Mar 19, 2019, 05:49 AM
FrSky-MKT - Forum Sponsor
AndreaHuang's Avatar
New Product
FrSky New Arrival - Taranis X-Lite S and Pro
With the growing acclaim of the new compact X-Lite form factor, FrSky is introducing this upgraded version. The Pro and S versions combine all the benefits of the preceding design with the features of our full-sized radios, along with the newly developed ACCESS (Advanced Communication Control, Elevated Spread Spectrum) protocol.
New for the Pro version is a high-quality, all-metal CNC hall sensor gimbal. Checking the airwaves for RF noise is now possible with the new power meter and spectrum analysis function added to the OpenTX firmware. Both versions feature the addition of a PARA wireless trainer function which makes them compatible with the FrSky Free Link App and AirLink S. The best thing about the Pro and S models is that pilots can now expect even lower latency and enhanced performance due to our new ACCESS transmission protocol. With the integrated 6-axis sensor unit, pilots can use the radio as a motion-sensing controller to control the inputs of a model during flight or use it to point a camera in the desired direction. Like all of our transmitters, all of the beloved features from previous Taranis are included such as full haptic feedback and voice alerts, as well as telemetry and 24 channels and an additional 2 momentary buttons are installed.
Name: X-Lite Pro 2-2.jpg
Description: Name: X-Lite Pro 3-3.jpg
Description:
Name: X-Lite Pro 5-5.jpg
Description: Name: X-Lite Pro 6-6.jpg
Description:
SPECIFICATIONS
  • Number of channels: 24 channels
  • Internal RF module (X-Lite S): ISRM-S
    Internal RF module (X-Lite Pro): ISRM-P
  • Weight: 308g/ 376g (with battery)
  • Operating Voltage Range: 6.0 ~ 8.4V
  • Operating Current: [email protected]
  • Operating Temperature: -20C ~ 60C (-4F ~ 140F)
  • Backlight LCD resolution: 128*64
  • Model memories: 60 models (expandable by micro TF card)
  • Micro USB interface: supports 2S Li-battery balancing charge
  • Compatibility: ACCST D16 and ACCESS receivers
FEATURES
  • Ergonomic and compact design
  • M12 Lite hall sensor gimbals (S)
  • MC12 Lite all-metal CNC digital hall sensor gimbal (Pro)
  • Upgraded RF module with installed ACCESS protocol
✧ More sensitive and lower latency (down to 12ms)
✧ High-speed digital interface of internal and external modules (Baud rate: 450K)
✧ Longer range with 40% enhanced performance
✧ Accurate SWR indicator
✧ Supports power meter function
Input Signal Measurement Range (Frequency: 900MHz & 2.4GHz, Precision: within 1db)
Without attenuator: -50dbm ~ -10dbm
With added 40db attenuator: -10dbm ~ 30dbm (Optional Accessory)
✧ Supports spectrum analyzer function
  • New PARA wireless training system
✧ High-speed training system with a lower latency
✧ Compatible with FrSky Free Link App and AirLink S via mobile devices
  • Supports wired training function
  • High-efficiency quick-charge system
✧ Supports 2S Li-Battery balancing charge
  • Supports motion sensing control
✧ Integrated with 6-axis sensor unit
  • Haptic vibration alerts and voice speech outputs
Taranis X-Lite S PRICE (TAX EXCLUDED): US$ 149.99
MORE DETAILS: https://www.frsky-rc.com/product/taranis-x-lite-s/
Taranis X-Lite Pro PRICE (TAX EXCLUDED): US$ 199.99
MORE DETAILS: https://www.frsky-rc.com/product/taranis-x-lite-pro/
Taranis X-Lite Comparison List: https://www.frsky-rc.com/frsky-new-u...d-pro-release/
Mar 19, 2019, 08:39 AM
P.I.Engineer's Avatar
will there be heavy duty springs available for the gimbals?
Mar 19, 2019, 12:45 PM
Will ACCESS protocol require new receivers or can previous generations be flashed to use ACCESS?
Mar 19, 2019, 08:45 PM
jtroutt19's Avatar
When can I purchase it?
Mar 19, 2019, 08:46 PM
Hi sir,
The springs of MC12 Lite gimbals are adjustable on Pro version.
Mar 19, 2019, 08:48 PM
jtroutt19's Avatar
Let me buy it now! Please
Mar 19, 2019, 08:51 PM
Hello sir,
All FrSky transmitters and previous X, RX and GX series receivers will be gradually supported to use ACCESS protocol.
Mar 19, 2019, 08:54 PM
Sure, won't be a long time.
Mar 19, 2019, 10:10 PM
Originally Posted by AndreaHuang
Hello sir,
Excellent news,
Thank you sir.
Mar 20, 2019, 10:53 AM
What about R9 stuff? Will that stay on ACCST?
Mar 20, 2019, 01:18 PM
GerdS's Avatar
Hello sir,
Will the new protocol stil be divided into a FCC and an EU-LBT version or will it be LBT for all regions?
And a question to the new X-Lite S/Pro:
What type is the casing finish? Still this sensitive and not very durable soft coating of gthe original X-Lite or just plain but good structured plastics?
I had a lot of radios during my life, one is about 20 years old, still in use for my submarines and still looking as good as new. None of them was as sensitive and had that low durability as the housing of my original X-Lite, where the coating peels already off after just 6 months!
As I functionally like the X-Lite, I would swap it for the Pro version, but only if that one doesn't have that same lack in surface quality...
Mar 20, 2019, 10:23 PM
Is this the "new radio" that Andrea hinted at a couple of months ago that was going to be introduced?
Also, these use a Micro USB port for charging.
So can you charge these with a standard USB charging cable (like a cell phone) or does it use the proprietary hang on charger that the early X10's used?
Mar 21, 2019, 03:08 AM
GerdS's Avatar
I would like to see a robust USB type C connector here.
Mar 21, 2019, 03:11 AM
Happy FPV flyer
Kilrah's Avatar
Standard USB.
Mar 22, 2019, 01:41 PM
SilverLine's Avatar
Sounds nice
https://www.frsky-rc.com/frsky-advan...tocol-release/
Discussion FrSky - Taranis X-Lite - S and Pro - X9 Lite - S - R9M Lite and Pro - MPM Lite Jet_Flyer Radios 4103 Jan 09, 2022 10:42 AM
Discussion FRSky R9M Lite - Long range mini module for Taranis X-Lite sevet Radios 42 Dec 14, 2020 10:11 AM
New Product FrSky New Arrival - Taranis X-Lite Compact Transmitter Release! AndreaHuang FrSky 12 Sep 19, 2018 09:30 PM
New Product FrSky Taranis X-Lite Transmitter Parts BRACE Lite & Long+Short Gimbal Stick Ends for Rishi Banggood.com 4 Aug 31, 2018 02:02 PM
