Jun 03, 2019, 08:19 AM
I think that would be a great option.��
Jun 03, 2019, 07:35 PM
Lynxman's Avatar
I added aileron wings now. Took longer than I thought to make the change, but it's done now. I reduced the dihedral to 4 total as well. Bend 2 mm piano wire or similar to the shape of usual sport plane aileron torque rods. They should click into the slots on the underside of the wing. Thinner rod can also be used, down to 1 mm, since it's such a small plane, with some kind of sleeve to reduce the fit of the channel. I split up the ailerons in the same place as the wing parts so that multi color printing will align. Use ca hinge for the ailerons.
Jun 04, 2019, 07:35 AM
Will you be posting to Cults or Thingiverse? I ‘d like to see it.
Jun 04, 2019, 09:15 AM
Lynxman's Avatar
It's on Cults. I uploadewd it yesterday. https://cults3d.com/en/3d-model/vari...l-reproduction
Jun 05, 2019, 06:18 PM
Any possible build videos or build pics of it? So far F1, F2, Nose and Motormount look good. I'll post pics soon. Thanks again, this is a real joy. Joe
Jun 06, 2019, 10:00 PM
Would you consider a straight wing Mod with ailerons? Just as a option. Progression design for training new pilots.
Jun 08, 2019, 12:21 PM
So here is a peculiar happening. Stringing on one side only.
Jun 08, 2019, 12:23 PM
Here is what I have so far at 135%. Exciting.
Jun 08, 2019, 12:25 PM
Lynxman's Avatar
Cool.
Jun 08, 2019, 03:54 PM
Is this a plug to cut out for air circulation in the electric set up option?
Jun 08, 2019, 04:14 PM
Building at 135% does have its challenges. Using an Ender 3 Pro. Just under max volume. Vibration at top end.
Jun 08, 2019, 04:21 PM
Lynxman's Avatar
Yes you should cut away the end of that plug. It also helps with aligning the nose piece.
Jun 10, 2019, 06:03 PM
Any pics of the Latch Mech? Started on the wings. Everything else is printed. Cheers!!!
Jun 10, 2019, 06:17 PM
Lynxman's Avatar
Two rods and a spring will work. Here's the same mechanism on another plane of mine:
Jun 11, 2019, 10:23 AM
Thank very much. Joe
Discussion Blu Baby trainer mt92 Foamies (Scratchbuilt) 10 Mar 22, 2016 07:52 PM
Discussion Choosing Trainer Plane for New "Pilot" soegeng.patric Beginner Training Area (Aircraft-Electric) 10 Aug 15, 2008 05:07 PM
Golden Age Reproduction; Fleet Trainer, Conversion Downwind 1 Scale Kit/Scratch Built 8 Nov 05, 2005 09:44 AM
New glow/IC fuel Trainer review for the glow pilots in this beginners forum.... AMCross Beginner Training Area (Aircraft-Electric) 0 Apr 19, 2004 03:38 PM
Few of the trainers I recommend for new pilots! someone special Beginner Training Area (Aircraft-Electric) 17 Aug 23, 2003 02:30 PM
