This thread is privately moderated by Gary Chen, who may elect to delete unwanted replies.
Mar 28, 2019, 03:24 AM
Gary Chen's Avatar
Long flying time drone: 61 minutes with 2KG payload
61minutes with 2KG payload on YD6-1600L long flying time drone (7 min 38 sec)
47 minutes with 5KG payload on YD6-1600L heavy lift drone (5 min 58 sec)
YD6-1600L hexacopter frame is a multifunctional heavy-lift flight platform. Its one-time forming carbon fiber technology reduces weight while still keep the stiffness, which makes it stronger and lighter for long flight time.
Stable and reliable
YD6-1600L arm connector is using special compound material: industrial plastic with glass fiber. This compound material features high strength and flexibility, which can stand high-frequency vibration created by the motors in the air. Furthermore, with a glass fiber canopy, the GPS signal will not be blocked.
Easy for setup and maintenance
Frame arm of YD6-1600L is detachable, which will enable you to finish the drone setup in 5 minutes. Furthermore, if the arm is broken during a flight crash, you will just need to replace it with a new one, which will greatly save your maintenance cost and time.
Long flying time
Equipped with the 29inch propeller, KV85 U8 Lite motor, 2 units 6S 32000mah HV lipo battery, the YD6-1600L frame is able to fly 61 minutes with 2KG payload, 47 minutes with 5KG payload.
Good for drone customization
YD6-1600L comes with big size center frame, which is able to accommodate more devices. So it becomes an ideal flight platform for your drone customization.
Power combo it is using
Motor: T-Motor U8 Lite KV85 motor
ESC: T-Motor ALPHA 60A HV ESC
Propeller: T-Motor 29*8.7 inch propeller
Battery: 2 x Tattu 6S 32000mAh 22.8V high voltage lipo
Discussion Heli under 2kg with 700 gr payload vdiallonort Electric Heli Talk 13 Dec 08, 2016 10:56 AM
Discussion Long flight time and large payload? maybe50 Electric Plane Talk 10 Jan 06, 2016 04:34 PM
