuit. The maximum charge power capacity is up to 1100W, the maximum charge/discharge current of a channel is up to 30A.
  • X8 Supports 8s LiPo, Lilo, LiFe, LiHV, LTO and NiZn batteries, with maximum 2A balance current, and adopts a unique balance calculation of internal resistance correction. Supports 1-25s NiMH/NiCd batteries and 1-15s Pb batteries.
  • With digital-power mode for great protection (over-current protection, over-voltage protection, input under-voltage protection, input undercurrent protection, and etc.)
  • Intelligent fan control. Sensing internal temperature via the internal temperature sensor, to thereby control the fan speed.
  • Internal temperature protection. When the internal temperature exceeds the Power Reduce temperature, the output power is automatically reduced; and the charger will shut down when temperature exceeds the Shut-down temperature.
  • This charger can save 32 parameters sets and support the data import/export to SD card.
  • A 2.4" IPS LCD screen provides rich information including current, voltage, power, capacity, internal resistance, control status, time-consuming and temperature, etc.
  • Multi-discharge features: self-discharge, regenerative to input discharge, and lithium battery extra expanding discharge.
  • Supports measurement for internal resistance of battery offline and online. Can measure not only the internal resistance of the entire battery pack, but also measure the internal resistance of each cell within the lithium battery.
  • X8 has protection for reversed polarity (input or output), input voltage/current, battery temperature, charging capacity, overrun time and maximum power etc.
  • Supports upgrading the hardware program by USB port or SD card. X8 also supports the “Junsi Console” software and can display, plot and analyze the charge and discharge data by it.
  • Net weight: 200g
  • Dimension: 97.5×64.5×37 ±0.5mm
  • Input voltage range: 9—49VDC
  • Maximum input current limit: <35A
  • Maximum charge/discharge current: 30A
  • Maximum charge power capacity: 1100W
  • Maximum discharge power capacity: 50W
  • Maximum regenerative discharge power capacity: 1100W
  • Maximum extra discharge power capacity: 1000W @33.5V/30A
  • Maximum current drain for balancing: >2.0A
  • Price: $129.99
New Product New iCharger X6 and X8 Has Been Released!!! junsi Batteries and Chargers 614 May 23, 2019 02:49 AM
News iCharger X6 800W 30A 6S Balance Battery Charger Jason Cole Batteries and Chargers 3 Jul 18, 2018 01:05 PM
Discussion iCharger X6 800W 30A DC LCD Touch Screen Smart Battery Balance Charger Discharger scousethief Banggood.com 0 Jun 21, 2018 07:05 AM
News Toledo News - Radical RC Cessna Retracts Jason Cole Electric Plane Talk 2 Apr 04, 2016 10:40 AM
News Toledo News - Buddy RC Jason Cole FPV Racing 2 Apr 13, 2015 06:07 AM
