This thread is privately moderated by Spaaro, who may elect to delete unwanted replies.
Mar 21, 2019, 05:41 AM
Spaaro's Avatar
Build Log
FX-706 Sloper Mods: Safety Pin Hinged Rudder, & Shaping up the Stab
Part of this project I was looking forward to: using safety pins for hinging. Connected up the rudder post...turned out FANTASTIC!
Having that little bit of metal in there seems more like real, hinged control surfaces than CyA-soaked plastic ones.
They went together in one session/sitting; I don't think it is too much more effort than pre-made hinges either, at least as far as alignment/gapping.
Stabilizer progress:
Its not based on any particular airfoil beyond 'TLAR'--a slab with a modest amount of symmetry, eg: flattened lenticular shape. I had skipped a step that would have imparted more convex curve to the slotted undersurface(..moisture + heat molding..); still possible but a bit tougher this far along in its build. Probably unnecessary.
With 20/20 hindsight, I could have designed a better 'stab-vertical' "T"-interface or mount, likely without the potentially weak, chord-wide slot. At this point, a CF-tow patch & leading edge sheeting should solve it.
I'm not 'seeking' any hobby grade balsa or ply veneer; I've got bamboo flat strips from a thrift store dinner mat: edge-sanded into planks and joined to form sheets. About 20+ minutes of judicious sanding gave me 2, thinned sheets perfect for the task; they will be sanded much thinner once mounted in place.
Spliced them together on a bias to match the mild forward sweep; hoping this crossing of the bamboo's long grain will also improve torsional stiffness.
Aiming to mount later today--we'll see!
Discussion Im building a chipmunk. I was wondering has anyone covered the stab and rudder first ng8264723 Painting and Finishing Tips 1 Mar 06, 2016 07:28 PM
Yippee! Bird Shaped flyer... now with elevon/rudder set-up CactusJackSlade Thermal 7 Dec 05, 2003 10:18 PM
