Phoenix 2000 (V1) problem
Hi there,
Maybe someone with a good flying Phoenix 2000 can help me. I suspect the fuselage is deformed. Bend downwards. First I had to trim up a lot to make it fly straight and not dive all the time. CG is already further back than the markings, but finally I still had to raise the front of the wing with a layer of depron to raise its angle. Now it works but this canīt be right. I have attached a pic of the fuselage laid on a flat surface to make the curve visible. Might be a design decision but also a sign of a mistake during production. |
Is this the new version (with the wheel ) or the old version (no wheel)
Try asking here https://www.rcgroups.com/forums/show...G-Phoenix-2000 |
Thx, itīs the V1.
Mine flies very well, but I had to remove and discard the battery tray and set up a stick for the battery so that I can slide it back under the servos all the way to where it reaches the rear wing mounting screws, in order to get the CG where it needed to be. I have the CG at 3 and 3/8" (3.375 inches) behind the leading edge. The battery is actually behind the CG.
![]() By the way, my fuse curves the same way yours does. I don't think anything is wrong with yours. |
Thanx. As I suspected, this is 1,5cm (Europe here) behind the markings on the wing. But I have already been there, and still it was going nose down. But I did not test it since I did my tweaking on the fuselage.
Maybe someone reads that way later: It flies good now. The solution: slowly pour boiling water over the area and bend it straight. As I suspected, the fuselage was deformed, most likely due to failures while production. Things like that seem to happen with those fuselages more often.
Thread Tools | |
Similar Threads | |||||
Discussion | Still having electric problems with my hobbyking Phoenix 2000, Crashvideo | kyrkbymannen | Electric Sailplanes | 4 | Oct 28, 2020 02:37 PM |
Discussion | Hobby King Phoenix 2000 Stall Problem | tekochip | Electric Sailplanes | 7 | May 08, 2018 08:37 PM |
Discussion | Help me choose: HK Walrus, Phoenix 1600 or Phoenix 2000? | FOGeologist | Foamies (Kits) | 2 | Apr 11, 2017 01:18 PM |
Himax 2815/2000 and Phoenix 45 problem | Rugar | Power Systems | 3 | Nov 17, 2004 12:58 AM |
