Mar 29, 2019, 09:27 PM
Tips for finishing micro balsa planes
Hi All,
Planning to build micro planes out of balsa and powered by 1s lipo packs. Example like the micro kaos 1s -
https://outerzone.co.uk/plan_details.asp?ID=7732
What is the best finishing/painting method without adding too much weight?
Thanks.
Mar 30, 2019, 11:08 AM
cat herder
jimmycashley's Avatar
A really light coat of oil based polyurethane from a spray can, very carefully sand with 320 or 400, and then possibly some sharpie markers. As you obviously know, paint is heavy.
Mar 31, 2019, 11:52 AM
Play that funky music right
kenh3497's Avatar
Or maybe lacquer out of a spray can??? More solvent to evaporate????? The lacquer would dry a lot faster. I guess some experimentation is in order!
Ken
Apr 17, 2019, 10:43 AM
Paul's Avatar
Why not one of the lightweight iron-on films, like Parklite or something similar.
May 03, 2019, 11:11 AM
tspeer's Avatar
Originally Posted by Gerry Santos
...What is the best finishing/painting method without adding too much weight?...
Have you considered tissue over mylar?
http://www.antiquemodeler.org/sam_ne...%20mar2008.pdf
http://www.flyingacesclub.com/PFFT/T...arCovering.pdf
http://www.thebuildingboard.com/2012...ver-mylar.html
Covering with mylar and tissue
May 03, 2019, 10:24 PM
Thanks guys for the inputs. Will try experimenting first with japanese tissue and dope but unfortunately, dope is hard to come by in this country.
May 06, 2019, 07:16 PM
kenh3497's Avatar
Do you have access to lacquer? What I have used is what is used to finish furniture. It can be purchased at home improvement stores or hardware stores in the paint department. Lacquer and dope are in the same family of cellulose paints.
Ken
May 07, 2019, 03:59 PM
There are plenty of micro-light films and I've used colored felt markers.
Having built several of these types from Stevens Aero, you have to be very careful concerning weight and using any spray on coating can add it. Just a few extra grams can make a difference.
I never use any sort of spray on finish for these.
Jun 13, 2019, 10:08 AM
Lurking......
LTR91's Avatar
You don't need dope to shrink and seal tissue, yo can get away with using acrilic floor polish. I've used it with stick and tissue models and the only side effect is less shrinking ability. You might consider laminating film too. Most of the builds in the micro forum use a mix of future floor wax and Tamiya paints.
Discussion Finish for sheet balsa indoor glider jester_s1 Free Flight 10 Jan 24, 2017 02:04 AM
Cool 15" Ultra-micro indoor balsa plane K4 SE5A display on Beijing Show and become popular DW Hobby Balsa Builders 5 Sep 25, 2016 05:32 PM
Discussion What materials do I need for a balsa and silkspan plane finish? squeak1982 Painting and Finishing Tips 3 Feb 27, 2015 11:45 AM
Discussion tips for building a scrachbuilt balsa plane f22 parkflyer 3D / Fun Fly Fuel Planes 1 Dec 25, 2009 01:58 PM
Discussion tips for building a scrachbuilt balsa plane f22 parkflyer Fuel Plane Talk 1 Dec 24, 2009 12:51 PM
