This thread is privately moderated by Scale Master, who may elect to delete unwanted replies.
Mar 29, 2019, 01:48 AM
Trader Rating: 12
$100.00 USD
Buyer pays shipping
Sold
NEW -MrRCSound Smoke System For Electric RC Planes / EDF's
I bought this months ago but never got around to using it. You get all the items shown in the kit + instructions I received from Motion RC. This sells right now for around $175 bucks. So if you in the market you can save 75 bucks by picking this one up.
Details:
MrRCSound Smoke System for Electric Aircraft
This is the first electric smoke system for electric RC planes with the ability to turn the smoke on/off with the flip of switch on your radio. The MrRCSound Smoke System is a tankless system that uses distilled water and glycerin to make smoke for your electric airplane. The unit is best suited to planes with a wingspan of at least 1300mm. The smoke can be piped out of an exit air hole or out to the wingtips. Under good conditions (blue sky and sun), the smoke is very visible and will leave a long trail in the air. During twilight, and overcast conditions, although it may still be visible, it will not be as stunning.
The unit weighs around 4.5 ounces. Run times of 2 minutes and 15 seconds can be safely achieved without harming the unit. We recommend a warm up on the ground for 15 seconds and then a 2 minute run in the air. The best part about this smoke system is the ability to assign it to a channel on your receiver so it may be turned on and off from a switch on your radio. This gives you the versatility to have fun with smoke when you need it, not just during the first 2 minutes of your flight.
Since the system is tankless, there is no need for a separate tank, or injector. The unit is all self contained. Drips are minimal even when doing aerobatics or inverted flight. The Smoke system includes about a foot of large diameter tubing already connected to the system. Extra large tubing and connectors are available for purchase to extend the smoke farther back and small tubing and connectors are available for purchase to extend smoke out to the wing tips.
Connections, required cables, and batteries
Connection is very simple. The unit has a "T connector" on the power lead for a direct connection to a power source. The smoke system requires a separate battery to run it. Though the smoke system requires a 6S battery, using two 3S batteries connected in series allows for more freedom in sorting out center of gravity. We recommend two 3S 1100mAh 25C packs or two 3S 1300mAh 25C packs. The two 3S packs should be connected together using a series adapter. The unit also has a standard "JR connector" for connection to a free channel on your receiver. This allows you to turn it on and off during flight.
Features and specs:
Channels: 1 channel required to turn smoke on and off
Duration: 2 minutes and 15 seconds of smoke on a single fill
Input: 6S LiPo (recommend two 3S LiPo connected in series)
Current: About 22A peak (amperage falls to a low of about 12A as smoke is burned off)
Dimensions: 3.25" x 2.25" x 2.25"
Weight: 5.5oz
Battery Connector: T-connector
Receiver connector: Standard JR male servo connector allowing connection to nearly any brand receiver
Paypay payment adress: [email protected] (please, if sending payment select friends and family to save on pp fees).
Thanks, for lookin..
-TSM
Mar 29, 2019, 09:23 PM
Trader Rating: 8
Caveman5150's Avatar
PM sent for questions
Mar 30, 2019, 02:58 AM
Trader Rating: 12
PM'd to your questions!
Sold NEW -MrRCSound Smoke System For Electric RC Planes / EDF's Scale Master Aircraft - Electric - Airplanes (FS/W) 1 Mar 30, 2019 03:21 PM
For Sale NEW -MrRCSound Smoke System For Electric RC Planes / EDF's Scale Master Aircraft - Electric - Airplanes (FS/W) 1 Feb 18, 2019 05:22 PM
For Sale NEW -MrRCSound Smoke System For Electric RC Planes / EDF's Scale Master Aircraft - Electric - Jets (FS/W) 0 Feb 18, 2019 07:13 AM
Sold MrRCSound Smoke System for Electric Aircraft wdy Aircraft - General - Miscellaneous (FS/W) 0 Nov 16, 2014 09:13 PM
Discussion Smoke system for electric planes and edf jets Red Leader 1 Electric Ducted Fan Jet Talk 3 Sep 17, 2013 03:07 AM
