Mar 14, 2019, 11:52 AM
Joe 1320's Avatar
New Product
Micro Airbus A-380 Airliner
Considering the lack of airliners, this could be popular. Its based on the same differential thrust as many of the other rtf micros, but with elevator control this should be fun. Its on pre-order at banggood.com.
WLTOYS A120-A380 2.4GHz 510mm Wingspan 3CH RC Airplane Fixed Wing RTF
Features:
The built-in six-axis gyroscope flight self-stabilization system, allow the beginner to master it easily.
Remote control transmitter comes with small rudder and big rudder control. Small rudder for beginners, big rudder allow the stunt function of airplane, like rotating etc.
Dual back pusher powers, forward and backward propellers cancel each other out, course lock is more stable
EPP material, durable and light, only 70g.
Ultra stable, easy control for beginners.
Assembled and comes with 2.4Ghz 3CH remote control system and mode 2 left-hand-throttle controller, ready to fly.
Specification:
Remote Control : 2.4G 3CH
Wingspans : 51cm/20in
Net Weight : 72g
Charging Time : about 30min
Flight Time : 7-8min
Material : EPP ABS
Remote Control Distance : more than 200m/656ft
Motor : Coreless motor 07162
Battery : LI-POLY 3.7V(300MAH) 20C
Charger : 1S USB charger
Model : A120-A380 3CH Airplane
Fuselage : 48cm/18.9in
Package Included:
1xA120-A380 RC Airplane
1xCharger
1xCW Prop
1xBattery (Built in)
1xCCW Prop
1x2.4G 3CH Remote Controller Transmitter
1xLanding Gear
Mar 14, 2019, 12:09 PM
ɹǝʎןℲ ǝıssn∀
taz101's Avatar
It might be helpful if you change the thread header to A-380 not A-320
Latest blog entry: Compulsory Reading!!
Mar 14, 2019, 06:39 PM
Quad Erat Demonstrandum
scousethief's Avatar
If it flies as well as the previous c-130 then it should sell very well.
Mar 15, 2019, 01:56 AM
Rudi's Avatar
Ordered it and the decals of a revell LH A380 I hope this is a good base for some scale modifications
Rudi
Apr 01, 2019, 08:42 PM
Tom Para
Tom in Cincy's Avatar
I ordered one off Ebay last week from a US seller.
I edited this post because I got a response from the seller.
He is from the Philippines
The item does ship from California
Ordered March 28
Arrived April 6.
He has many aliases estherser-0 , barn-37 , michaelaoyo0 , aricle_86, band_30 , double_deals99 , edaelec0 ,
I will report back If I get the plane
I got the plane and it flys GREAT!
Apr 02, 2019, 05:39 AM
airbus A380 XK A120 DSM2 receiver MOD.
空客 AirBus A380 偉力 XK A120 改裝 DSM2 接收機 混控尾舵 @中心公園 20190322 (1 min 5 sec)
Apr 02, 2019, 06:37 AM
Pixelpeter's Avatar
That looks really nice!
Apr 02, 2019, 06:59 AM
Joe 1320's Avatar
Tracking shows mine should arrive Thursday. My intent was to covert it to dsmx, lol... someone already beat me to it. Looks good
Apr 03, 2019, 07:39 PM
Joe 1320's Avatar
A nice surprise, the A-380 arrived a day early. It’s really easy to assemble, plug in the elevator servo and literally one screw to hold the wing to the fuse. The landing gear pop right into place if you want to use them, just charge the battery and go. Maiden flight in the morning.
Apr 03, 2019, 09:03 PM
WL Toy XK A120 Video (AirBus A380)
空中巴士 AirBus A380 偉力 XK A120 原廠宣傳影片 (1 min 7 sec)
Apr 04, 2019, 01:04 AM
https://www.youtube.com/watch?v=jzBRi1FdKKY
dsm2 by replacing a receiver ?
Apr 04, 2019, 08:27 AM
Joe 1320's Avatar
Took a maiden flight this morning, it flew. Out of the box, elevator control is what I could best describe as touchy but it works. The first landing was easy and no bounce from the landing gear. It’s a win when you consider its portable ( disassembles and stores in the box), has elevator control and the landing gear actually work. I can see that converting this to full control would make this a home run.
Apr 04, 2019, 08:43 AM
Tom Para
Originally Posted by Joe 1320
Took a maiden flight this morning, it flew. Out of the box, elevator control is what I could best describe as touchy but it works. The first landing was easy and no bounce from the landing gear. I.
I have a couple of questions.
In the first video the pilot looked to be stalling the plane and then going into a snapping spin.
So does it stall forward or does it snap.?
They advertise that it has a gyro .. is it built into the receiver??
Video1 shows tailerons. I am sure that is not stock.
The thing uses differential thrust. I assume the speed controllers are also built on the the receiver board ?
Apr 04, 2019, 11:33 AM
Joe 1320's Avatar
Yaw is handled with differential thrust, however..... it’s not on the rudder channel, it’s on the aileron channel. Too much elevator at slow speed and it will drop a wing. I managed to do that by slowing down and feeding in up elevator. Keeping the throttle up prevents the stall. I haven’t explored what it will or won’t do, I was really limited to a couple minutes on the first flight. In short, don’t try to really feather back the throttle unless you’re on final approach.
The receiver board has built in speed control and two extra unused sockets, I’m assuming for plug in lighting like the C-17, Diamond, and the Reaper drone.
Apr 04, 2019, 06:25 PM
Joe 1320, where did you purchase from and how long did shipping take?
Thanks.
New Product Walkera Furious 320 Tilt Rotors & GPS enabled! juliet Multirotor Drone Talk 19 Today 02:50 AM
Build Log 1/9th Scale PSS HFB-320 (Hansa Jet) Scratch Build Owen Hedger Slope 140 Sep 18, 2017 08:22 PM
New Product Walkera Runner 320 Dinamo Multirotor Drone Talk 1 Dec 25, 2015 02:47 PM
