Feb 23, 2020, 12:46 PM
1275mini's Avatar
My build so far
Just waiting on a couple of metal tail upgrades to arrive
And my motor
Feb 23, 2020, 12:50 PM
UK 550/600 Tarot distributor
Smoggie's Avatar
And my motor
Shame i didnt know you needed stuff. I've got it all here in the UK, motors as well.
rc user
pdooley's Avatar
for 6S-
possible to use the 600 gear on the 550 frame?
a quick check shows the 600 gear has 106T vs 153 for 550. but the module is also different so I'm not sure if the 600 ratios would help get more rpm..
what are the 550 and 600 pinion sizes?
Smoggie- you should put the UK distributor info in your header if possible.
Feb 23, 2020, 01:41 PM
Smoggie's Avatar
Yes, the 600 gears will work perfectly on the 550, but they need a motor with a 6mm shaft.
Good call on the header, i'll get that sorted
Feb 26, 2020, 09:41 AM
1275mini's Avatar
Going by the build quality of my 600 I would definitely be in the market for a 700
Feb 26, 2020, 02:06 PM
Smoggie's Avatar
Hopefully you can bring your 600 to helifest in June? I'll be there on a shared stand with Tarot from China and the UK distributor ScotiaRC. Anyone who brings and flies a Tarot heli gets a free beer (or a coffee for the non- drinkers!)
Mar 02, 2020, 06:47 PM
Stevies's Avatar
I use EC5 connectors currently but used the AMASS connectors and made an extension to go out the front and down the side. Quite like it to!
I'm using 6S and Opti 6S 5000 packs.
Mar 13, 2020, 11:01 PM
Team Compass/KBDD Team Pilot
Ah Clem's Avatar
I am going green...
No, I didn't go out and purchase a more fuel efficient car, but I did pick up some of the special green parts for my Tarot 600 helicopter. these match the Lime Green KBDD 96mm EE Tail Blades as well! I have been installing these a few at a time.
Mar 14, 2020, 03:12 AM
Smoggie's Avatar
You need the green tail fin to complete the look
Mar 14, 2020, 03:34 PM
Ah Clem's Avatar
I actually have one-I forgot about it!
Mar 14, 2020, 04:05 PM
Ah Clem's Avatar
Stephen,
Do you have a link to your Tarot Distribution business in the U.K.?
Someone is asking for a European Distributor on FB.
Thank you.
Mar 14, 2020, 04:25 PM
1275mini's Avatar
U.K. Stockest
https://scotiarc.co.uk/
Love my 600 can’t wait for the 700
Mar 14, 2020, 05:44 PM
Ah Clem's Avatar
Thank you very much 1275mini.
I have posted that on FB.
Mar 15, 2020, 04:51 PM
Smoggie's Avatar
Thanks.
I've still not made the payment section of the site live, but anyone wanting to buy can contact me and I'll sort out the order.
Mar 20, 2020, 05:02 PM
Atomic Skull's Avatar
Budget ESC option, $108 for a 150A HV ESC.
https://www.altitudehobbies.com/coll...sc-opto-no-bec
Helidirect sells the JP Hobbies version (ZTW is the OEM) for $196 but they are the exact same ESC and the only difference is branding.
https://www.helidirect.com/products/...is-150a-hv-esc
Note that ZTW's governor is kind of useless (it's fixed RPM and you adjust the headpeeed by changing the pinion) so you'd have to use a brushless RPM sensor and the FBL governor. I'd recommend the Eagle Tree v2 sensor. Red is ground and black is positive on the Eagle Tree sensor so you need to swap those two wire in the connector. What I do is put 2mm bullet connectors on the sensor and then solder short 18awg pigtails either to the outside of the female bullets on the ESC or solder them into the cups on the male bullets on the motor depending on what's more convenient at the time (if I am putting new connectors on the motor). I do not like soldering them into the cups on the female bullets because the 10 AWG wire on the ESC side leaves little room while the solid strand wire on the motor side leaves plenty of room in the solder cup for the extra wire and is also less prone to excessive wicking.
Discussion Tarot 550/600 FBL rotor housing TL60231 pdooley Large Electric Helis 14 Jan 13, 2020 12:49 AM
News NEW 2017 Mikado 550/600 ndfly700 Electric Heli Talk 3 Jun 08, 2017 01:27 AM
New Product New KDS 550/600/700e Flybar and FBL PnP from RCWarez rorrock Large Electric Helis 170 Nov 21, 2014 10:50 PM
Poll What is the cheapest 550-600 size CP heli to crash? FlybyPDX Electric Heli Talk 40 Dec 21, 2007 10:46 PM
Article Upgrading Two Very Different Planes from NiMH to an Electrifly Lipo 1200 FLYWINGFAN Batteries and Chargers 14 Nov 16, 2004 03:07 PM
