This thread is privately moderated by Mad_angler1, who may elect to delete unwanted replies.
Mar 25, 2019, 05:13 PM
Bog Flusher Platinum Grade
Mad_angler1's Avatar
Mini-Review
Polar Pro Monitor Mount for DJI Ronin S
The guys over at Polar Pro contacted me a few weeks ago about their new monitor mount for the DJI Ronin S and I wanted to share some info and my thoughts on this with you after receiving it.
This new accessory from Polar Pro allows you to fit an external monitor and accessories to your Ronin S, it’s made from light weight aluminium and one of its best features is that it has a quick release so its very easy to quickly remove and you don’t have to worry about it getting in the way in storage or if you don’t need it.
On the bracket itself you have the usual accessory thread that is attached to a large captive thumb screw for mounting to the monitor, the face is coated in rubber as well to ensure the bracket does not cause any damage to the monitor.
On the top and corner of the mount there are 3 additional ľ’’-20†threads that are designed to take accessories such as a microphone or lights giving you multiple fitment options should you need them.
In the kit polar Pro includes everything you need to fit the mount in the field including a hex wrench, Its mounted to the Ronin S via a QR plate that gives you the ability to mount it on both the left or the right hand side, It screws over the accessory port and once the base plate is fitted you can simply attach the mount via an integrated thumb screw.
In the plate there are multiple lug holes all the way around that allow the mount to be locked into place giving you the ability to set the perfect viewing angle.
Overall
This is a very nice and well made bracket for the DJI Ronin S, when fitted its extremely solid and the locking pins mean you don’t have to worry about the bracket rotating in use while still giving you the ability to position it in any 360 degree spot you need, It costs $49.99 and includes Polar Pro’s usual life time warranty, if your looking for a bracket to hold a Small HD Monitor or anything to the Ronin S this is well worth a look.
You can order the bracket from Polar Pro here https://www.polarprofilters.com
You can order the Ronin S Here too https://click.dji.com/AHaZe1oTt0pits...0001&pm=custom
New Product Dual Monitor Mount For DJI Phantom 3/4 and Inspire 1 dotster77 Multirotor Drone Talk 0 Oct 18, 2016 10:43 AM
Article DJI Ronin - 3 Axis Pro 8kg Gimbal RCGroups Update Multirotor Drone Talk 361 Jan 28, 2016 08:00 AM
