This thread is privately moderated by Spaaro, who may elect to delete unwanted replies.
Mar 20, 2019, 07:19 PM
Spaaro's Avatar
Build Log
FX-706 Sloper Mods: "But wait--There's MORE!"
I've now gotten 1/2 way thru constructing the stabilizer and verifying it's fit/alignment atop the Vertical. Currently sits @+2.5 deg. incidence, but too early for any fixed decalage setting.
I 'DID' cheat here: I've added a couple strips of CF ribbon across thinned wood on its central mounting plate, as the mounting slot has a glaring fracture/stress point.
A bit torsionally flexy, but not after I attach some wafer-thin, bamboo sheeting along its leading edge and a few cross braces. The acrylic plastic base material is rather heavy; it will all be cut/'fretted' out; cover will be either mylar or Tyvek.
Elevators will also be foam & safety-pin hinged and I've only sketched out possible linkage patterns for moving those angled halves smoothly.
I should be working it now, but I've put off posting updates longer than I expected.
Discussion Eachine H8 mini - It's time for antenna mod. But... silverAG Mini Multirotor Drones 1 Jun 29, 2016 04:39 PM
Is there a brushless Gws Ips size,but more power. kitbasher Parkflyers 6 Sep 01, 2003 07:45 PM
