Some of us found the bearings loose in the plastic holders.
Of course you already know but... the more centered, the better! Have fun! |
The elevator system was much improved (tighter) after adding paper shim material between bearings and the plastic bearing retainer cups. MRC mentions this procedure in the form of a service bulletin. It took about a hour to extract the broken screw but overall I’m glad I added the shims. The elevator to shaft bolt snapped while trying to remove screw one day after it was installed using blue locktite. I believe the issue is with the strength of bolt, not the thread locker used. I make it a practice to remove all set screws and similar fasteners to ensure thread locker has been applied. Never used a tap in the process but this experience may make me do so in the future. |
I'm off to maiden my PST reaction and re-certify my SM hawk. If all goes well i'll be buzzing with excitement and get right onto the Hornet. If the day ends in tears, well...... |
Please let us know how it goes. I have one on the table now as well. I managed to get a 590 ml juice bottle under the spine with a little cutting of the foam. The center of the bottle is within 15mm of the CG so I was happy with that. sitting a bit forward is a secondary tank that hold an additional 180 cc. Total useable fuel is 720ml ( 24 oz ). A little cleaning up and the hatch fits perfectly back into place.
Dean W. |
A fuel bladder is a pretty conformal solution, too.
Latest blog entry: Using acrylic floor gloss to coat foam
Hmmm cant use them in Canada and I don't think its AMA O.K. either....
dw |
Rigid does not necessarily mean more puncture-resistant. Can be the opposite.
Bottles can be rather rigid depending on the type. This applies to any fuel powered airplane. I won't ever use a bladder type fuel tank, but the bottle is fine, I have seen it used on many large scale applications without issue or breaking the "rules" not laws. Let me know how this goes, and if you get video of it. Got my second X45 sittin in the box barking at me.
Can you set the tank lower down into that area? Yeah a bladder would be a very handy solution to the "odd shapes left for fuel" type problems these conversions bring. Not really worried about what the AMA rules say The Germans seem to be pretty keen on them, but trying to find somewhere to buy them from is not so easy. Might stick with a solid tank on this one. I have also heated the plastic tanks and pushed them into more useable shapes on conversions before with some success. Made my turbine mounting "ear" out of 0.030" aluminium, Have contacted my buddy about making another pipe that is right on 45mm because I need all the clearance I can get. |
Ok,
pic's for the previous post and with inspiration from shokaidobb efforts, I have completed the cutting out. access hatch first to then remove the required material. my grand master plans were foiled to some extend by the spar tube. this only really allows the tank to have 15-20mm of its length behind the CoG. Would have liked more, but happy to call it a day there and see how much the fuel burn affects the CoG in flight. I still have the opportunity to add another tank aft of the spar to help if needed. |
